Bajabob Samba Member
Joined: October 18, 2003 Posts: 18 Location: Cadiz,KY.
Posted: Sun Oct 07, 2007 5:49 am Post subject: Volksrod - Project 64 |
I'm redoing a 64 that needs a little of everything.When finished it'll be a volksrod.Heres a few of many more questions.
What other year parts are interchangable with it?
What type of 12v wire harness to go with,factory type but for what year?
Should I run a generator or alternator?
Are there disc brake conversions for the front and rear available?
Its basically a rusted shell that has been cutup into a baja,has alot of rust and a seized dp motor.I figure to get it "driveable" it'll need motor work, brakes, wiring, and 2 front seats. |
mailman Samba Member
Posted: Sun Oct 07, 2007 6:30 am Post subject: |
Parts interchangability varies depending on the part. You'd have to be more specific.
I'd stick with the 6 volt wiring harness. The wires are bigger guage than the 12 volt.
Alt vs. gen depends on what you want it to do. Will you be running a big stereo? Big off-road lights? If so, go alt., if not, you're fine with a gen.
Yes there are disc brake conversions available for both front and rear. They are pricey....especially the rear. Some rear sets allow parking brake, some don't. _________________ '64 Bahama Blue Beetle / steel sunroof
'64 Bahama Blue Beetle Sedan (future ragtop) |
