how about this for a wheel?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
sailorjerry13
sailorjerry13 is offline
PostPosted: Thu Apr 12, 2007 5:41 pm    Post subject: how about this for a wheel? Reply with quote
has anybody tried these on stock bug wheels? i'm considering some for my bug but dont wanna spend cash on something that wont work, can you send me some pix if you know of any?
TC/TeamEvil
TC/TeamEvil is offline
PostPosted: Fri Apr 13, 2007 7:29 am    Post subject: Reply with quote
They won't fit. There's that extra collar around the lug hole on the wheel which hits the cap.
sailorjerry13
PostPosted: Fri Apr 13, 2007 10:54 pm    Post subject: Reply with quote
damn it!!! im trying to look for something to use instead of the hubcaps, but have come to nothing, i dont have the $$$$ for fancy wheels, i guess i'll have to slap on the old hubcaps, thanx anyway
raul arrese
raul arrese is offline
PostPosted: Sat Apr 14, 2007 5:16 am    Post subject: Reply with quote
dont those go from the back, first the cap then the rim??
TC/TeamEvil
PostPosted: Sat Apr 14, 2007 7:00 am    Post subject: Reply with quote
Yup, they fit through from the back, but the opening in a stock wheel isn't a perfect circle, there are five little "bumps" or "ears" intruding into the opening where the metal surrounding the lug holes is reinforced with a lip.
The cap will go through the wheel just fine but not all the way, the diameter of the cone will hang up on those "ears".
Although, those in the picture seem different from the ones offered with the Ol' Skool JACKMAN wheels. There DOES seem to me a greater distance between the lug hole and the edge of the cone. You could probably enlarge the image to real size, measure the distance and see if there is enough clearance to fit the through the stock wheel . . . . maybe . . . .
Stock Steve
Stock Steve is offline
PostPosted: Sat Apr 14, 2007 8:42 am    Post subject: Reply with quote
TC, I'm guessing we're not talking about real high quality stuff here (i.e. Taiwan mfg., etc.)--what would stop someone from just threading in the lug bolts, and just "making 'em fit," via just slowly torquing down the bolts???
Stock Steve
Shoreline Antique Auto Connection
http://www.shorelineantiqueautoconnection.com/
Ich Bin Ein Facebooker: https://www.facebook.com/steve.fromsaac
Join VVWCA: http://www.vvwca.com/
Your source for old school metal tire valve caps: http://www.thesamba.com/vw/classifieds/detail.php?id=1416217
Thanks Veterans
lostinbaja
lostinbaja is offline
PostPosted: Sat Apr 14, 2007 8:51 am    Post subject: Reply with quote
I have been running them on my Baja for years. Once the wheel is torqued on, the "hub cap" will have 5 little dents from the wheel and they look like they came that way.
Jerry...
sailorjerry13
PostPosted: Sun Apr 15, 2007 3:34 pm    Post subject: Reply with quote
i'll try that bro, thanx for the info
TC/TeamEvil
PostPosted: Mon Apr 16, 2007 8:14 am    Post subject: Reply with quote
So will I ! ! ! !
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
