TBI
Culito
11010101
Culito is offline
PostPosted: Wed Sep 05, 2007 8:20 pm    Post subject: TBI Reply with quote
I'm sure this has been talked to death in here, but has anyone slapped a TBI setup from a small 4cyl on a VW engine?
I've looked into some multi-port VW stuff and it seems like overkill/expensive for a non-performance vehicle. Seems like a simple TBI setup adapted to a stock manifold shouldn't be too much of a problem.
Ideas?
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
GDOG57
GDOG57 is offline
PostPosted: Wed Sep 05, 2007 11:28 pm    Post subject: Reply with quote
Turbo city out of California,years ago made a T.B.I.setup that used a G.M. unit.Don't know if they still do or not.Hope this helps!
'57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red)
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Thu Sep 06, 2007 1:03 am    Post subject: Reply with quote
I would say that if you're going to go ahead and put EFI on a VW engine, there's really no reason I can think of to go one way or the other. I guess it just depends on what you're trying to achieve.
For example, some people like their engines to look stock, but want the benefits of EFI (e.g. stock resto/resto rod). If I fell into that category, I would modify a standard carburator to function as a throttle body by removing the venturi's, pulgging idle/main circuts, and mounting an injector in such a way that it could be hidden by the stock air cleaner. That's quite a bit of work, so what most people do is use a TB from a production vehicle, and adapt it to work on the car's existing manifold. I don't see any reason why not to do that to a VW engine, aside from the normal fuel dropout/vapor lock issues people sometimes have with carb'd engines.
OTOH, multipoint parts for VW engines are really cheap these days, and if you have any aspirations of going turbo one day, MPI is the way to go IMO. For example, I put together an entire MPI system using Megasquirt and various bits and peices from the junkyard and CB Performance for less than the cost of only a standalone ECU from another company (greddy, ect).
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
Culito
11010101
Culito is offline
PostPosted: Thu Sep 06, 2007 1:29 am    Post subject: Reply with quote
I don't really care about the stock look. I was just looking for an alternative to the fussiness/inefficientcy of a carburated system.
A friend of mine suggested something along the lines of a Suzuki Samuri TBI system...it's relatively simple and the engine size is close. With a addition of a few sensors, it doesn't seem too far-fetched.
Again, I'm not looking for super performance...just reliability and effiicientcy.
Really? I haven't seen a full-on kit advertised for less than a few thousand bucks. Compare that to a cheap junkyard retrofit...
'62 bug
johnnypan wrote:
ashman40
ashman40 is offline
PostPosted: Thu Sep 06, 2007 1:57 am    Post subject: Reply with quote
This sounds very interesting.
I'm just starting to collect parts for a EFI system based around a MegaSquirt ECU. I'm not near any junk yards so I've been searching the Internet and eBay. The closest thing I've seen are EFI Motorcycle TBs. These usually come as a set of four, but some are easy to break apart.
Bikes tend to have smaller engines than acvws and their TBs are meant for one on each individual cylinder, but they rev a whole lot higher (like 14,000RPM)! That's like 3x what you might expect for a simple VW. This means one bike TB may have the capacity to handle a stock 1600cc VW engine.
I'll be interested i nwhat you find.
AshMan40
lostinbaja
lostinbaja is offline
PostPosted: Thu Sep 06, 2007 3:36 am    Post subject: Reply with quote
I would go with port injection, with TBI you still have the fuel puddling in the manifold like you do with a stock carb. Port injection will increase the performance, drivability and the fuel economy over a TBI setup. The Megasquirt ECU along with a TB from a 2 litre car on a plenum style manifold are a good starting point.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
Culito
11010101
Culito is offline
PostPosted: Thu Sep 06, 2007 10:01 am    Post subject: Reply with quote
So the megasquirt can control a TBI setup? I'll have to study the megasquirt more.
I realize that a multi-port setup would be better, but I really don't want to mess with the stock manifold...I don't suppose I'd be afraid of fabbing a new piece between the DP end castings, though.
What about timing? Doesn't the computer in most TBI or multi-port systems sense the timing and control the advance accordingly?
'62 bug
johnnypan wrote:
Loopole
Loopole is offline
PostPosted: Thu Sep 06, 2007 11:23 am    Post subject: Reply with quote
go to the shoptalkforums.com, go to the fuel injection forum for your education. I have been looking into this for some time, the new megesquirt two is really impressive, can now control all your ignition needs now as well. One aproach would be to use an early vw cis throttle body which is a two barrel progressive t/b. These have the same footprint as a weber progressive, so use a weber progressive manifold and use cb performance dual port end castings with the fuel injector bungs welded in, not a engineered plenum setup but should work well for a small displacement engine, and minimal fabrication. I am considering doing this, but some have said the dual port end casting will be way to restrictive for a 2110 even if opened up. Another option is the full on dual idf style throttle bodies but then you are into some serious money.
Another option would be to convert your pict 34 to a throttle body by removing the venturi and adapting a tps to it and use the cb end castings.
then lock out your 009 and add a pertronix, you probably already have these.
return fuel line, new pump and regulator 150
buy a preassembled megasquirt/harness $350
cb efi endcastings fuel rail and injectors $250
plus of course your time and tinkering but would be in another universe as far as driveability and economy, and simplicity. someone needs to do it.
miniman82
Samba Swamp Donkey
PostPosted: Thu Sep 06, 2007 11:47 am    Post subject: Reply with quote
Yes.
if you don't want to mess with the stock setup too much, you can always mount a TPS on the carb and use THESE for a simple multipoint setup. That's what I did.
Megasquirt can control a wide range of ignition systems, and is even capable of driving coil on plug setups directly from the ECU. I'm using Ford's EDIS system, for distributorless ignition. All that's required for EDIS is the crank trigger, a trigger disk mounted on the pulley, the coil pack, control module, and the associated wiring. I got everything for free from a junkyard... Laughing
buggofast
buggofast is offline
PostPosted: Thu Sep 06, 2007 1:16 pm    Post subject: Reply with quote
buying every piece you could put a multiport setup together for around, 1200 or so. I wouldn't waste my time w/ tbi it's barely a step above the carb. cb sells stock end castings with injector bungs in them. I built my own centersection to work w/ a ford tb and made my own fuel rails on my first setup.
Culito
11010101
Culito is offline
PostPosted: Thu Sep 06, 2007 2:18 pm    Post subject: Reply with quote
Well that's pretty awesome.
How did you do your trigger/disk setup?
I'd like to see some pics of tbi or home made multi port setups.
'62 bug
johnnypan wrote:
miniman82
Samba Swamp Donkey
PostPosted: Thu Sep 06, 2007 8:00 pm    Post subject: Reply with quote
Well, I suppose I could show off a little.... Laughing
Here goes.
miniman82
Samba Swamp Donkey
PostPosted: Thu Sep 06, 2007 8:44 pm    Post subject: Reply with quote
I mounted the trigger wheel with 5 allen head machine screws, lockwashers, and locktite on the threads to make sure it doesn't come apart at speed. It was a bitch to get it centered, it would have helped if I had bought a solid pulley instead of this one with the holes.
Or, you could just buy one from these guys:http://home.earthlink.net/~beanbooger/boost_engineering/
I haven't fabbed the bracket for the VR sensor just yet...
EFI end castings. They will be plummed to a single TB, for simplicity.....
....which is in turn fed by CB's turbo buggy header, and one of 4 different turbochargers (I don't know which one will work best yet Twisted Evil ) Oh yeah, it will be intercooled as well. That's as much progress as I've made since getting off the boat, more to come soon, I hope. Rolling Eyes
I'm a lazy b*stard!
Culito
11010101
Culito is offline
PostPosted: Fri Sep 07, 2007 9:35 am    Post subject: Reply with quote
Cool stuff.
I guess since I'm pretty low on cash, I'll have to stick with my crappy 34 pict 3 for now.
But I'll be planning the ultimate setup in the meantime.
(insert evil laugh here)
'62 bug
johnnypan wrote:
