Fuel pump relay terminals...
Surfthrees
Surfthrees is offline
PostPosted: Thu Sep 06, 2007 11:55 pm    Post subject: Fuel pump relay terminals... Reply with quote
Hi!, I've seen lots of info on fuel pump relays, but they all refer to the terminals 30, 51, 85, 86, 87... The relay I have is also 5 terminal but with the terminals 15, 30, 31, 31b, 87? I've read the terminal designation sheets but am still unsure about the hookup? Has anyone wired this relay before so I dont have to risk damaging the relay?
The part number is: 321 906 059 C I figure 87 goes to the pump, but am a little unsure of which ones get switched power and which need direct hookup to battery (if at all?)
67 Type II
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Sep 07, 2007 8:16 am    Post subject: Reply with quote
This is a relay that is activated by the #1 terminal from the ignition coil. Rather than label the relay "1" for this, they call it 31b for whatever reason. Here, since this a relay of type used in watercooled cars, I copied and re-did a diagram from a Bentley watercooled book:
Surfthrees
PostPosted: Fri Sep 07, 2007 11:02 am    Post subject: Reply with quote
Thanks! Thats exactly what I was looking for... Do I have to use the coil terminal or can I run that to another switched on source like the alternator or the oil pressure switch?
67 Type II
The Android
PostPosted: Fri Sep 07, 2007 2:00 pm    Post subject: Reply with quote
It has to be from the #1 on the coil. The pulsating signal is what this relay senses to activate it. That's the point actually, because if anything happens to stop the coil from working, the engine will be not running, and if the engine is not running, you don't want the fuel pump to keep running. Since this is the same wire that you can use to run a tachometer, if you have a tach up front, it should be easy to tap into that connection and use it for a relay. And vice-versa, if you run a #1 wire up front for a relay, would make it that much easier if you wanted to add a tach.
-Andy
Surfthrees
PostPosted: Fri Sep 07, 2007 4:39 pm    Post subject: Reply with quote
Ahhh... much thanks! Thats exactly what I was looking for. So when the ignition is simply switched on it wont activate my pump... but the ignition when it begins to "fire" or pulsate, will. Cool. I'll run it from my tach to CDI wiring... easier that way! Aloha... J
Very Happy
67 Type II
ach60 Premium Member
ach60 is offline
PostPosted: Sun Sep 16, 2007 5:24 pm    Post subject: Reply with quote
Who makes it & where can I get this relay?
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
The Android
PostPosted: Sun Sep 16, 2007 5:42 pm    Post subject: Reply with quote
VW makes it! You can get it out of any old watercooled VW in a junkyard. If you get one from a 77-82 Rabbit/Jetta/Dasher etc, it will even have a fuse built into it. Here's some for sale new online:
http://www.busdepot.com/details.jsp?partnumber=321906059C
http://www.germansupply.com/home/customer/product.php?productid=16928&cat=&page=1
ach60 is offline
PostPosted: Sun Sep 16, 2007 11:56 pm    Post subject: Reply with quote
THANKS
Good Luck
Al
AndyM
AndyM is offline
PostPosted: Wed Jun 03, 2009 5:43 pm    Post subject: Reply with quote
I've got this 5-prong relay and understand the set-up. I think. My question is can I house the relay back in the engine compartment? And , if so, where does #15 get its power from the ignition switch? Is this the same as the POS (+) #15 on the coil?
Also, does #30 get its power directly from the battery or from a connector on the starter?
Thank to any who can answer these questions,
AndyM
The Android
PostPosted: Wed Jun 03, 2009 7:02 pm    Post subject: Reply with quote
Yes, terminal 15 is the same wherever you find it, it means a power source that comes on when you swith the ignition switch on. Terminal 30 is a power supply that is on all the time, regardless of the ignition switch.
It could be run in the engine compartment, if you secure it out of harms way.
-Andy
