idle '77 Fuel Injection
BusBerd
BusBerd is offline
PostPosted: Fri Apr 20, 2007 10:09 am    Post subject: idle '77 Fuel Injection Reply with quote
on a cold start my bus really struggles with a low idle (almost dying) until it warms up. I thought it may be the Aux Air Regulator, but I replaced it with a new one and I am still having problems.
My idle use to shoot up to 2000rpm when warm, but I recently set the idle at 850(+-75)rpm when the engine was fully warm, so now my idle at "cold start-up" struggles considerably, but when fully warm the idle is ok, I think.
My thoughts are to check the power coming to the AAR valve. Does that come through the double relay? should I check something on the double relay as well??
Also in my "idle" search here in the forum, someone mentioned checking the gap of the spark plugs. I have never done that to my plugs, but I have changed them a few times in the life of my bus. I always thought they were pre-gapped. do i need to gap them?
Would a vacuum leak create this low idle at a cold start that eventually creeps up?I don't know if this is related, but when I take the vacuum hose of the Distributor (SVDA) there is no change in the engine and i feel no vacuum in the hose. I tried revving the engine with the hose off and my finger over the hole in the hose, but felt very little, if any, vacuum. That doesn't seem right to me. On my '71 bus (with a 34PICT3 carb), if I do that at the distributor, the engine will die unless I cover the vacuum hose with my finger. and i can definitely feel the vacuum.
HELP! I would love to have a smooth idle from cold to warm.
"The large print giveth and the small print taketh away."
1977 Westfalia Camper Bus 2.0L Fuel Injected Engine, Manual Transmission
VWBusrepairman
VWBusrepairman is offline
PostPosted: Fri Apr 20, 2007 10:30 am    Post subject: Reply with quote
To get a warm idle, did you have to screw the idle screw all the way in? Maybe it's too far in and it's cutting off the air supply at cold throttle? This is a condition I'm noticing on my engine as well. To help, I too replaced my Aux. Air valve, but also put hose clamps on the cracked hose and filled the cracks with some sealant...
How are the 4 braided hoses on the air plenum? Maybe it's drawing in false air from some where?
BusBerd
BusBerd is offline
PostPosted: Fri Apr 20, 2007 10:32 am    Post subject: Reply with quote
I think the hoses are ok. I replaced them. But would a vacuum leak cause the idle to creep up as the engine gets warmer?
what about the no-vacuum issue at the dizzy?
VWBusrepairman
PostPosted: Fri Apr 20, 2007 11:11 am    Post subject: Reply with quote
I thought the vacuum would increase as the throttle increases...perhaps a clogged vac. line to the throttle? Pinched hose? There is no vacuum at idle, I don't believe.
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Apr 20, 2007 11:30 am    Post subject: Reply with quote
I think the bentley has a method for determining if the thermotime switch is actually working in order to tell the CSV to give you a squirt when the engine is cold.
2VWs1BMW
2VWs1BMW is offline
PostPosted: Fri Apr 20, 2007 11:36 am    Post subject: Reply with quote
also take a look at your cylinder head temp sensor. they tend to go south after a while.
when I DD'd my bus, I replaced it once a year.
- Brian -
'17 Alltrack
'99 ///M Coupe w/48k mi - Bimmerforums
'77 Westy w/156k mi
VWBusrepairman
PostPosted: Fri Apr 20, 2007 12:02 pm    Post subject: Reply with quote
The cylinder head temp sensor is critical to good engine performance, particularly during starting and warm-up.
The cold start valve can be checked by hot wiring the valve and watching the change in fuel pressure on the gage.
for the thermo-time sw. - operate starter, test light connected on the cold start valve harness should go on for several seconds and then go out if the thermo-time sw. and harness are OK. Hope this helps!
BusBerd
BusBerd is offline
PostPosted: Fri Apr 20, 2007 3:07 pm    Post subject: Reply with quote
Thanks for the help guys!
this sounds promising. I have not checked or replaced this yet. Just to be clear: this is the sensor that is screwed in (13mm nut, I think) by the #3 cylinder air intake.
I thought the cold start valve shuts off right after the bus has started. Is it invovled in the idling of the bus too?
I need to get a test light with small enough clips. Confused
2VWs1BMW
2VWs1BMW is offline
PostPosted: Fri Apr 20, 2007 4:31 pm    Post subject: Reply with quote
yes.
I think this will help you a bunch. let us know how you make out.
- Brian -
'17 Alltrack
'77 Westy w/156k mi
Randy in Maine
PostPosted: Fri Apr 20, 2007 4:49 pm    Post subject: Reply with quote
Just like riding a bull. 8 seconds is all it takes.
VWBusrepairman
PostPosted: Sat Apr 21, 2007 7:50 am    Post subject: Reply with quote
those 8 or so seconds make a huge difference as gasoline engines are less efficient when cold, so an extra "sptriz" of fuel is required and this would be similar to the choke function on a carburated engine. Likewise, the aux. air valve supplies extra air to the mixture, which increases the idle on an initial cold start. God luck.
BusBerd
BusBerd is offline
PostPosted: Sat Apr 21, 2007 2:40 pm    Post subject: Reply with quote
the idle is rough for more than just 8 seconds when starting from a cold engine.
I have ordered a temp sensor from Bus Depot, and I am going to try to find a test light with prongs tiny enough to fit on the FI harness connections so I can check the power coming to the Aux Air Regulator and the Cold Start Valve.
Randy in Maine
PostPosted: Sat Apr 21, 2007 3:10 pm    Post subject: Reply with quote
Just plunk your volt ohm meter on the wiring harness. that will tell you the voltage right now.
BusBerd
BusBerd is offline
PostPosted: Fri May 11, 2007 7:28 am    Post subject: Reply with quote
Just to wrap this thread up, I'll post the my fix of the idle.
Well, I just got my temp sensor II in the mail a few days ago.
I took out my old one and put the new one in and it idles great now. I really didn't think it was going to make a difference, but I was wrong. thankfully.
It was an easy fix.
Thanks to all for your help and insight!
Randy in Maine
PostPosted: Fri May 11, 2007 8:41 am    Post subject: Reply with quote
Suggestion: Always keep a new spare Temp Sensor II in your tool box. they are cheap to buy and have as a spare.
The old ones will also bench test "OK" when they are really "bunk".
