sledge4.2 Samba Member
Posted: Mon Jun 22, 2020 6:39 pm Post subject: Help from the forum on '67 Convertible |
Hello all, I am a car enthusiast and decent mechanic, and am very active on similar boards for the various cars I own, but i know nothing whatsoever about old VW's. I posted on another forum
what do you all think of this car? Obviously I would do a PPI, but curious if any experts on this board know the car, or can comment on its presentation?
https://www.oldbug.com/histeve67.htm
Thank you all,
Geno |
Jos.Hall Samba Member
Joined: January 29, 2011 Posts: 348 Location: Sunny So Cal.
Posted: Mon Jun 22, 2020 7:01 pm Post subject: Re: Help from the forum |
Geno, Randy Carlson who runs Oldbug.com is known for being pretty thorough in the cars he consigns. This convertible seems to be no exception
Having looked at the photos I see some definite replacement items but nothing major that is very concerning. The biggest expense would be finding the correct original bumpers in the same condition as the rest of the car. Both front and rear are incorrect and would probably run over a grand to have replaced with correct one year only '67 units.
The only other thing I'd look into is if the engine matches the chassis. Yes it is a correct HO engine block but is it the one that left the factory with that chassis?
I have a '67 convertible and there's no way that you can build a '67 vert this nice for the price. Most of the major issues (Like the convertible top) and chassis are well sorted.
Good luck and hopefully welcome to the '67 club.
jos _________________ PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
https://vintagejalopy.com/67bugregistry/vwbugregistry1967_view.php
'67 L41 Sedan 117333192
'67 L41 Vert 157343589
'67 L19K Vert 157452166
'67 L19K Vert ??????
'67 L282 Vert 157419653
'67 L620 Sedan 117534350 (Sold)
'67 L54 Vert 15745800 (Parted out)
'52 Split based Devin |
Posted: Mon Jun 22, 2020 7:15 pm Post subject: Re: Help from the forum |
Just in the photos I see the following items... None of which would keep me away from the car. They're just the difference between concourse and show condition.
I really like this car and I think it's a great price for what it is. Look at the Hagerty price guid on '67 convertibles and I think you'll agree. There are a lot more correct items on this car than incorrect but heres what I see right off the bat.
1. As stated, the blue coil is a common replacement coil. It should be a short 12v coil (1 year only).
2. Fuel pump should be a square top Piersburg. Nothing wrong with this one.
3. The Chick Iverson frame is a repop $30 frame. If it were real it's a $400 frame
4. Incorrect knobs for a '67 Blaupunkt radio. Not sure which model it is. It looks like a '68 Blaupunkt Manhattan. Either way it's not a big deal. It's nice that it has both AM/FM and the Long wave band.
5. The mirror although "proper shape" is a reproduction mirror as far as I can tell. It should have a lip all the way around the back side.
6. Front wheels are 11 hole (Incorrect) and the rear wheels are 10 hole '66/67 wheels.
7. Door Panels are reproduction. Not bad just not original.
8. Both Bumpers are aftermarket. They look shiny though
9. Seat belts are modern replacement seat belts. That's a plus or a minus depending on who you ask. _________________ PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
aircooled Samba Member
Joined: December 02, 2003 Posts: 1314 Location: Heartland, Neb
Posted: Tue Jun 23, 2020 4:39 am Post subject: Re: Help from the forum on '67 Convertible |
This is an old listing, and is not currently listed on OldBug.com. _________________ 67 Sun Roof / Born Sept 66 / Second Owner
67 Convertible / Born Aug 66 / Second Owner
Member of 67 Posse
Omaha Volkswagen Club
Neb VVWCA Chapter Rep
Volkswagen Club of Nebraska |
Posted: Tue Jun 23, 2020 1:38 pm Post subject: Re: Help from the forum on '67 Convertible |
really appreciate all the responses guys - yes looks like i may have found an old listing, but interested in something exactly like this so all leads are appreciated. Thanks again guys, very much appreciated |
67conv Samba Member
Joined: July 10, 2005 Posts: 453 Location: Simi Valley, California
Posted: Thu Jun 25, 2020 7:20 am Post subject: Re: Help from the forum on '67 Convertible |
As pointed out by Jos.Hall, this is a very fine example of a 1967 convertible with a few minor details that are easily corrected. None of which are really convertible specific, but more so 1967 specific. The "1967 convertible" part of this car is actually extraordinary! The detractors (if you can consider them so) are additionally the things that make the 1967 purist crowd cringe a little in a car this nicely done. Again, nit picking the minor things -
1. incorrect generator along with that fuel pump
2. incorrect air cleaner decal
3. black running board rubbers and fender beading instead of beige for Savanna Beige paint
4. as pointed out by Jos.Hall, aftermarket door panels. Also seat covers, but done about as good as it gets for aftermarket covers. Rear seat heat seams incorrect. Absolutely NOBODY in the aftermarket seat cover world gets this detail right for a 1967 convertible!!!
5. It's the aluminum trim rings, not the actual wheels that are mis-matched in the pics of this car. Wheels should be black painted slotted, not two tone, with 10 hole bright aluminum trim rings.
1967 convertibles this nice are very rarely seen. _________________ 1967 VW Convertible, owned 35 years.
1957 DKW 3=6, owned 21 years.
PREVIOUS: 1972 "Baja Champion SE" Spec. Edition Beetle bought NEW @ Pierce VW in Denver; 1979 Super Beetle Convertible bought NEW @ Downtown LA VW; 1967 type 1 savanna beige; 1967 Porsche 2.0 911S; 1973 Porsche 2.4 911T; 1963 356 T6 B Cabriolet; 1964 356 SC sunroof coupe; 1972 Type-3 Squareback; 1968 + 1969 Type-3 Fastbacks; 1987 Vanagon GL Weekender |
finster Samba Member
Joined: May 26, 2012 Posts: 10151 Location: not far from the madding crowd
Posted: Thu Jun 25, 2020 12:39 pm Post subject: Re: Help from the forum on '67 Convertible |
sledge4.2 - if you haven't done so already it might be a good idea to scrounge a ride in a vw just to make sure it's the car for you. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
