zippyslug31 Samba Member
Joined: July 20, 2007 Posts: 799 Location: Central Oregon
Posted: Fri Aug 17, 2007 8:53 am Post subject: key buzzer / musical tones at start up |
Several years ago I had a friend who had (I think) an '86 westy that made a little 3-note musical song when you turned the ignition over.
Not exactly sure if it was 3 notes, but from memory it was this little "faa-Lah-LAA" sound.
Fast forward to now. My '90 westy has never done this since I've owned it. I'm assuming this is just the key buzzer since I can also have the key in the ignition with the door open and no warning sounds occur. I've looked under the dash and found a few different plugs where I think this may have lived at one time.
Call my a dork, but I'd like my van to nag me when I leave the keys in it and I'd like my dumb little "faa-Lah-LAA" sound at start up!!!!
So.... anybody know the details? Where to source one of these devices and where they go? Any pics of the location or plug number/description would be super helpful as well. _________________ previous:
'80 westy
current:
'90 syncro westy 2.5L subi, triple knob, 16" wheels.
'84 sunroof van, 2.1L motor. |
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Fri Aug 17, 2007 9:04 am Post subject: |
The relays can be had... here's a guy on eBay that has some listed: http://cgi.ebay.com/ebaymotors/CHIME-RELAY-RABBIT-...0050857829 (No financial interest, but I have bought from him and was pleased with the transaction). It shouldn't be hard to source one used either since it seems most folks want to disable this feature rather than putting it back.
The relay plugs into one of the empty sockets above the fuse block. It can be seen in this article about power the stereo from the key-in-ignition warning relay: http://images.google.com/imgres?imgurl=http://www....n%26sa%3DN
It's the relay with the little grill in the top to let that obnoxious sound out.
EDIT: Interestingly, this image collage shows it on its own socket above the other relays: http://www.biztek.com/k6acj/images/vw-collage.jpg My '88 is in the same location as the previous image I had posted. _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
Posted: Fri Aug 17, 2007 9:23 am Post subject: |
Excellent reply! Just the info I was looking for, thanks!
So am I to understand that both the door BZZZZZZZ sound and the startup tones is from the same relay? _________________ previous:
'80 westy
current:
ChesterKV Samba Member
Joined: February 07, 2005 Posts: 1725 Location: El Cerrito, CA
Posted: Fri Aug 17, 2007 9:33 am Post subject: |
| zippyslug31 wrote: |
So am I to understand that both the door BZZZZZZZ sound and the startup tones is from the same relay? |
I took mine out because it was annoying me and now I hear nothing at any time. I'm looking for an Audi chime but I haven't had the time to figure it all out.. _________________ 1984 Wolfsburg 7-passenger stock sunroof
1992 Subaru Legacy EJ22 boxer motor installed.... van is now sold.... currently playing with a 1987 Toyota MR2 with 1.6 liter twin-cam motor. Better than the Subaru boxers....... I'm impressed. Well, okay, in an "apples and oranges" kind of way.  |
Posted: Fri Aug 17, 2007 10:16 am Post subject: |
As Volksaholic posted, this ebay link above is for a "nicer" door chime. _________________ previous:
'80 westy
current:
Posted: Fri Aug 17, 2007 10:28 am Post subject: |
I had the chime version in mine but I pulled it out when I wired up the stereo to be powered by the key-in-ignition power. I like being able to leave the stereo switched on and have it shut off when I pull the key, and I don't usually leave the keys in my ignition unintentionally. Now what I'd like to figure out is how to shut the parking lights off when I leave the car... I've been trying to decide what behavior I want before I decide how to rewire things. _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
redstripe GTI Samba Member
Joined: June 17, 2007 Posts: 39 Location: Nanaimo, BC Canada
Posted: Mon Sep 03, 2007 8:11 am Post subject: |
I would love to know how to do that. I hate turning my radio on/off manually but would like it to be able to play without the engine running.
PM sent. _________________ When my time comes I want to die peacefully in my sleep, like my grandpa- not screaming like the passengers in his car.
1985 Doublecab Transporter |
Posted: Mon Sep 03, 2007 11:21 am Post subject: |
Redstripe.... from reading another post it sounds like you're part way there. In the post about disabling the Seat Belt Annoyance buzzer you say you found that buzzer/relay and removed it. I'm assuming from the pic that you've got an '85 or newer... the fuse box and relay positions change in '86.
If I'm reading things correctly, Fuse #3 powers the radio in the '86 & up Vanagon, Fuse #8 or #9 in the '83 through '85. You also need to know whether your stereo has a switched power lead and a memory lead, or just the switched power. If it's got a memory lead (for things like radio station presets) you need to make sure that lead is always hot. Any of the three fuses above should give you that constant power, and if it's the old Heidelberg radio that came in my '85 it's got what appears to be switched and memory power, but in reality if you cut the switched power you also lose the memory. I don't know if it was supposed to work that way, but in practice that's what mine did and someone here told me that was how they came from the factory.
There's a gray/black wire that runs from the SU terminal on the ignition switch to the coil for the Seat Belt Annoyance relay. Even though the relay position changed, the color of this wire didn't. When you put the key in the ignition power is applied to that wire. If your relay is already out and you have no intention of putting it back in you can simply put a male 1/4" crimp connect on a wire and plug it into this gray/black power wire. I wanted the option of putting my Annoyance Buzzer back so I pulled the female connector from the back side of the relay block, spliced in a wire, then put the connector back into the relay block. This is probably silly because I wouldn't want to be trying to listen to the stereo while the relay is chiming, but I thought I'd leave the option open. In the '85 I sold I had used the male crimp connect plugged in where the relay would go.
In either case, you could run the radio directly off that power but I'm not sure the switched connection in the ignition is designed to take much current so I'm driving the coil on another relay with that power. I opted to do this in both the '85 and '88 Vanagons. I have a constant hot power going into the relay contacts and when the key is inserted the relay closes and applies power to the stereo. The relay was about $5 at a FLAPS... originally sold for adding fog lights.
I used the relay with future expansion in mind too... if I decide to put some window rattling subwoofer system in the van (not likely) with an amplifier that draws 2 megawatts, the worst thing I will do is blow a fuse or melt down the relay contacts. A more likely scenario that I've alluded to in a previous post is that I may take the parking light power through the relay so that when I pull the key the parking lights turn off even if the switch is still on. I haven't figured that one out yet... I may want headlights available even when the engine is shut down but the key is in the ignition because it's kinda handy sometimes, but that would take more extensive rewiring.
I hope this makes sense... I'm never too sure how easy it is to follow my explanation. Let me know if it's gibberish and I'll try to draw some pictures!  _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
Posted: Tue Sep 04, 2007 4:09 am Post subject: |
Crystal clear! It is all hooked up and runs good. What a bonus- two birds with one stone. I didn't hook up up any subs yet but ran the wires for the amp while I was in there. I'm planning on putting the amp under the passenger seat nice and close to the battery so I just ran a blue wire (amp remote turn on from the head unit) and the rca cables down the middle under the heater channel cover and up into the base of the seat.
Thanks for the info Paul.
I'll add my vehicle to my sig now. _________________ When my time comes I want to die peacefully in my sleep, like my grandpa- not screaming like the passengers in his car.
RevKevin Samba Member
Posted: Tue Sep 04, 2007 4:20 am Post subject: Re: key buzzer / musical tones at start up |
Lemme check my boxes of spare parts, I had that chime in my '86 and '90 Golfs, the first thing I did when I got them was rip it out because I didn't like my car making the same sound as the deep fryer at McDonalds. I might have given them away when I sold my '90 golf to my friend and gave them a bunch of the spare parts and manuals for it, but there's a good chance one of the two are floating around. If I find one I'll let you have it for shipping cost, it's going to be a few days before I can make it home though. |
Posted: Wed Sep 05, 2007 3:16 pm Post subject: |
| Yup, checked my parts and I don't seem to have them, should be pretty cheap and easy to come by though, if you hit up any MK2 H2O VW (85-92) they should have that relay so check your local Pull-A-Part. If you want to remember what kind of sound they made before buying one go to your local McDonalds, order inside and hang out for a few minutes, their fryers make the same noise when the fries are done cooking. |
dishrag Samba Member
Joined: February 24, 2014 Posts: 27 Location: san jose, calif
Posted: Tue Mar 17, 2015 3:06 pm Post subject: |
| Volksaholic wrote: |
I know this is old but I wonder if you'd have ideas how I can get my seat belt warning light--but no buzzer/chime-- to work. My light bulb does work (it comes on when I first turn ignition on). I do see a 10-amp fuse up at the "18" position of the relay panel. But I don't know what to do next.
PS did you end up having your headlights go off with key out? I have mine set up so that if the lights are on AND the keys are out AND the door opens, then the warning chime goes off. _________________ '86 Westy manual |
