Steelz21 Samba Member
Joined: January 09, 2017 Posts: 130 Location: Ontario canada
Posted: Mon Oct 19, 2020 4:11 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
I did the opposite and matched the wheels to the interior then added stainless beauty rings. |
chris fryer Samba Member
Joined: November 12, 2017 Posts: 82 Location: Australia
DaveVHS Samba Member
Joined: September 27, 2020 Posts: 34 Location: Brisbane QLD
Posted: Tue Dec 01, 2020 5:41 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
EMPI 914 15x5 Rims with 185/55 tyres
about to install 4" narrowed beam and drop this approx. 80-90mm
kent70ghia Samba Member
Joined: June 15, 2020 Posts: 176 Location: Tacoma, WA
Posted: Fri Jan 29, 2021 9:47 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
Has anyone shaved the rear face of an EMPI Riviera? Due to a bad repair on the drivers rear fender, it rubs on corners, and a body shop said can't roll or pull the fender, too much bondo. Just curios how much can be taken off. I have a 70 coupe with stock IRS. |
Burman Samba Member
Posted: Sat Jan 30, 2021 4:53 am Post subject: Re: What Rims Do You Have On Your Ghia? |
Will be running 14 inch Fuchs on the 71.
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Sat Jan 30, 2021 6:18 am Post subject: Re: What Rims Do You Have On Your Ghia? |
Burman wrote: |
Will be running 14 inch Fuchs on the 71. |
Beautiful. Looking forward to seeing the end result. IMHO nothing beats a red '71 Karmann Ghia cabriolet on Fuchs
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sat Jan 30, 2021 8:48 am Post subject: Re: What Rims Do You Have On Your Ghia? |
A little biased there Charlie???? I hate red cars, but you are right, the Ghia convertible does look good in red though. Especially yours!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
c21darrel Samba Member
Posted: Sat Jan 30, 2021 11:19 am Post subject: Re: What Rims Do You Have On Your Ghia? |
c21darrel wrote: |
kent70ghia wrote: |
You may want to try asking in the Wheel/tire forum. I wouldnt shave on an expensive part until i had some guidance that it was an acceptable fix. Safety first. |
Thanks, just did that. Was told by the place I bought them, I should be able to take 3/16 off with no issues, but thought I would see if anyone else has done it. There are quite a few posts in other forums where they are asking about taking 10 - 15 mm off of other wheels. That scares me! |
scottandhis68 Samba Member
Posted: Fri Nov 26, 2021 11:59 am Post subject: Re: What Rims Do You Have On Your Ghia? |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1138 Location: Melbourne Australia
Posted: Fri Nov 26, 2021 3:31 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
They look sharp. 17"?
what width and offset on the back? |
Posted: Sun Nov 28, 2021 6:09 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
Ian Godfrey wrote: |
15 inch diameter x 5 inches wide - backspacing: 3-5/8 inch on the rear.
4.5 inch on the front.
Rears are super tight but minimal rub. |
Posted: Sun Nov 28, 2021 6:48 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
Scott, thanks for that, great looking car |
DariuszPlich Samba Member
Posted: Tue Nov 30, 2021 2:30 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Tue Nov 30, 2021 3:47 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
Love the look but what I really want to know is:
what color is that? (The body not the roof )
Solid or metallic?
Single-stage or BC/CC?
Emil _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Tue Nov 30, 2021 5:13 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
Evil_Fiz wrote: |
Solid or metallic?
Emil |
Hi Emil,
Thank you. It is a respray of the original color which is called Regatta Blue.
Single Stage solid acrylic enamel.
-Scott |
Posted: Fri Dec 31, 2021 3:00 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
What a great picture, and a beautiful Ghia. |
overboost Samba Member
Joined: June 11, 2021 Posts: 178 Location: Huntersville, NC
Posted: Sat Jan 01, 2022 2:11 pm Post subject: Re: What Rims Do You Have On Your Ghia? |
Fuchs 2L alloys on Michelin XZX 165 and 145
_________________ The older I get... The faster I was... |
metz Samba Member
Posted: Fri May 27, 2022 6:51 am Post subject: Re: What Rims Do You Have On Your Ghia? |
Wasn't the easy way to go, but happy to have finished up wheels and tires. Custom Appliance Pacers, 5" in the front with 135/80 and 6" in the back with 185/70. Narrowed front beam and all four fender lips rolled.
_________________ 68 panel
64 ghia coupe |
kingkarmann Samba Member
Posted: Fri May 27, 2022 7:35 am Post subject: Re: What Rims Do You Have On Your Ghia? |
metz wrote: |
I really, really like the way those look! _________________ "Depression is a malfunction of the instrument we use to determine reality.
Mike Gerson
What is your "Bespoke Reality"? |
