ksis Samba Member
Joined: May 21, 2005 Posts: 81 Location: oak harbor, washington
Posted: Wed Feb 28, 2007 2:59 pm Post subject: 215/65/15 on a 62. |
Put a set on last night. Looks pretty aggressive! Hopped it to roll home after the shop closed and hear a whinning. Looks like the tire is rubbing on the swing arm.
I did a seacrh and read the threads and everyone is running these. Could I have another unforseen issue with my car? Anyone else run into this? Thanks! _________________ 62 in the works.... |
Skim Rants Master
Joined: April 15, 2001 Posts: 17098 Location: GFK 33 Year Vet
Posted: Wed Feb 28, 2007 6:01 pm Post subject: |
Spacers shouuld fix that problem. _________________ GFK
1953 Kabriolet
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
rambler1959 Samba Member
Joined: October 23, 2006 Posts: 247 Location: east of east L.A.
Posted: Wed Feb 28, 2007 11:42 pm Post subject: |
| what wheels are you running? the 215-65's dont rub at all on my 66. (i can get my ringfinger between the sidewall and springplate) spacers should solve it. |
hpw Samba Member
ksis Samba Member
Posted: Thu Mar 01, 2007 11:31 am Post subject: |
Stock Steelies.... I went back last night and had them swapped out for 205. Now there is no problem. _________________ 62 in the works.... |
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: So. Cal/Montana
Posted: Thu Mar 01, 2007 3:19 pm Post subject: |
Do any of you guys experience sidewall play in you 215/65's? I run a set on a fatchick w/rivieras. At freeway speeds I seem to feel the rear being a little loose. As in side ways wiggles. I can actually see the wheel move from side to side in the tire when I push on the car. Is this normal when this tire is put on a 5.5 rim?
_________________ Old rides...
1959 Ragtop Beetle
1958 Danish Beetle
1967 SO-42 Westfalia Tintop
1961 Sunroof Beetle
1969 Sunroof Beetle |
Behemoth Samba Member
Joined: September 02, 2003 Posts: 389 Location: Lenoir NC
Posted: Fri Mar 02, 2007 12:23 am Post subject: |
| industryvw wrote: |
In the reviews for the tires I just bought some users said they experienced this, especially in lateral use, and that over inflating to the point of tjis going away solved the problem and had no adverse effect on use or wear. The normal overinflating seemed to be below 10 lbs. most of the time. _________________ 63SunNotch...."Don't qoute me on it but I am pretty good when it comes to tits.
Been sucking on them since I was a baby. "
vdubmax..."I thought we were friends. I will be by to drop off your recently fucked up parts next weekend fool" |
Posted: Fri Mar 02, 2007 2:50 pm Post subject: |
| hpw wrote: |
| rambler1959 wrote: |
And what would that be, beetle, ghia, bus?
What kinda of rims? |
sorry for not including that info. 66 beetle with 5.5" chrome porsche (wide 5) wheels |
