Type 4 camshaft ID
vweds57
vweds57 is offline
PostPosted: Mon Jul 23, 2007 8:54 pm    Post subject: Type 4 camshaft ID Reply with quote
I bought a new unused T-4 camshaft from a guy on ebay who said he couldn't remember much about it. It came with a new bolt on gear. There is a shop near by that can tell me the specs but is there some way to know if it is a solid lifter cam or a hydraulic lifter cam. The only # on the cam itself is EP93 with a blue dot. GEX says a yellow dot indicates hyd and Webcams says the blue dot indicates Hyd. Is there really a way to tell or did I waste my $15. Any help.
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Jul 24, 2007 6:25 am    Post subject: Reply with quote
it is an aftermarket cam, but the ep93 is on almost all aftermarket cams because pretty much everyone who makes type 4 cams uses the same blanks. look closely at the nose of the cam where the gear attaches and see if there are any stamped numbers.
SL
vweds57
vweds57 is offline
PostPosted: Tue Jul 24, 2007 10:38 am    Post subject: type 4 camshaft ID Reply with quote
I have checked and rechecked for any makings at all. The only other marks on it are the letters CWC which are between two of the lobes just as the EP93 markings are. There are no stampings of any kind on the gear end of the shaft. Thanks,
busman78
busman78 is offline
PostPosted: Tue Jul 24, 2007 11:02 am    Post subject: Reply with quote
A blue dot on an early European Motorworks camshaft indicates a stock grind solid lifter cam. The specs should determine a lot, lift, duration overlap and ramp. With all of those the application can be determined including whether the cam is for solid or hydro's. Unfortunately in the end you may never know who made the cam.
Bleyseng
Bleyseng is offline
PostPosted: Tue Jul 24, 2007 4:50 pm    Post subject: Reply with quote
its a $15 paperweight.... Wink
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
