RussellK Samba Member
Posted: Wed Dec 20, 2006 2:05 pm Post subject: Inside Panels FAQ |
What kind of treatments have been done to your interior panels. I need to replace mine on a '77 Westy. The Shurfit panels from WCM have been discontinued and TMI has a reputation for poor quality. Sewfine is supposed to be pretty good. Any others? _________________ -Russ
'77 Westphalia
'68 Standard |
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Wed Dec 20, 2006 2:12 pm Post subject: |
The wood paneling?
I pulled my old stuff out, bought 3mm baltic birch, and
traced the old panels - used them as a template.
I then used a good jigsaw and fine toothed blade (to minimize chipping).
I taped both sides where I was to cut, to also prevent chipping.
After cutting, I sanded, stained, and protected.
Like so.
_________________ '76 Deluxe Campmobile
Posted: Wed Dec 20, 2006 2:25 pm Post subject: |
I've read about usiing the Baltic Birch. How did you attach it? _________________ -Russ
'77 Westphalia
'68 Standard |
Posted: Wed Dec 20, 2006 2:32 pm Post subject: |
I used the same hardware that attached the old panels. After
I cut the new panels, and confirmed their fit, I put the new and old
panels back to back, marked the location of the drill hole, taped over each hole to prevent tearing, and proceeded to drill them
out. _________________ '76 Deluxe Campmobile |
themarshotel7 Samba Member
Joined: February 04, 2005 Posts: 336 Location: Valparaiso Indiana
Posted: Wed Dec 20, 2006 2:59 pm Post subject: |
Hey Poptop, im in valparaiso. Where did you find the 3mm baltic? and how much per sheet? _________________ 1971 Westy
1972 Super Beetle
2001 Eurovan
1991 Fox
"Going wrong this curve set up for that unless you got a flat or suspension change even but what I found out was I could throw anything into reverse under ten miles an hour aw gosh good old granny you can allways tell by the fear in your belly how limited y'ar."
-Neal Cassady |
Sk84Jesus3 Samba Member
Joined: September 11, 2006 Posts: 72 Location: St. Louis, MO
Posted: Wed Dec 20, 2006 3:05 pm Post subject: |
| poptop tom wrote: |
The wood paneling?
Like so.
That looks really good. Just wanted to commend your craftsmanship. _________________ What's under the hood? A tire. There's a spare engine in the trunk. |
ChiTwnVW Samba Member
Joined: November 18, 2004 Posts: 1174 Location: Home. Sweat home.
Posted: Wed Dec 20, 2006 3:18 pm Post subject: |
| How many of the 5X5 sheets did you use? |
Posted: Wed Dec 20, 2006 4:58 pm Post subject: |
| Quote: |
| Hey Poptop, im in valparaiso. Where did you find the 3mm baltic? and how much per sheet? |
Had to go to Chicago to get it. Big C Lumber located it for me. I have the info on the place at work.
| Quote: |
| That looks really good. Just wanted to commend your craftsmanship. |
Thanks! I was happy with the turnout.
| Quote: |
Again, I have all that info at my shop. I'll get it to you all tomorrow a.m.
Sorry I'm no help to y'all this evening.  _________________ '76 Deluxe Campmobile |
Posted: Wed Dec 20, 2006 6:53 pm Post subject: |
| Someone could probably have a business making those panels. |
westyornot Samba Member
Joined: August 31, 2004 Posts: 79 Location: Central CA
Posted: Wed Dec 20, 2006 8:59 pm Post subject: |
I traced my panels just like everyone else; then upholstered them. It's really not that tough to do; just takes some patience and a lot of aerosol glue.
_________________ The best things in life aren't things... |
Posted: Wed Dec 20, 2006 9:57 pm Post subject: |
| My inititial reaction was, why cover up that beautiful wood. But I have to admit it looks nice. Way to go! |
jamesinkster Samba Member
Joined: November 14, 2006 Posts: 77 Location: North Vancouver, BC
Posted: Wed Dec 20, 2006 10:45 pm Post subject: |
i like the upholstered look -- very slick.
how did you attach them? in the pic i don't see any screws, etc... plastic clips in the back?
thanks |
jereandjess Samba Member
Joined: January 09, 2005 Posts: 563 Location: Massachusetts
Posted: Thu Dec 21, 2006 7:19 am Post subject: |
Hey Tom, that really looks great!
What stain did you use to make it come out so close to the original? _________________ ~Jeremy (and Jessica)
77 Sage Green Westfalia 2.0 FI - since May 2004
78 Blue Landmark camper 2.0 FI - since April 1998
69 Beetle - In the family since new
86 Wolfsburg Vanagon Camper "Weekender" since July 25, 2015 |
Posted: Thu Dec 21, 2006 9:00 am Post subject: |
I'm attaching a few different ways:
- side panels you see are anchored at the top in the channel; then I used screws with finishing washers just behind the seat there and at the floor... they're visible at the other end.
- the front door panels have been drilled and will use the hidden factory clips
- the rear hatch and slider were drilled for the factory chrome headed clips (visible just like they are with the wood panels)
Matt _________________ The best things in life aren't things... |
Posted: Thu Dec 21, 2006 9:27 am Post subject: |
Okay folks, here is some more info from my panels.
It took 2 sheets of 60"x60" baltic birch panels.
This did all westy panels (76-79). No kickboards. No
front panels. No headliner. Just the back hatch, slider,
around the fridge, and the other smaller trim pieces.
I couldn't find the product locally (South Bend), but was referred to a place in Chicago, near Midway. Frank Paxton Lumber. It's
on west 66th.
This stuff is not easy to haul. I had my old Ford fullsize pickup,
and fitting the pieces in the back was challenge, as I didn't want them blowing out, or warping!
Any how, here are more details.
First, the wood is flexible along the grain, and rigid against it. Keep this mind for each piece you cut.
Before doing any cutting, etc., the first thing I did was sand each piece
with 120 grit, and dry clothed it clean.
I then applied Olympic oil base sanding sealer. It took about a quart
to do both sides. Let it set overnight, and came back with 220 grit. WITH the grain! I then tack clothed it good.
Now I traced my lines - on both sides!
Masking tape over the lines (both sides).
Put the back side up, and use a utility knife with a new blade
and cut just inside the line (this will confine the chipping).
I then used a jig saw with a sheet metal blade (>1mm max tooth
spacing) and cut all pieces out.
I then stained 1 coat of ZAR oil-based wood stain - 120 Teak Natural.
Let it dry 3 hrs., or longer, and lightly sand with 800 grit. WITH THE GRAIN! .Wipe clean with tack cloth. Stain it again.
Let it dry overnight (is it dark enough?). If not dark enough,
lightly sand with 800 grit, wipe clean, and stain again to desired darkness.
I used simple cloth stain rags to apply stain.
My panels aren't an exact match (although I've never seen
barnd spankin' new panels to truly compare to), but are very close, and I'm very satisified with how they came out.
There are more pics in my gallery, I believe. I'm satisified with the turnout!  _________________ '76 Deluxe Campmobile |
young5o Samba Member
Joined: July 03, 2006 Posts: 153 Location: Wine Country, Oregon
Posted: Thu Dec 21, 2006 2:31 pm Post subject: |
| westyornot wrote: |
Nice work on the panels. Did you have to open up the channel at the top to get the panel to fit? Did you use pading behind the upholstery?
RussellK. I had the same questions. Glad you brought it up.... |
Posted: Thu Dec 21, 2006 5:35 pm Post subject: |
I opened the channel up a bit; not much at all (hindsight, do it before the paint job!). I used masonite (hardboard?) and have a somewhat thick fabric, so the fit is a bit tight and the panel doesn't go all the way into the channel. I also cut the foam short of the edge of the panel to keep the overall thickness at the edge as small as possible.
I used 1/4 inch upholstery foam; nylon webbing on one side. It doesn't give much lift on the finished product; and acts as a nice transition filler where the holes are in the panels on the front seat stands (see original picture of the backside of one of the panels).
I also used the same cloth material for the headliner above the front seats and have new baltic birch panels and ebony wood stain to keep the natural wood look on the ceiling in the back of the bus. _________________ The best things in life aren't things... |
Dead 1 Samba Member
Joined: October 31, 2005 Posts: 1374 Location: Burning shores of Lake Michigan
Posted: Fri Dec 22, 2006 8:48 am Post subject: |
| themarshotel7 wrote: |
I got mine here. http://www.badgerwood.com/products.html#Plywood _________________ "I reject your reality and replace it with my own"
"The American Dream - true enough because you gotta be asleep to believe it"
71, 1776 cc. |
suzygrnburg Samba Member
Joined: February 23, 2005 Posts: 264 Location: Teaticket MA
Posted: Tue Dec 26, 2006 4:19 pm Post subject: |
can anyone hook me up with a copy of a tracing of the kicker panels? I don't have any to go off of and I don't know any bay owners around here. _________________ Without Love in the Dream It Will Never Come True! |
Posted: Thu Dec 28, 2006 7:44 am Post subject: |
I'll have mine out over the weekend and can trace the outline _________________ -Russ
'77 Westphalia
'68 Standard |
