Zwitter?
Page: 1, 2, 3, 4, 5  Next
57veedub
57veedub is offline
PostPosted: Tue Jul 03, 2007 5:33 pm    Post subject: Zwitter? Reply with quote
so im curious other then the obvious (oval dash with split rear window) whats special about a zwitter and whats the story behind them?
why didint vw make more zwitters?
1957 oval ragtop baja
thebucket
Samba Stockbroker
thebucket is offline
PostPosted: Tue Jul 03, 2007 5:43 pm    Post subject: Reply with quote
They were using up old parts before the ovals went into full production. There are some small interior differences as well. Do a search I think this has been covered....... Cool
ITMC-El Presidente
OG 55 bullet 3 fold....
http://www.thesamba.com/vw/forum/viewtopic.php?t=150858&highlight=thebuckets++++fold
vwwitch
vwwitch is offline
PostPosted: Wed Jul 04, 2007 5:14 am    Post subject: zwitter Reply with quote
i have a zwitter and the differences i know of r as follows ...
there is a push button starter button on the left of the steering wheel , heart tail lights, dome light switch under the dash on the left of the steering wheel , dome light without an on off switch on it , speedo is a 6 month only speedo it has 2 separate arrows on it to indicate the signal is on , ash tray is different then an oval , there is an A/Z on the heater nob , the ignition switch is an on and off and is a zwitter only ,
as far as i can think thats all i can remember ... if i think of anything else ill post it ...
working dog
working dog is offline
PostPosted: Wed Jul 04, 2007 6:48 am    Post subject: Reply with quote
Hey vwwitch my nov 5 1953 oval has all off the parts you just mentioned not zwitter only.These parts were used mid 1952 till dec 1953. Hope this helps !
John Moxon Premium Member
John Moxon is offline
PostPosted: Wed Jul 04, 2007 8:25 am    Post subject: Re: zwitter? Reply with quote
Hope you've got your flack jacket on too...some of the split window purists will tell you you're in the wrong forum Wink
John.
vwwitch
vwwitch is offline
PostPosted: Wed Jul 04, 2007 10:22 am    Post subject: Reply with quote
did not know that about using the parts till dec 53 ... thanx for the info
Bruce
Bruce is offline
PostPosted: Wed Jul 04, 2007 10:39 am    Post subject: Reply with quote
thebucket wrote:
They were using up old parts before the ovals went into full production.....
Nope! That is a common conclusion that isn't true most of the time. When you are manufacturing as many cars per day as VW was, planning parts delivery is extremely important. There is no way VW had 4-5-6 months of inventory hanging around to use up. Besides, the only difference between a zwitter and the first ovals is the roof stamping, rear glass and rear window rubber. How many roof stampings do you think they had piled up in heaps in Oct 52 that they had to "use up"? Enough to keep production going until Mar 53?
banana split
banana split is offline
PostPosted: Wed Jul 04, 2007 12:15 pm    Post subject: Reply with quote
And remember, those Zwitter roof stampings are different than the earlier split ones if you consider where the interior light was located. The earlier splits had a big round light mounted above the "split" and Zwitters had them mounted in the same location as an oval etc. That big round hole for the early splits had to be stamped out. And yes I realize the big hole was stamped into a separate panel that was welded to the roof section.
My Beetles :
1953 Zwitter
1964 Chop Top
passoa55 Premium Member
passoa55 is offline
PostPosted: Wed Jul 04, 2007 1:05 pm    Post subject: Reply with quote
A zwitter haves also an alluminium font hood handle, same model as oval.
1950 Hebmuller #458
1952 Azure blue crotch cooler ragtop
1953 original paint oval ragtop
1955 lowlight lizard green
1955 original paint oval
1956 1600 super V-sunroof Porsche
1958 lowlight ghia black
1967 SO42 westy
1969 original paint Westy
1970 one owner 1300L bug
57veedub
57veedub is offline
PostPosted: Wed Jul 04, 2007 1:09 pm    Post subject: Reply with quote
thanks everyone for the positive answers
i always thought there was more differance other then just the roof stamp
IN2VWS
IN2VWS is offline
PostPosted: Wed Jul 04, 2007 2:24 pm    Post subject: Reply with quote
I was speaking to a nice guy in Germany in April this year. He had a Zwitter, and has owned it for over 30 years. It was a very nice example of the car.
Whether this is true or not I don't know, but he told me the reason the Zwitter was not an oval is because there was issues with the curved glass of the oval windows, so they continued with the split window until the problems with the curved glass was sorted out. But the intention was for it to be an oval from October 1952.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
25horseboxer
25horseboxer is offline
PostPosted: Wed Jul 04, 2007 3:01 pm    Post subject: Reply with quote
Also, the "split" rear window in a Zwitter has Aluminum trim. a split doesn't.
52HoffmanSplit
52HoffmanSplit is offline
PostPosted: Wed Jul 04, 2007 3:41 pm    Post subject: Reply with quote
This may have some truth to it as the reason the Split Window was originally adopted was due to the expense of curved glass in 1937/38 and the fact they were trying to get and keep the VW38 and 39's under the 1000RM price. (Split was introduced in the VW303.. and designed as usual by Erwin Komenda).....Curved rear glass would have blown the budget on the KDF-Wagen. (or... thats what they thought!!)
This is all in Chris Barber's "Birth of the Beetle"... which I think is a fascinating book... not sure what everyone else thinks of this one... it has some great pictures and quite a bit of technical background. It's more like a really COOL coffee table book.. but definitely gives some good info.
DB
11/1966 Porsche 912
7/1968 Type 265 Double Cab
4/1955 Type 117 - 3 Fold
Dave Haviland
Dave Haviland is offline
PostPosted: Wed Jul 04, 2007 4:54 pm    Post subject: Reply with quote
Do early ovals have the rectangular headlight switch like a zwitter? Same ash tray?
Dave
working dog
PostPosted: Thu Jul 05, 2007 8:29 am    Post subject: Reply with quote
Yes my 53 oval has same ash tray and rect. lite switch.
usariemen
usariemen is offline
PostPosted: Thu Jul 05, 2007 2:34 pm    Post subject: Reply with quote
Zwitter ashtrays have no handle, 53 ovals have the little chromed handle on the ashtray but not yet the later chrome frame around.
Master of my domain!
Zwitter
Zwitter is offline
PostPosted: Thu Jul 05, 2007 6:02 pm    Post subject: Zwitter Reply with quote
All the noted facts concerning the Zwitter models have been accurate!
I have been wating to see if there would be a posting by anyone in reference to the non-anodized body side mouldings, door window aluminum scraper frames, and running board trim, which match the mouldings found in the window rubbers.
I think over the years these mouldings have been replaced during "restoration", the owners liking the look of the shiny anodized trim.
It's certainly not easy to find the original trim mouldings.
bam
bam is offline
PostPosted: Fri Jul 06, 2007 5:14 pm    Post subject: Reply with quote
don't forget the antenna lump in the roof.
hi
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Jul 06, 2007 5:45 pm    Post subject: Reply with quote
A difference between a Zwitter and a '53 oval not mentioned is that the interior light has NO switch at the light......a '53 oval has a two position light switch and in '54 they got the familiar three position light switch.
vwwitch
vwwitch is offline
PostPosted: Sat Jul 07, 2007 8:40 pm    Post subject: Reply with quote
as far as i know there is no hump on the roof for an antenna ... my zwitter doesnt have it and neither does my friends ...
Page 1 of 5
