65 wiper pivot size question
bnam
bnam is offline
PostPosted: Sun May 11, 2025 3:23 am    Post subject: 65 wiper pivot size question Reply with quote
The pivots on my car are missing the circlips at the top that retain the shaft located to the sleeve. I happen to be in the US and thought I’d pop into an Ace Hardware and see if they have some thing that works. Can someone tell me the dia I should look for?
Thanks,
Byas
Click to view image
1952 Citroen TA 11BL
runamoc Premium Member
runamoc is offline
PostPosted: Mon May 12, 2025 8:20 am    Post subject: Re: 65 wiper pivot size question Reply with quote
Take it with you to Ace and size it up there. Cool
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
bnam
bnam is offline
PostPosted: Mon May 12, 2025 11:42 am    Post subject: Re: 65 wiper pivot size question Reply with quote
Wiper pivot is in India with the car.
Click to view image
Rome
Rome is offline
PostPosted: Tue May 13, 2025 12:07 am    Post subject: Re: 65 wiper pivot size question Reply with quote
I checked 2 old 6 V single-speed wiper assemblies I have in the basement. Shaft diameter ranges from 5.9 to 6.1 mm (0.23" - 0.24"). A circlip for 1/4" (0.25") might be slightly too big, and bending a clip made of spring steel is probably useless. You could buy a few 1/4" to try bending once you're home, but also buy a pair of 1 size smaller, since its unlikely that ACE would have metric sized circlips.
