gas gauge not reading more than half
Freshmaker
Freshmaker is offline
PostPosted: Mon Jul 21, 2003 7:03 pm    Post subject: gas gauge not reading more than half Reply with quote
I have a problem with my fuel gauge not reading more than half a tank even after I fill up. Is this a grounding issue?
75F.I.Superbtle
75F.I.Superbtle is offline
PostPosted: Mon Jul 21, 2003 7:14 pm    Post subject: gas gauge not reading more than half Reply with quote
It is most likely the fuel gauge "vibrator". The "vibrator" is a small shiny metal or black plastic box that is bolted to the back of the fuel gauge. These can go out over time causing the gauge to not read full. They are about 30 bucks. RockyMountainMotorworks carries them. http://www.autopartsgiant.com might have them as well. The fuel tank sending unit might be defective or the floats inside the tank might be sticking. You might try lightly banging on the tank near the sending unit with your fist or a rubber mallet. Don't use anything metal as you don't want any sparks.
Good Luck....
[email protected]
superb72@yahoo.com is offline
PostPosted: Thu Jul 24, 2003 11:04 am    Post subject: gas gauge not reading more than half Reply with quote
best bet...clean all electrical contacts and spray them with a bit of water inhibitor...works wonders. Dirty contacts are the enemy...
