OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2176 Location: Portland, OR
Posted: Tue Jul 03, 2007 9:27 am Post subject: 67 Only Battery Tray |
I searched but came up empty.
I would like to see a picture of a stock 67 battery tray with the strap and everything. I just bought an nos battery tray, but I have no idea how the battery straps down. When I replace it, I want it to look factory.
Thanks! _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Tue Jul 03, 2007 1:14 pm Post subject: |
There are no straps. A 67 clamps the battery from the base. On the back side there is an L-shaped clip, fixed in place like what you would see on a late bug pan. On the front side there is a removable galvanized clamp with a bolt going downward through it to clamp the battery in place. The bolt threads into a weldnut mounted to the underside of the tray. Come on by this week and check out the original tray and clamp in my 67 if you would like to take exact measurements. I think you have my number. I'll be on vacation until the 14  |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19925 Location: Land of Whine and Phonies
Posted: Tue Jul 03, 2007 1:36 pm Post subject: |
| Major Woody wrote: |
| On the front side there is a removable galvanized clamp with a bolt going downward through it to clamp the battery in place. The bolt threads into a weldnut mounted to the underside of the tray. o |
Similar to a bay window bus _________________ Your Vanagon sucks, Stop waving at me.
| HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Tue Jul 03, 2007 2:24 pm Post subject: |
| crofty wrote: |
Similar to a bay window bus |
Damn, I'm proud to say I wouldn't know.  |
Posted: Tue Jul 03, 2007 7:35 pm Post subject: |
| crofty wrote: |
You need to get your "'67 only" learn on then partner! _________________ Your Vanagon sucks, Stop waving at me.
Jerry J Samba Member
Joined: June 12, 2004 Posts: 1257 Location: Portland, OR
Posted: Wed Jul 04, 2007 10:19 am Post subject: |
A photo would be really cool. My bus has remenants of a battery tray and fitted sheet of plywood. I'm waiting for the day when I see my battery go bouncing down the highway.  _________________ Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab |
Posted: Wed Jul 04, 2007 11:15 am Post subject: |
| Jerry J wrote: |
A photo would be really cool. My bus has remenants of a battery tray and fitted sheet of plywood. I'm waiting for the day when I see my battery go bouncing down the highway.  |
Posted: Wed Jul 04, 2007 1:45 pm Post subject: |
| crofty wrote: |
| Jerry J wrote: |
Thank you...that will work. I looked on the Failsure sited but couldn't find anything like this. I musta not looked hard enough.
Brian, where did you find that battery tray? I've never seen an NOS or any '67 specific trays advertised here on TheSamba. _________________ Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab |
Posted: Wed Jul 04, 2007 1:57 pm Post subject: |
One other thing about a 67 is the vertical piece at the forward edge of the tray where the tray meets the rear edge of the wheelwell. I presume that the intended purpose of the piece is to keep the battery from sliding forward, but what it really does is trap dust and crap that comes in the vents, where it accumulates, gets wet and rusts out. I had to patch mine. Here is a photo of the tray area of my bus. The clamp is not on because I am having it hot dip galvanized. I can take another one with the battery out if necessary.
The battery strap is just sitting there as the bus is apart at the current time.
And yes Dave, all my hardware is original Kamax, re-plated!
Posted: Wed Jul 04, 2007 2:02 pm Post subject: |
What's the yellow wire for? _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Jul 04, 2007 2:08 pm Post subject: |
| crofty wrote: |
What's the yellow wire for? |
Alarm trigger. Pinswitch is mounted underneath the hatch seal so the switch opens when the seal is compressed by the decklid. From that angle you can see it if you know what to look for. I do have a locking handle as well. |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5928 Location: back to living where hell meets the suface
Posted: Wed Jul 04, 2007 2:25 pm Post subject: |
| Jerry J wrote: |
| crofty wrote: |
| Jerry J wrote: |
Brian, where did you find that battery tray? I've never seen an NOS or any '67 specific trays advertised here on TheSamba. |
Kassic Fab make 67 only trays. I have a couple coming on my next shippment. _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15501 Location: Casa de Oro, California
Posted: Wed Jul 04, 2007 3:33 pm Post subject: |
Ronnie I'll probably be getting one for the wrecked '67 Westy. Here's a shot of the '67s battery area. It's been coated with epoxy and red oxide primer a couple times to stop the acid.
Here's the battery bracket.
Here's the battery holddown. Notice the bolt has a self cutting tip. It's missing a washer I think.
EverettB  Administrator
Joined: April 11, 2000 Posts: 71992 Location: Phoenix 602
Posted: Wed Jul 04, 2007 8:18 pm Post subject: |
| splitpile wrote: |
| Jerry J wrote: |
| crofty wrote: |
| Jerry J wrote: |
Kassic Fab make 67 only trays. I have a couple coming on my next shippment. |
Ronnie, do you have prices for the tray? Does it come with the part "82" from the drawing?
I also need to get prices on a passenger side rocker which would include the outer, the inner-inner and the inner rocker for my '67, please. _________________ Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab |
Posted: Wed Jul 04, 2007 8:26 pm Post subject: |
| Jerry J wrote: |
I also need to get prices on a passenger side rocker which would include the outer, the inner-inner and the inner rocker for my '67, please. |
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111701433
I thought the rockers were $85 at BOR, but I may be wrong. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Jul 04, 2007 10:58 pm Post subject: |
| Jerry J wrote: |
| splitpile wrote: |
| Jerry J wrote: |
| crofty wrote: |
| Jerry J wrote: |
I am curently on my 1st family Vacation in 15 years (closed till July 10th). Off the top of my head the cargo door rocker and strethener are 885 dollars, the 67 only battery tray I believe between 80 and 90. It does nnot come with the clamp but that is a very common item and if I took a magnet in the yard behind my shop 'd probaly find some _________________ Stocking distributor of "The Funky Green Panels"
Posted: Wed Jul 04, 2007 11:30 pm Post subject: |
| splitpile wrote: |
I am curently on my 1st family Vacation in 15 years (closed till July 10th). Off the top of my head the cargo door rocker and strethener are 885 dollars, the 67 only battery tray I believe between 80 and 90. It does nnot come with the clamp but that is a very common item and if I took a magnet in the yard behind my shop 'd probaly find some |
Holy f'n mark-ups Batman!!  _________________ Your Vanagon sucks, Stop waving at me.
Metalwizard Samba Member
Joined: October 21, 2003 Posts: 696 Location: Archdale, NC
Posted: Thu Jul 05, 2007 6:36 am Post subject: |
Here you go, i think its runs from mid 66 -67. as i have did a couple 66 with this style tray.
battery tray $85.00, I have 1 in stock.
also the rocker cost is
outer and strengther $85.00
outer, strenghter, inner rocker $120.00 that $5.00 discount by buying all 3 pcs at once. _________________ http://s461.photobucket.com/albums/qq335/Metalwizard/
Kelly aka
"Bubble & Nut Buster for wannabe BadBoy's of Restoration"
"There is no cure for Stupid"
ITMC "Drill SGT"
Posted: Thu Jul 05, 2007 6:37 am Post subject: |
LOL, don't have a cornary Crofty. Ronnie had a miss type. ROFLMAO _________________ http://s461.photobucket.com/albums/qq335/Metalwizard/
Kelly aka
ITMC "Drill SGT" |
