carbs for 2110
nobugJay
nobugJay is offline
PostPosted: Wed Nov 20, 2002 7:57 pm    Post subject: carbs for 2110 Reply with quote
Could someone tell me if a 2110cc motor is too much for Dell 40 DRLAs. I already have the carbs, so it would save some money to go toward building the engine.
Thanks
Jay
Erik G
Erik G is offline
PostPosted: Thu Nov 21, 2002 1:32 pm    Post subject: carbs for 2110 Reply with quote
not really too much engine, I think the dells flow better than the webber's anyways, I have heard people say Dell 40s' flow like weber 44's, but I have never tried a back to back comparison.
It's not like it won't work, maybe a liitle less top end though.
[email protected]
psimitar@yahoo.co.uk is offline
PostPosted: Fri Nov 22, 2002 7:26 am    Post subject: carbs for 2110 Reply with quote
you could also knife edge the throttle butterflys and innner venturi support arms.
it's an old trick from the race track.just means that carb will flow a bit more.
if u really go to town on a carb then you end up cutting the front side of the throttle butterfly spindle away and the solid inner venturi support arm and make everything as smooth as poss.
of course these mods will work best at higher RPM's.
WideRidezzz
WideRidezzz is offline
PostPosted: Fri Nov 22, 2002 10:22 am    Post subject: carbs for 2110 Reply with quote
I was steered into Webbers when rebuilding my other VW engine. The mechanic's concern was parts availablity for Dells. It was his notion Dell'orto (sp?) was out of business.
True or false?
Is there a primer anywhere with that butterfly modification illustrated, etc?
Erik G
Erik G is offline
PostPosted: Fri Nov 22, 2002 11:54 am    Post subject: carbs for 2110 Reply with quote
you can still get Dell parts, CB sells parts, a bunch of other places. A lot of parts from the Weber IDF line work as well
[email protected]
farleytom@webtv.net is offline
PostPosted: Sat Nov 23, 2002 7:30 am    Post subject: carbs for 2110 Reply with quote
40 mm dells have main ventures that you can change (as well as the 36-45@ 48s). The 40s come with a smaller venturie 32or34s . You can go up to 38mm which is BIG. You would have to go bigger on your main jets @ air correction jets.CB Perf.has all the carb.parts you'll ever need. They also have a book with the formulas you'd need for jeting ect. Forget about feathering your butterflies, unless it's a drag car @ you want every ounce of power. That would only help wide open.
[email protected]
PostPosted: Sat Nov 23, 2002 9:47 am    Post subject: carbs for 2110 Reply with quote
will try and rack my brains for who did those carb mods.
farley is kinda right about the butterfly but the venturi mod helps flow thro the whole rev range.
will let u know when i think of his name.
