Bret Young Samba Member
Joined: August 26, 2006 Posts: 760 Location: Turlock, CA
Posted: Mon Jul 30, 2007 10:24 pm Post subject: Suitcase stereo |
hey every1. i have been thinking about building a suitcase stereo for my car, and was wondering of those who use them, are you satisfied with them, the way they sound vs. a regular stereo? id like to hear peoples opinion. thanks.
Bret |
63type1 Samba Member
Joined: September 28, 2004 Posts: 129 Location: Portland, OR
Posted: Tue Jul 31, 2007 9:57 am Post subject: suitcase sterio |
I have thought about doing this. Someone please tell! _________________ '63 ragtop |
akokarski Samba Member
Posted: Tue Jul 31, 2007 10:47 am Post subject: |
like the whole thing in a suit case? or just a speaker in a suitcase?
Anton |
Posted: Tue Jul 31, 2007 11:14 am Post subject: |
all in 1. but i never thought about that, mount the stereo, then just attach the speakers in the case. hmm........ but i still like it all in 1. |
Posted: Tue Jul 31, 2007 11:38 am Post subject: |
i wouldn't like proximity of the speakers to the stereo due to the magnets they have. Also speakers do need volume in the enclosure. Depending on the suitcase size you will be very limited. Plus how are you going to operate the stereo unless it's sitting right next to you in the passenger seat.
If you don't wanna cut up the dash or put your head unit into the glovebox another option is to get a hide away stereo with remote which you can place anywhere you want.
http://www.online-racer.com/secretaudio.htm
Anton |
Posted: Tue Jul 31, 2007 11:49 am Post subject: suitcase sterio |
I always wanted to put speakers in a small suitcase and set it behind the back seat. Then it would just look like a suitcase and provide the extra sound but still appear stock. I never wanted a blasting whoop-dy-doo sterio setup, just something simple. I'm not sure what Mrblyoung was going for. _________________ '63 ragtop |
Posted: Tue Jul 31, 2007 11:53 am Post subject: |
im looking for the exact same thing the person above me is looking for, something moderate that works, but doesnt alter the stock look of the interior of the VW. and looks stealthy, detering theives. am i correct? |
Posted: Tue Jul 31, 2007 12:03 pm Post subject: |
if you are going to put speakers in the suitcase, build an enclosure that tightly fits inside and mount speakers to it. you will need to put some foam to prevent suitcase from rattling around the enclosure. It's a cool idea, I seen it done and if you can match speakers to the enclosure volume you have to work with it will sound fine. you can also get a vintage cooler and use it the same way. Heck get a a few purses for mids and tweeters!
Anton |
Posted: Tue Jul 31, 2007 12:06 pm Post subject: |
there is one for sale on thesamba right now, and it doesnt have foam on the inside. so you would havet o build an enclosure and put foam on the outside to make it sound good? that seems like a lot of work. you would think it would be more simple. |
Posted: Tue Jul 31, 2007 12:12 pm Post subject: |
well you should put something between the enclosure and the case. better yet just glue the whole thing together or fasten it some way. perhaps you can get Masonite panels and cut em to size. glue them to the inside the case that way you can use small screws to secure outside of the suitcase to the enclosure. Basically if it rattles, all you'll hear is a rattle and it will drive you nuts.
Anton |
youngster1966 Samba Member
Posted: Tue Jul 31, 2007 12:14 pm Post subject: |
I used a suitcase record player, already had the speaker. I detached it from the record player and rigged it to play my ipod. |
Posted: Tue Jul 31, 2007 12:30 pm Post subject: |
so akokarski, i need to build an enclosure for each speaker, then foam the rest of the inside, then seal it shut? haha. whoa. |
ScrapJunkie (O\U|U/O)
Joined: March 17, 2004 Posts: 3977 Location: Hutchinson, Kansas
Posted: Tue Jul 31, 2007 1:31 pm Post subject: |
Here's mine, it sounds decent.
_________________ (O\U|U/O) Top Vw (o\UU/o) |
Posted: Tue Jul 31, 2007 3:36 pm Post subject: |
mrblyoung wrote: |
that would be ideal. single enclosure is fine, do a divider. If suitcase is sturdy enough you might not need to. but if it's going to be a subwoofer then yeah, you will need enclosure.
Anton |
Posted: Tue Jul 31, 2007 5:26 pm Post subject: |
i wasnt really planning on running a subwoofer, cause if you think about it, not a ton of cars come stock with a subwoofer, and yeah. germanpride's one above looks nice, im not sure if i just want to stick to 6 1/2's, or run a pair of 6x9's also? |
ipodjunky Samba Member
Posted: Tue Jul 31, 2007 8:04 pm Post subject: |
I'm going to do one with a small amp and two speakers, then just run my Ipod to it and control the Ipod in the front with me. |
Hiramhaus Samba Member
Posted: Tue Jul 31, 2007 8:12 pm Post subject: |
I have been thinking about "lunchbox" with speaker out - I have two external speakers in enclosures already. _________________ 1969 Ghia
2016 Audi Q3 |
Posted: Tue Jul 31, 2007 10:58 pm Post subject: |
haha......unique. |
Posted: Tue Jul 31, 2007 11:25 pm Post subject: |
There's a connection for my Ipod through a hole in the top of the suitcase. There's a remote so I don't have to turn around to control it, or the cord for the Ipod is long enough to reach from the front seat.
I used a 4-flat trailer wiring harness so it can be taken out of the car quickly, all it needs is a constant power from the battery, a ground, and a switchable power from the ignition. I put an antenna inside the suitcase completly hidden. It works GREAT!
Oh, and I almost forgot, I still need to put the 6x9s in, as well as seperate the halves of the suitcase so I can use one side for storage for tools and spare parts. _________________ (O\U|U/O) Top Vw (o\UU/o) |
Posted: Tue Jul 31, 2007 11:48 pm Post subject: |
well germanpride, once i get all my parts, your gonna get an email, cause im gonna wanna see more pics of how you wired yours up, and have it put together. |
