nm767 Samba Member
Joined: March 23, 2008 Posts: 84 Location: Lathrop, CA
Posted: Thu Jun 19, 2008 7:09 pm Post subject: Correct Accelerator Cable |
Bus depot has several different Accelerator Cable's. Im not sure which one i need. I have a 71 westy with 1600 DP. Which one is correct? |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Thu Jun 19, 2008 8:33 pm Post subject: accel cable |
211 721 555 G 69-71 type 2 _________________ V.W.owner since 1967 |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1418 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Thu Jun 19, 2008 9:53 pm Post subject: |
If the one you order come and works right, make sure you order a spare next time you order parts; and keep the extra one in the bus, no bus should ever leave home with out at least three tings; Fire extinguisher, spare throttle cable and spare clutch cable, it is not question of if you will need them but just when :0)
PS an OEM manual and the tools you’ll need to replace the cables would help too ;0) _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
nm767 Samba Member
Posted: Thu Jun 19, 2008 10:31 pm Post subject: |
OK anothe $100.00 order of parts on the way!! Bus is getting closer to being driven for the first time in 10+ years. |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1932 Location: N.W. Georgia
Posted: Fri Jun 20, 2008 4:54 am Post subject: |
From my experience, I suggest an extra clevis pin, or at least a small bolt and a nylock nut to get you going if the pin breaks and you lose the clutch. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
