Engine hood struts
Page: 1, 2, 3, 4, 5, 6  Next
gfw1985
gfw1985 is offline
PostPosted: Mon Aug 27, 2007 12:02 pm    Post subject: Engine hood struts Reply with quote
Has anyone ever rigged something like this for a Ghia? I am running dual Kadrons and the air cleaners hit hood springs. I know I can get shorter air cleaners, but I like this idea.
http://www.mamotorworks.com/acvw.html?frame=1.3769
Plantman
Plantman is offline
PostPosted: Mon Aug 27, 2007 1:41 pm    Post subject: Reply with quote
HVWs or VWTRends did an article on a Ghia that someone had installed the struts on the engine compartment. The guy who did it did a really nice job. The article gave fairly decent instructions, I think it was about two years ago, give or take a few months.
David
Every day may not be good, but there is something good in every day,
No matter where you go, there you are.
'69 bug & '71 Ghia
awj_woody
awj_woody is offline
PostPosted: Mon Aug 27, 2007 1:59 pm    Post subject: Reply with quote
hmm, i would be afraid of messing up and drilling a ton of holes Embarassed
ovalboy
ovalboy is offline
PostPosted: Mon Aug 27, 2007 2:01 pm    Post subject: Reply with quote
Like this?...
There's a great "how-to" article in Hot VW's from sometime in 2004 I believe. It gives the instructions, part numbers and all the details of how Mike Lawless did it on his '65 Ghia. I followed it to the letter and it turned out great.
KarmannBob
KarmannBob is offline
PostPosted: Mon Aug 27, 2007 4:29 pm    Post subject: Reply with quote
I was able to do it using a single Vanagon rear hatch strut.
'71 Ghia
'65 single cab
'57 pg/sg standard
DORIGTT
DORIGTT is offline
PostPosted: Mon Aug 27, 2007 7:26 pm    Post subject: Reply with quote
That's pretty cool KarmannBob!
What are the measurements on the mount placement?
To err is human, but if the eraser wears out before the pencil does you're a major screw-up.
gfw1985
gfw1985 is offline
PostPosted: Tue Aug 28, 2007 6:38 am    Post subject: Reply with quote
Exactly what I'm looking for. Can anyone narrow down that article for dual struts? Tried HotVW's search site, but it is painfully slow on dialup.
ovalboy
ovalboy is offline
PostPosted: Tue Aug 28, 2007 8:19 am    Post subject: Reply with quote
I tried to look it up on Hot VW's website, but it's a needle in a haystack on that site. I'm pretty sure it was one of the summer 2004 issues. I'll keep looking. I did mine right out of the article and it was relatively easy to do. The hardest part was getting the measurements right and making the brackets for the struts, but still pretty easy.
awj_woody
PostPosted: Tue Aug 28, 2007 12:49 pm    Post subject: Reply with quote
that's a nice looking engine bay.
i think i like the looks enough to start looking for that article.
gfw1985
gfw1985 is offline
PostPosted: Tue Aug 28, 2007 1:05 pm    Post subject: Reply with quote
After a couple hours searching, found out it was April 2004 issue of Hot VW's. But can not find anywere to view it. Any ideas?
ovalboy
ovalboy is offline
PostPosted: Tue Aug 28, 2007 1:16 pm    Post subject: Reply with quote
Maybe buy a back issue from Hot VW's? I borrowed it from one of my buddies when I used it. I'll see if he still has it.
gfw1985
gfw1985 is offline
PostPosted: Thu Aug 30, 2007 11:20 am    Post subject: Reply with quote
Hot VW's has a terrible website. Hate dealing with someone that I can't even call. If anyone comes across this article, I would love a scan or copy to sell.
Ovalboy: If I knew what struts to use, I believe I could figure the rest out.
ovalboy
ovalboy is offline
PostPosted: Thu Aug 30, 2007 11:38 am    Post subject: Reply with quote
I'll see if there's a part number on mine. I bought them at NAPA. I can take some better pictures and e-mail them to you if you would like.
gfw1985
gfw1985 is offline
PostPosted: Thu Aug 30, 2007 12:25 pm    Post subject: Reply with quote
That would be great! Thanks for the help. I'll PM my e-mail address.
rons1coat
rons1coat is offline
PostPosted: Fri Aug 31, 2007 10:29 am    Post subject: struts Reply with quote
hey guys I have the article at home. I done the same on my 72 and gonna do it on my 67 so I kept the mag. over the weekend I will try to at least send all the seasurements via e-mail. I will try to scan it and send the whole article if I can. Send me a pm gfw1985 and I will see if I can help you out
bt
bt is offline
PostPosted: Fri Aug 31, 2007 3:20 pm    Post subject: Reply with quote
gfw1985 I have that article. Email me and I will scan it for you.
hawynvdub
hawynvdub is offline
PostPosted: Fri Aug 31, 2007 5:22 pm    Post subject: Re: struts Reply with quote
Can you send it to me too? I've been searching for this for a while now. Sad
808 (O > i < O)
gfw1985
gfw1985 is offline
PostPosted: Sun Sep 02, 2007 5:42 am    Post subject: Reply with quote
Special thanks to rons1coat for scan and Ovalboy for some great pics
Gromit
Gromit is offline
PostPosted: Sun Sep 02, 2007 7:36 am    Post subject: Reply with quote
I have this type of set up on my MG. Works fine but keep in mind that you may have to readjust your hood because of the upward pressure the struts puts on the hinges. For all the 'DIY' or 'figure it out yourselfers'. Check out the struts, end pieces, and mounts at
www.smallparts.com
search for 'gas springs'
Larry
rons1coat
PostPosted: Mon Sep 03, 2007 6:17 am    Post subject: struts Reply with quote
hawynvdub, send me your e-mail address and I will send you the aticle
Page 1 of 6
