DBLB Bug Samba Member
Joined: October 26, 2010 Posts: 5 Location: SAN JOSE, CA
Posted: Fri Jun 26, 2015 10:30 pm Post subject: Ghia window scraper |
I need a pair of window scrapers (rubber seal) 141 837 475B. I have a 60 Ghia with the early version. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13960 Location: Southampton U.K.
VeloMikey Samba Member
Posted: Mon Dec 28, 2015 5:59 pm Post subject: Re: [lowlight] door upper chrome |
How do you determine left of right on the chrome trim? The one on the right came with my car and the one on the left is a reconditioned OG from KGPR and is a "right" side. Do I have two rights? Both Chromes seem to line up on both doors pretty well. The OG screw holes line up on both as well.
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Mon Dec 28, 2015 8:17 pm Post subject: Re: [lowlight] door upper chrome |
To me in the pictures it appears you have a left and right, A quick look at my car in the dark shows the thinner edge goes toward the front and the thicker edge goes toward the back, the rear profile should match the quarter window chrome strip. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Tue Dec 29, 2015 9:59 am Post subject: Re: [lowlight] door upper chrome |
lonotch wrote: |
To me in the pictures it appears you have a left and right, A quick look at my car in the dark shows the thinner edge goes toward the front and the thicker edge goes toward the back, the rear profile should match the quarter window chrome strip. |
Thanks for the info! _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Disc Samba Member
Joined: September 24, 2009 Posts: 560 Location: Europe
Posted: Wed Dec 30, 2015 3:58 am Post subject: Re: [lowlight] door upper chrome |
You can recognize left or right side by looking their back side. Slots for inserting trim clips are on different (mirrored) location. Then place the trim near the door edge and examine relation between slots of the trim and the holes on the door. You'll quickly find out which is left and which right. _________________ The glory never gets old, just need new paint.
Nick |
Posted: Wed Dec 30, 2015 8:11 pm Post subject: Re: [lowlight] door upper chrome |
Disc wrote: |
You can recognize left or right side by looking their back side. Slots for inserting trim clips are on different (mirrored) location. Then place the trim near the door edge and examine relation between slots of the trim and the holes on the door. You'll quickly find out which is left and which right. |
Turns out I have two rights... Lonotch, you are right about the thin part going toward the front of the door and the rear edge lining up with the quarter window trim. Disc, early cars use screws to hold the trim on not clips. The screw head does all the work and the tension is adjusted by tightening or loosening the screws. The right and the left are identical on the back side from top to bottom. It is all in the topside profile. _________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Thu Dec 31, 2015 12:59 am Post subject: Re: [lowlight] door upper chrome |
Oh Man, Now I am going to worry until I dig that box of Chrome parts out |
c21darrel Samba Member
Posted: Thu Dec 31, 2015 1:24 pm Post subject: Re: [lowlight] door upper chrome |
I am going to use stainless steel screws to replace these. Finding the proper size and shape of the head is the difficult part. |
Posted: Fri Jan 01, 2016 12:55 am Post subject: Re: [lowlight] door upper chrome |
I got the inner channel and lower outer chrome mounted and the door trim test fitted. KGPR sells these counter sunk screws. They work great.
OMR_007 Samba Member
Posted: Fri Mar 13, 2020 5:08 am Post subject: Re: [lowlight] door upper chrome |
Can anyone confirm how many screw holes there are to hold the chrome trim to the door? My trims only have the slots for 2 screws, one middle and one toward the front. And the painters filled all the screw holes
Maybe I have late style trims for clips? |
kgj Samba Member
Joined: February 25, 2013 Posts: 418 Location: Uk, Cornwall
Posted: Fri Mar 13, 2020 1:33 pm Post subject: Re: [lowlight] door upper chrome |
Hi,
5 on mine.
Regards. _________________ 1958 coupe |
Karmann Gheezer Samba Member
Posted: Fri Mar 13, 2020 5:14 pm Post subject: Re: [lowlight] door upper chrome |
Original screws for the early Ghias. Hope this helps. _________________
Posted: Tue Mar 17, 2020 2:30 pm Post subject: Re: [lowlight] door upper chrome |
Thank you |
