Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Wed Jan 12, 2022 4:52 am Post subject: Re: Body Repair Panels? FAQ |
this is on my list when i get a couple days off shortly. will post some pics when I get to it. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
Posted: Mon Jan 31, 2022 12:11 pm Post subject: Re: Body Repair Panels? FAQ |
Quote: |
Nice job. Did you have much trouble getting the inner section to close up tight to both the outer section and the B pillar closing panel? Both mine look like they need 10mm of metal added to the inner dogleg to meet the B pillar |
was able to just hammer closed the gap areas between the outer skin and against the b-pillar. i waited till the whole thing was welded in place as to not shift or move it with some block and hammer blows. the new material reformed quite easily and then I welded it up.
i hated to drill through my new panel but wanted to use the clecos to keep the panel tight for welding. it is welded up and the holes have been welded up too. after grinding weld snot on the inner-side, threw some all metal on there for cosmetic reasons. just in case someone wants to put there head underneath and look. you know someone will someday. i know i look at shit like that and judge. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
challomoner Samba Member
Joined: October 13, 2010 Posts: 1226 Location: IRELAND
Posted: Mon Jan 31, 2022 2:56 pm Post subject: Re: Body Repair Panels? FAQ |
Good job closing the inner to the outer, mine twists in all sorts of ways if I try squeeze it closed. I made the decision to cut a section out and remake it to fit well before I fit them to the truck.
Also noticed the curvature doesn't match the nos b pillar I have so that needs correcting too. |
