Brosol H30/31 Throttle Return Spring
magnus0328
magnus0328 is offline
PostPosted: Tue Mar 20, 2007 8:53 am    Post subject: Brosol H30/31 Throttle Return Spring Reply with quote
Good AM,
I have a H30/31 carb with a throttle return spring that has just a little more tension then the stock spring. This was done so that the throttle arm goes back onto the throttle cam with no hesitance or issues (so that it idles right). Will this tension damage the carb in any way from being a little tighter. thanks
cochinito77
cochinito77 is offline
PostPosted: Tue Mar 20, 2007 9:05 am    Post subject: Reply with quote
it shouldnt i did that on many of my aircooled engines, no problem noted?!!
magnus0328
PostPosted: Tue Mar 20, 2007 9:08 am    Post subject: Reply with quote
thx alot
