van wouldn't turn over, buzzing sound, then it did
Blix
Blix is offline
PostPosted: Tue Jun 07, 2011 1:48 pm    Post subject: van wouldn't turn over, buzzing sound, then it did Reply with quote
Hey all, I just took the van on about a 1600 mile road trip. The van ran great except for two incidents. After driving for about 400 miles straight I stopped to gas up, turned the van off to gas, then when getting back in it wouldn't turn over at all. Battery was fine, and it was almost making some kind of buzzing sound in the engine bay but no cranking. I fiddled around with things for a bit with no luck, then all of a sudden it crunk up no problems. Drove it for another 800 miles with no problems on shut off and cranking back up. Then all of a sudden it did it again. This time it sat for about 2 hours, I tried cranking probably 40 times then all of a sudden it crunk up and had no problems the rest of the trip. Any ideas on how to start tracking down the problem? Thanks!
When I say whas up, you know where I'm from.
84 Westy
Blix
Blix is offline
PostPosted: Tue Jun 07, 2011 7:17 pm    Post subject: Reply with quote
So I think this is the "hot start" problem that some people install a relay to bandage up. Is it ok to just drive the fan and let it cool when it won't hot start or should this be fixed to ensure the starter will last?
84 Westy
debbiej
debbiej is offline
PostPosted: Tue Jun 07, 2011 9:50 pm    Post subject: Reply with quote
my fuel pump makes a buzzing sound. could be that. does it make the sound when you turn the key, even if it starts?
Wildthings
Wildthings is offline
PostPosted: Wed Jun 08, 2011 4:09 am    Post subject: Reply with quote
crunk (krʌnk) —n. a form of hip-hop music originating in the southern states of the US
shenan-agon
shenan-agon is offline
PostPosted: Wed Jun 08, 2011 10:20 am    Post subject: Reply with quote
I love the use of "crunk" as the past tense for "crank". I'm going to steal that.
Anyway, it sounds like it could be an issue with your starter solenoid sticking when it's hot. If it happens again, try having someone crank the engine while you smack the starter with a hammer, stick, large shoe, or whatever you can find lying around.
Blix
Blix is offline
PostPosted: Wed Jun 08, 2011 11:05 am    Post subject: Reply with quote
sounds good, just have to locate the starter.....is it kinda under and back from the ac compressor? if anyone has a photo of the engine bay with the starter pointed out that would help lots, thanks
84 Westy
SCM
SCM is offline
PostPosted: Wed Jun 08, 2011 1:10 pm    Post subject: Reply with quote
It's under the van - on the passenger side and toward the top of the transaxle. I'm not certain but you might be able to reach it from the engine bay, way up in front and on the right side of the motor/bellhousing.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
