Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Sun May 13, 2007 8:56 am Post subject: M Codes |
Just reading the the thread on split bus forum about m codes, reminded me that i still dont know what M18 is, it comes up as 'unidentified' on my birth cert.
Anybody got any other barndoor ones or know what M18 is?
My bus is Austrian, the only things different that it has are an orange brake light and a steering damper fitted to the front beam. _________________ 64 356 C Coupe |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10263 Location: Petaluma, CA
Posted: Sun May 13, 2007 9:48 am Post subject: Re: M Codes |
| Rusting Hulk wrote: |
My bus is Austrian, the only things different that it has are an orange brake light and a steering damper fitted to the front beam. |
My July '55 and October '55 Westies have M18 on their B.C.. Both had red brakelights and steering dampers. |
RickC Samba Member
Joined: August 04, 2001 Posts: 125 Location: Monterey County, CA
Posted: Sun May 13, 2007 6:08 pm Post subject: |
Greetings Simon & Greg.
A 1/14/54 Canadian delivery Ty23A at the shop has a B.C. with M 018 - Larger reflector in brake/indicator light. It also has a steering dampener. _________________ Rick Clark in Monterey County, CA USA
... where the surf is happening and the lightweights are standing on the beach, checkin' it out... |
Posted: Mon May 14, 2007 12:09 am Post subject: |
Hi Rick, thanks for that info, That would make sense if Gregs buses had whatever lense that meant. Is that the type of lense i have seen with the circular centre?
My bus has an orange lense which i think is correct for Austria and maybe Italy but it was just fitted with a std style lense, which may have been a replacement.
Simon _________________ 64 356 C Coupe |
Posted: Mon May 14, 2007 8:34 am Post subject: |
| RickC wrote: |
A 1/14/54 Canadian delivery Ty23A at the shop has a B.C. with M 018 - Larger reflector in brake/indicator light. It also has a steering dampener. |
Hey Rick, what book showed the meaning of M18? |
RickC Samba Member
Posted: Mon May 14, 2007 6:08 pm Post subject: |
Hi Simon... I think the brake & license light unit was replaced on this bus; the P.O. did some "custom" work on it during the cold Canadian winter nights. Coming to OCTO / classic?
Hi Greg.... It was on the B.C. from the museum, as M018. I'll try to do a scan for you, but can't get to it just yet. _________________ Rick Clark in Monterey County, CA USA
Posted: Tue May 15, 2007 4:16 am Post subject: |
Rick, No wont be at Octo/Classic but going to Camberg. Will try to get over next year maybe... this deluxe is draining my funds!
Greg any ideas on what the M18 means? _________________ 64 356 C Coupe |
Drew Ogden Samba Member
Joined: February 19, 2004 Posts: 339 Location: Miami, FL
Posted: Tue May 15, 2007 7:27 am Post subject: |
Interesting, I didn't know that later barndoors could have that circular pattern in the brakelight. 50/51 busses have a plastic lens with a circle and the shape of the lens is more rectangular with sharp edges. Sweinhagens 51 sunroof has an original one (dried up and kind of wasted) , and believe that Mark L's 51 came with one too. It can also be seen in the early literature. Took me FOREVER to find one, probably the most excited I have ever been to find a part.
I have also seen the later shape (52-55) which is more rounded with the circle and assumed that they were from some other european car. That is really cool if they are some sort of option. I've got an extra if anyone wants it, free if your bus is M-coded for it. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71944 Location: Phoenix 602
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1195 Location: San Tan Valley, Arizona
Posted: Tue May 15, 2007 2:22 pm Post subject: |
My 55 bd panel shows no special signs of anything not accounted for in the mcodes besides the sealed beams (which are also 55 only buckets). It has laminated sigla glass and mph speedo for Canada, so m018 would deffinetely make sense for the sealed beams to match the other 'non euro' import codes. It also has 083 and 086 which are unknown though. It does not have a dampner. Keep in mind the dampner is only clamp on so it *could* have been added at any time in the past on any of your BD's. Of course with that line of thinking, then it could have been removed from mine too.
Nobody knows the mcode for dampner as far as I know, do we even know for sure it could come from the factory and was not just a dealer add on post 55?
tony- Do you know what was the date of this literature? http://barndoor.dk/accessories/accessories6.htm |
Posted: Wed May 16, 2007 12:04 am Post subject: |
My bus being european wouldnt have had sealed beams, maybe they used the M code for two markets, i think there are instances of multiple uses in other codes.
Does anybody know what shock was used in the steering damper, i dont really want to use the modern replacement. I see it has a type 1 part number does this mean it it the same as a bug one, front or rear? _________________ 64 356 C Coupe |
Tonny_Larsen Samba Member
Posted: Fri May 18, 2007 5:36 am Post subject: |
| Kommercial wrote: |
Maybe there is an older one, but this one is stamped 1960.
-Tonny |
splitvws Samba Member
Posted: Thu Jan 17, 2008 3:50 pm Post subject: |
Got my birth Certificate today for my 55 deluxe and it also has M018 and is listed as cannot identifed. Also has M124 yellow headlamps and safety rear view mirror. Show it as being delivered to Paris France so it would not have had sealed beam lights either so any update on what M018 would be?
Thanks Dave |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 892 Location: Cornwall, UK
Posted: Thu Jan 17, 2008 4:29 pm Post subject: |
I got 009 and 101 listed as unkown on a 54 Samba
Thesamba archives say
009 is unkown (yellow tail lights?)
101 Mud & Snow tires and front VW badge painted red, on fire truck  |
686 bus-boy Samba Member
Posted: Fri Jan 18, 2008 1:24 am Post subject: |
i have an m009 - unknown on mine,i also came up with after searching that it appears to be a 'yellow tail-light' option.  |
Posted: Fri Jan 18, 2008 6:15 pm Post subject: |
any idea what 'yellow tail-light' means?
Aswel as standard tail-lights? or instead. i.e. different lenses?
Where the hell am i going to find THEM  |
Posted: Sat Jan 19, 2008 1:31 am Post subject: |
| 686 bus-boy wrote: |
Was your bus originally from Columbia? Maybe Gerson could shed light on what the m-code may be. _________________ 64 356 C Coupe |
nize Samba Member
Joined: June 21, 2004 Posts: 537 Location: Sweden - Cheesy town
Posted: Sat Jan 19, 2008 4:43 am Post subject: |
I used to own a 1959 with M-code 18. It also turned out as an unidentified M-code on the certificate. However it did have a VW steering column lock with a start button. It was registered as a taxi and did also have a distance / cost measuring box in the passenger area. _________________ ----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
Posted: Sat Jan 19, 2008 4:52 am Post subject: |
Was your bus originally from Columbia? Maybe Gerson could shed light on what the m-code may be. |
It was a 'gerson bus' so yeh i could ask him,he did supply me with a load of pics of when it was found,not on there then tho!  |
Posted: Sat Jan 19, 2008 12:03 pm Post subject: |
I finally received my birth certificates for the 51 and 53.
20-09301
22A, VW eight seater
25bhp, 1.1 liter
Krauss, Nuernberg/Germany
No Options
20-050246
24G VW De Luxe Micro Bus
25bhp, 1.2 liter
VW-Diffusion, Neuilly, Paris/France
M560 Sunroof
M425 Seatbelts and mounting points
M563 and M573 cannnot be indentified
Well, at least the front belts in the 53 aren't a hack, kinda cool. I assume one of the unknow M-codes is yellow headlights being from France. Anyone know about either of these two M Codes?
Whats up with the 1.1 liter vs. the 1.2 liter on the two busses?
Nice to see the "eight seater" reference as well. |
