oil problem
baja221
baja221 is offline
PostPosted: Thu Jan 18, 2007 5:26 pm    Post subject: oil problem Reply with quote
my car is smoking like crazy. i put a quart in yesterday filling it about halfway between the marks and now it is below the low line again. is a piston ring blown? any ideas?
HeadlessChicken
HeadlessChicken is offline
PostPosted: Thu Jan 18, 2007 5:31 pm    Post subject: Reply with quote
Uhhhhhhhhhhhhhhhh....................................I would have to say that you car is burning oil. Rolling Eyes Noobies Rolling Eyes
Laughing
baja5
baja5 is offline
PostPosted: Thu Jan 18, 2007 6:58 pm    Post subject: Reply with quote
Sounds like it might be rings.I'd do a compression test or even a leak down test just for kicks to see where you're at.
RealAwesomeNinja
RealAwesomeNinja is offline
PostPosted: Thu Jan 18, 2007 7:39 pm    Post subject: Reply with quote
baja5, not to be rude but do you know anything about the internal combustion engine? There is no "kicking" involved.
http://www.realultimatepower.net/
baja5
baja5 is offline
PostPosted: Thu Jan 18, 2007 7:53 pm    Post subject: Reply with quote
Just a little.If you have something important to say just spit it out.Lets see.The car is smoking,using oil. and VW's dont use valve seals.Let's hear your opinion on the subject.Yes,I know that a compression test and a leakdown test won't tell you the condition of the oil control rings,However they will give you a general idea of engine condition.If you have a better suggestion i'd be all ears.
Jamnajar
Jamnajar is offline
PostPosted: Thu Jan 18, 2007 7:59 pm    Post subject: Reply with quote
My vote would say there is a dead piston!!.......Are all of your cylinders firing? You might pull your plugs.. (look for the one covered in oil....)
subybaja
subybaja is offline
PostPosted: Thu Jan 18, 2007 8:46 pm    Post subject: Reply with quote
...and while you're pulling them, pull one wire at a time and see if there's one that doesn't make any difference. If there is, there's your problem-
-throw that wire away, and you're good!
Wink
Insanity: /ɪnˈsænɪti/ -noun: repeatedly voting for the same party and expecting different results.
Vote Libertarian
baja221
baja221 is offline
PostPosted: Fri Jan 19, 2007 4:13 pm    Post subject: Reply with quote
Laughing
^ yeah i pretty much figured that out for myself. all the cylenders are firing though but ill give pulling the wires off a shot
Jamnajar
Jamnajar is offline
PostPosted: Sat Jan 20, 2007 3:14 am    Post subject: Reply with quote
Do this while the bug is at idle....
