50ate Samba Member
Posted: Sat Sep 22, 2007 8:19 pm Post subject: need advice on 145's ??? |
i just bought a new bug its a 66 narrowed 6 inches and its adjustable and its on drop spindles runnin 205's out back it looks like it might be droped maybe 1 notch. up front its got temps 125's smoothies all around i want to get the beam off the ground and get some rubber under it (i drive on the free way) so i was thinkin 145's the beam sits about 2 in off the ground now. so let me know what you guys think!! also i have the stock spindles would i be better off puttin those back on and adjustin the beam down in stead or would they rub the buckets? |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2824 Location: Centennial, CO
Posted: Sun Sep 23, 2007 8:44 am Post subject: |
You want to keep the dropped spindles on as they keep the wheel back farther from the headlight bucket. The 145's will definitely give you more rubber and a height to get your beam off the ground. You still might run into problems hitting the headlight buckets though. |
50ate Samba Member
Posted: Sun Sep 23, 2007 12:13 pm Post subject: |
thanks i appreciate the info i had a 67 bout 6 years ago and it was not narrowed it was more euro look but this is going to be stock just dumped so with the 145's you think il be good at like 55 60 mph and not feeling like im eating pavement the temps are so full of air like 55 60 psi they just like riding on wood wheels i think the 145 is like 1 1/2 maybe 2 in taller and that would be great! thanks again il get some pics up soon . i think you guys will like it! |
beetjunky Samba Member
Posted: Wed Oct 17, 2007 1:32 pm Post subject: |
green66,
let me know how that works out. I am thinking of doing the same thing on me 57 oval. Post some pictures.
Are you going to the qiuck and dirty at the XXX this weekend?
Micky |
