Baja Oil Cooling??
vw_sean
vw_sean is offline
PostPosted: Wed Aug 13, 2003 3:46 pm    Post subject: Baja Oil Cooling?? Reply with quote
As far as cooling, do you think I should go for the roof scoop or mounted in the back where the cowl is? And if I do go for the cowl, inside with the scoop or on the outside. I'm thinking inside, to catch air going over the car, and to keep out of the sun so the oil isn't preheated too much. But are the roof scoops worth the $100 extra bucks?
View user's profile Send private message Visit poster's website MSN Messenger Classifieds Feedback
dadbug
dadbug is offline
PostPosted: Wed Aug 13, 2003 9:55 pm    Post subject: Reply with quote
There are some good oil coolers that have fans attathed and you can add a thermostat. Just don't mount it so the engine fans draws the hot air back into the shroud. Also don't mount it so it will get damaged by rocks are other junk that might damaged or punture it. I have mounted mine on the cowl in 3 baja's I built. Good luck, Smile
"It's not a car,
It's a Volkwagen"
Jrmobb55
Jrmobb55 is offline
PostPosted: Thu Aug 14, 2003 2:01 am    Post subject: Reply with quote
the roof scoop is not needed unless u have a huge engine. just a external sitting on top of car or somwhere so the outside air hits it. just dont put in the engine area or u will be defeating the point of a external one. also the oilcool with fan is a good idea as long as fan blows away from engine.
1974 white bug, 1741 engine
vicsvw
vicsvw is offline
PostPosted: Thu Aug 14, 2003 9:05 pm    Post subject: Oil cooler add on ?? Reply with quote
I hope you are talking about adding the above coolers and not replacing the stock coolers. You must keep the oil cooler where the fan can pull air across the cooler. If you want to just use the cooler on top, just remember you will not have decent cooling when speeds go below 30 or 40 MPH. Vic www.vwhelp.com VW Parts Books with VW part numbers.
vw_sean
vw_sean is offline
PostPosted: Thu Aug 14, 2003 9:15 pm    Post subject: Reply with quote
these are add-ons as part of a full-flow system.
BigElipso
BigElipso is offline
PostPosted: Fri Aug 15, 2003 1:53 pm    Post subject: Reply with quote
I mounted mine on the cowl and added an aluminum scoop on top of it to force air thru it. Don't know how well the scoop worked but I never had any overheating problems.
