195/50/15's on a 4.5"?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Twiggy
Twiggy is offline
PostPosted: Mon Mar 19, 2007 9:22 pm    Post subject: 195/50/15's on a 4.5"? Reply with quote
anyone running this size on that width? Will they fit?
buggpower
buggpower is offline
PostPosted: Mon Mar 19, 2007 11:50 pm    Post subject: Reply with quote
195/50's are same width as a 195/60 except taller. I have 195/60's on my car right now with 4.5" wide rims. I personally dont like it because they balloon out but not really bad, but since 195/50's are shorter you might not have a big balloon look like i have.
1972 Standard Beetle
Bite My Shiny Metal A$$ (quoted by Bender)
click the cool link haha!
http://img.photobucket.com/albums/v600/bigguy/avatars/150_tits1.gif
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Tue Mar 20, 2007 3:16 am    Post subject: Reply with quote
same here - running 195/60's on stock 4.5 steelies with no problems...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Bryan67
Bryan67 is offline
PostPosted: Tue Mar 20, 2007 6:38 am    Post subject: Reply with quote
Not true. 195/50`s are actually wider than a 195/60. Measure them sometime.
If you`re going to do something, do it right.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Mar 20, 2007 6:42 am    Post subject: Reply with quote
Tires do not measure exactly what the size is, but generally a 195 is a 195 is a 195. So a 195/50-15 is the same width as a 195/60-16 and a 195/50-14.
I have 195/60-15 on 5.5" wide wheels and think a 4.5" is a bit narrow.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bryan67
Bryan67 is offline
PostPosted: Tue Mar 20, 2007 6:50 am    Post subject: Reply with quote
Hers an example
http://www.tirerack.com/tires/Spec.jsp?make=Yokoha...mp;place=8
Erik G
Erik G is offline
PostPosted: Tue Mar 20, 2007 9:06 am    Post subject: Reply with quote
195/50 on a 4.5 looks terrible.
vwfye
vwfye is offline
PostPosted: Tue Mar 20, 2007 10:05 am    Post subject: Reply with quote
you will wonder why your car feels 'squishy' inthe turns. also, you actually have a greater chance of rolling the bead of the tire off of the rim in a hard defensive/evasive turn. read that as 'very bad'.
64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK"
Twiggy
Twiggy is offline
PostPosted: Tue Mar 20, 2007 12:05 pm    Post subject: Reply with quote
yeah I did a little more reseach after I posted this and found out they'll have the "baked bread" look.
Also that size might be a bit to low and throw off my gearing too much in my bug.
Bryan67
Bryan67 is offline
PostPosted: Tue Mar 20, 2007 4:57 pm    Post subject: Reply with quote
You can run a 185/55 or 175/55 with no problem though. Or even a 185/60.
clarkbre
clarkbre is offline
PostPosted: Tue Mar 20, 2007 6:05 pm    Post subject: Reply with quote
I run 175/65/15's on the front of my bug. They're 24" tall, a little wider than stock and have a fairly wide footprint on them. They ride really nice too.
ivsamhell
ivsamhell is offline
PostPosted: Tue Mar 20, 2007 8:02 pm    Post subject: Reply with quote
i used to run 195/50 up front, slammed and narrowed 4" on stock wheels.
i like the look and the handling. just bought some 145/65s to try out.
Skim
Rants Master
Skim is offline
PostPosted: Wed Mar 21, 2007 11:45 pm    Post subject: Reply with quote
Before they started coming out with the smaller width low profiles, I ran them on 4.5 fuchs, I didnt care for the look but thats all they had at the time.
Notice how the 195x50 bubbled out on the side wall...
Personally nowadays I like the 165x45 on a 4.5. Its like a match made in heaven. Plus they are cheaper than 195x50's
GFK
1953 Kabriolet
1959 Lowlight Ghia vert
Stevepi
Stevepi is offline
PostPosted: Thu Mar 29, 2007 10:55 am    Post subject: Reply with quote
I have in my possession a 185/55 and 195/65 and the 185s are wider than the 195s.
In fact when I measure them the 185 measures close to 195 and the 195 measures 185.
These are dirt cheap tyres made in china.
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Thu Mar 29, 2007 5:28 pm    Post subject: Reply with quote
Do you mean on a bus, or on sedans as well?
Looking for aluminum single port Kadron manifolds.
Skim
Rants Master
Skim is offline
PostPosted: Fri Mar 30, 2007 3:43 am    Post subject: Reply with quote
Honestly I dont like how they look on sedans, If a bug is not super low it will show a huge gap. I like 135's because its the traditional front tire on a bug but I would never, ever put them on a bus.
GFK
1953 Kabriolet
blankmange
Type 3 Darksider
PostPosted: Sat Mar 31, 2007 4:31 am    Post subject: Reply with quote
that may be the reason right there....
póg mo thóin
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
