Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Wed May 02, 2007 10:28 pm Post subject: Tune-up and Maintenance Cheat Sheet |
Howdy.
Like many of you, I own more than one vehicle. My yearly mileage is split up amongst those vehicles, and I might go a year without performing any maintenance but an oil and/or coolant change an a particular car. With that amount of time going by between services, I find myself becoming a little foggy sometimes about he details. So, I made up a little cheat sheet for each of my cars with tune-up and maintenance data - to be kept in the vehicle or in the tool box. It's not meant to replace a shop manual - just enough to refresh my memory when I need it.
It occurred to me that others of you might enjoy having something like this, and I thought I'd offer it. So I spruced it up in my normal anal retentive fashion, and the results are below. I'll need to make a few changes. The one below is fine tuned for my particular car. The version I'd make up for general consumption would be for a stock 1600 motor.
I need a couple of pieces of information about a stock motor (as I've never really had one.) Speak up please if you know:
Recommended oil viscosity
Oil capacity
Spark Plug
Spark plug gap
If you see any glaring errors or omissions, likewise sing out.
Thanks in advance,
Spalding
Below is a lo-rez version of the .pdf layout. The flat page gets folded as shown.
[Click on the images to see them full size]
FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Wed May 02, 2007 11:14 pm Post subject: |
awesome layout, a classic Thing document that will be used in many years to come I bet.
I'm sure we'll see them included on Thing sales on ebay in no time!
One thing, if possible the carb graphic is a bit fuzzy even at 100%, can it be blown up a little more? everything else reads fine
thanks for sharing! |
wa6usa Samba Member
Posted: Wed May 02, 2007 11:24 pm Post subject: |
Very handy Readers Digest condensed version of the vitals! Would love to see the final .pdf when your done.
I use Castrol 20/50 in my engine. _________________ 1973 Thing |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Thu May 03, 2007 12:08 am Post subject: |
That would be handy, if for no other reason, to remind me which way the star adjusters for the brake shoes go. Every spring I'm under there going "OK, let's see...."
Looks good. |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu May 03, 2007 12:15 am Post subject: |
I like it! I recommend laminating it and keeping it in the glove box. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Thu May 03, 2007 12:39 am Post subject: |
Thanks for the positive comments everybody. Re: the carb diagram - it's a Weber IDF, which is what I run in my car. In the distributed version there will be a diagram of the 34pict/3.
Last edited by Captain Spalding on Thu May 03, 2007 11:31 pm; edited 1 time in total |
bciesq Samba Member
Joined: April 13, 2005 Posts: 495 Location: Orlando, FL
Posted: Thu May 03, 2007 4:39 am Post subject: |
I think Rotella 15w40 is very close to old stock 30 weight oil. That seems to be the stock engine oil of choice in the performance forum.
Personally, I always have to look up which way to turn the engine for valve adjustments. TDC for number 1 is easy, but I'm never *sure* whether to go clockwise or counter-clockwise to get to number 2 to TDC (it's counter-clockwise ... right?). Maybe just a simple statement like this: From #1 TDC, turn pulley CCW 180* to adjust #2, #3 and #4.
Thanks and great work. _________________ '73 Thing -- making 45 mph exciting again. |
ztnoo Samba Member
Posted: Thu May 03, 2007 8:15 am Post subject: |
Captain,
What you have assembled is the most condensed, concise, collection of Thing relevant service information I have seen yet.
Kudos for your efforts!!
In answer to your call for additional info I researched a bit myself this morning.
Most of this information was taken from the Thing shop manual.
Recommended oil viscosity:
See Thing Owners Manual via Samba page 33: http://www.thesamba.com/vw/archives/manuals/73thing/73thingmanual.pdf
Oil capacity:
changing quantity: 2.5 liters (5.3 US pints)
initial filling: 2.0 liters (4.25 US pints)
Spark Plug:
Bosch W 145 T1, W 175 T 1*
Beru 145/14, Beru 145/14*
Champion L 88 A
*to be used in vehicles driven at high speed for long periods in areas where the average temperature is above 77 degrees F
Spark plug gap: .024 shop manual .028 owners manual |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu May 03, 2007 11:17 am Post subject: |
Beautiful! I happen to have Weber IDF's on mine too.
What did you originally make it in? Can you send it out as a PDF or some other editable version - various stats are different on my car as I move away from stock. (Electronic ignition, no condenser, disk brakes in front, etc)
I don't think you can load arbritrary files to TheSamba, but you can to Veewiki.com. A good page for this could be: http://veewiki.com/TheThing/CheatSheet
If you need help creating or uploading, give a holler.
I just had a thought to automating it. Pick your carb, pick your brake system, pick your ignition system, spit out a cheet sheet. That would be pretty easy to do in Veewiki. |
Posted: Thu May 03, 2007 6:08 pm Post subject: |
Re: Spark plugs. Bosch changed their numbering system again, so you should include the new numbers: 7502 for the old W8AC, 7902 for the "Super Plus" version that is replacing the Super.
- Scott _________________ 1974 Thing -- under the knife
lee73 Samba Member
Joined: September 08, 2005 Posts: 30 Location: Southern California, USA
Posted: Thu May 03, 2007 6:23 pm Post subject: |
Fantastic job Capt.
Thanks |
madster Samba Member
Joined: November 01, 2006 Posts: 180 Location: Rio Grande Valley Texas
Posted: Mon Mar 04, 2024 9:35 pm Post subject: Re: Tune-up and Maintenance Cheat Sheet |
Captain Spalding wrote: |
Howdy.
Oil capacity
Spark Plug
Spark plug gap
Thanks in advance,
Spalding
_________________ 1966 BEETLE @ 1973 THING |
yel-mel Samba Member
Joined: May 07, 2015 Posts: 427 Location: Tampa Florida
Posted: Thu Mar 07, 2024 6:47 am Post subject: Re: Tune-up and Maintenance Cheat Sheet |
This is some very good work !!!! |
