henrym Samba Member
Joined: August 19, 2006 Posts: 1010 Location: Marina Del Rey, California
Posted: Wed Feb 28, 2007 7:34 pm Post subject: Need Basic Tire Size/Brand Advice |
I will be purchasing a set of Flat-4 five lugs for 67 bug. It has a 2" narrowed beam with dropped spindles so not drastically lowered.
I have some ideas about what size tires to run but wanted your opinions. I think what they call "145's" would seem correct for the front? (I dont know much about tires so I apologize in advance....)
For the rear, I am not sure what to run. Its just a mildly modified bug. I would like it to have a nice looking wider tire but nothing over the top.
I would be very grateful for any size and brands you may recommend. Also do I need to run tubes on the 145's?
Thanks as always _________________ 1967 Bug (Second owner) |
Neil Davies Samba Member
Joined: July 31, 2005 Posts: 393 Location: Kidderminster, West Midlands, UK
Posted: Thu Mar 01, 2007 11:58 am Post subject: |
145s will be perfect for the front of your '67, as long as you get 145R15 and not 145/65R15 (Smart Car tyres). They look garbage in my opinion, and ruin the look of many a good car.
You won't need to run tubes on Flat 4 wheels as far as I know, but check with your tyre shop.
On the back I'd run something like a 185 or 195, in around a 65 or 70 profile. It'll give you a decent rake.
The first number (145, 195 etc) is the width of the trad in mm.
The second number (65, 70 etc) is the height of the tyre in % of the tread width. So a 145/65 will not be as tall as a 195/65. A tyre without the profile number is a standard tyre, and I seem to remember that it's around an 82 profile if worked out! _________________ '67/'68 Cal Look Beetle, 2007cc, 48IDFs, 14.4 @ 93mph, Oct 2017.
'68/'70 Karmann Beetle, wife's project, progressing slowly.
'80 Devon Moonraker, wife's ratty but cool toy.
'86 Scirocco special project - still measuring up... |
nevadajh Samba Member
Joined: November 05, 2004 Posts: 407 Location: Dayton, Nevada
Posted: Thu Mar 01, 2007 12:35 pm Post subject: |
If you have 145s in the front then I would go 205/65/15s for the rear. _________________ JACKSON HARDY |
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: So. Cal/Montana
Posted: Thu Mar 01, 2007 3:59 pm Post subject: |
| nevadajh wrote: |
| If you have 145s in the front then I would go 205/65/15s for the rear. |
Exactly what I was going to say. _________________ Old rides...
1959 Ragtop Beetle
1958 Danish Beetle
1967 SO-42 Westfalia Tintop
1961 Sunroof Beetle
1969 Sunroof Beetle |
JDGas Samba Member
Posted: Thu Mar 01, 2007 4:03 pm Post subject: |
For a visual. Here is my '59 with a -2" beam, NO drop spindles, adjusted all the was down it the front, and stock rear. I am running 145's in the front and 205/70R15 in the rear.
1959 Ragtop Beetle
1958 Danish Beetle
1961 Sunroof Beetle
