DINK Samba Member
Joined: February 22, 2004 Posts: 392 Location: Kid Prison
Posted: Thu May 17, 2007 7:59 pm Post subject: Does the insert in window rubber serve a purpose? |
The formerly chrome insert in all my Vanagon window rubber is old and worn out. Does it serve any purpose or is it purely cosmetic?
Thanks _________________ 66 Panel < 40,000 mi.
73 Std. Sedan
GBNF: 64 21 Window, 64 Deluxe, 73 Westy, 79 Bay, 84 GLI, 91 GL, 04 GLI, 87 Syncro Westy |
ChesterKV Samba Member
Joined: February 07, 2005 Posts: 1725 Location: El Cerrito, CA
Posted: Thu May 17, 2007 8:19 pm Post subject: |
If you remove it the rubber seals will back away towards the glass a bit since the strip is no longer filling the gap; it's more noticeable at the corners. I removed my old worn-out chrome trim and that's what happened and nothing else; the windows are still firmly held after several years. A lot of people have done this and some people have warned against it but I've never seen proof that it creates problems.
Good luck _________________ 1984 Wolfsburg 7-passenger stock sunroof
1992 Subaru Legacy EJ22 boxer motor installed.... van is now sold.... currently playing with a 1987 Toyota MR2 with 1.6 liter twin-cam motor. Better than the Subaru boxers....... I'm impressed. Well, okay, in an "apples and oranges" kind of way.  |
takitezy Samba Member
Joined: February 11, 2005 Posts: 111 Location: New Hampshire
Posted: Thu May 17, 2007 9:18 pm Post subject: |
| I also took out my chrome in an 77. The window did not seal as well. If the seals are old and cracked get new ones, and don't worry about getting the ones for the chrome they both should seal equally as well. |
DINK Samba Member
Posted: Thu May 17, 2007 9:21 pm Post subject: |
I've got a new windshield on the way. It will have a new "cal look" seal as opposed to one with the insert. I'm just waiting on a few good weather days where I can remove the old one, do some paint touch up and then have the winshield installed.
73 Std. Sedan
Posted: Thu May 17, 2007 10:17 pm Post subject: |
For the side and rear windows, vaseline helps to restore some of the elasticity in older rubber. Just apply a thick film and leave it on overnight. Just wipe it off. I'm in the S.F. Bay Area so the sun hasn't been that harsh and the rubber on the old van is in pretty good shape and still pliant. _________________ 1984 Wolfsburg 7-passenger stock sunroof
msinabottle Samba Member
Posted: Fri May 18, 2007 12:45 pm Post subject: Use Fresh Babies... |
I get very good results on all things rubber, vinyl and even hard plastic with baby oil, cheaper the better. Just use a clean rag (A perished pair of briefs is excellent) and rub it on.
If there's still some on the surface in a week, you could wipe it off, but people are always amazed at the condition of our cars, and Winston's plastic and vinyl look startlingly nice. It works just fine on the window seals, although the outer oxidized layer will come off on the rag. I do those last.
