Gerson Samba Member
Joined: January 23, 2004 Posts: 1828 Location: Jupiter Fl
Posted: Wed Oct 24, 2007 8:30 am Post subject: Barndoor heater tubes |
this might sound like a dumb question but here it goes......does anyone know if there is a difference between early(BD), and later heater tubes front side diameter????...how about the forward and the rear chassis crossbrace hole diameter where the heater tube passes thru??????I have some clients that are telling me that the tube is too large, too small...etc...I have an NOS chassis crossbrace, and the diameter is 7cm........any help would be greatly appreciated....... _________________ that's not patina, that's fucking rust man!!!!
we (klassicfab) make the funky green panels........... |
52panelvan Samba Member
Posted: Wed Oct 24, 2007 10:59 am Post subject: |
Hi,
Rear is 3" (7.7mm)hole in cross member and front is 2.75" (7cm)in crossmember. These are taken from panels made by someone else that i believe to be correct. When i fitted these exact panels to the 52 and they seemed to tally with the original heater tube i refitted(undamaged and for the most part not rusty) which was tapered from one end to the other too.
I dont know if later Bd had the non tapered version as in post 55 vans.
I will take try and take some measurements from the original heater tube if it helps.
I would be interested in the year question too as it may be me who has the wrong panels.
Thanks for the panels
Cheers
Mark |
euroduncan Samba Member
Posted: Thu Oct 25, 2007 4:18 am Post subject: |
| The heater tube is tapered needing the dimensions you say. This is correct for 53,54. As I don't have an earlier bus I can't tell you about other years. |
RockStock Samba Member
Joined: November 26, 2004 Posts: 4254 Location: England
Posted: Thu Oct 25, 2007 5:08 am Post subject: |
the feet on later heater tubes are angled, aren't they
feet on earlier buses go straight down? _________________ -StockRocks- |
Posted: Thu Oct 25, 2007 6:50 am Post subject: |
| RockStock wrote: |
feet on earlier buses go straight down? |
Not sure which parts you mean by "feet", Do you mean the 2 welded on clips that hold the front flexy pipe on?
When i assembled my van i could not figure how they would have assembled originally as with the two clips on the tube it will not go through the front centre chassis hole and the chassis section cant be slid on from the other end as the tube is too fat, so may be clips added after?
So 52-54 is tapered (possibly 8cm to 7cm across its length), im not sure my 51 has any left to check, some one will know im sure. I assume it was a slight attempt to increase the air speed in the cab as it comes out the vents? |
Gerson Samba Member
Posted: Thu Oct 25, 2007 6:56 am Post subject: |
so where do we stand with the measurements????the heater tube hole in my NOS rear chassis crossbrace is 7cm, I assume this is the same for all years...the front would then be 6.5cm for 1950, 51, 52...and different for 53, 54, 55 ?????? does this sound right?????  _________________ that's not patina, that's fucking rust man!!!!
Gerson Samba Member
Posted: Thu Oct 25, 2007 7:11 am Post subject: |
here is a picture/measurement of the hole for the heater tube on my NOS rear chassis cross brace...does anyone have a picture of the front????different year fronts???? _________________ that's not patina, that's fucking rust man!!!!
Gerson Samba Member
Posted: Thu Oct 25, 2007 7:17 am Post subject: |
Not sure exactly where we are with the measurements if you have an Nos rear at 7cm, but is it possible the Nos one could be a later one?? I really dont know.
Im saying that rear is 77mm and front is 70mm hole and between Duncan and myself we have heater tubes in a 52, 53 and 54 that reflect this size.
My 80mm mention in my last post was just an assumption based on the fact the tube sticks out past the chassis cross centre.
A few more people need to measure up to be sure i guess with Og heater tubes.
The front hole and heater tube diameter is 70mm just to confirm.
Cheers
mark |
Posted: Thu Oct 25, 2007 8:23 am Post subject: |
| RockStock wrote: |
sorry, i was missing the point - i was on about the the heater logs in the cargo area. _________________ -StockRocks- |
Posted: Sat Oct 27, 2007 5:00 am Post subject: |
Hi Gerson,
After looking at a picture of an nos bd rear cross member i have here, i think- and i could be wrong as i often can be but i think that rear cross member in your picture is not a Bd one. The hole size, cut out and a missing cut out point to it being possibly a later one.
On the picture i have the hole is defiantly around 1/2 cm either side nearer the edges.
Cheers
Mark |
Gerson Samba Member
Posted: Sat Oct 27, 2007 7:25 am Post subject: |
52panelvan, can you post a picture of it??thanks _________________ that's not patina, that's fucking rust man!!!!
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2996 Location: San Diego, CA
Posted: Sat Oct 27, 2007 12:15 pm Post subject: |
| Gerson wrote: |
helping hand on the photo |
Gerson Samba Member
Posted: Sat Oct 27, 2007 1:11 pm Post subject: |
thanks a bunch  _________________ that's not patina, that's fucking rust man!!!!
Posted: Sat Oct 27, 2007 2:45 pm Post subject: |
Hi Gerson, i have sent you a pm
Mark |
Gerson Samba Member
Posted: Sat Nov 17, 2007 12:40 pm Post subject: |
Mark, you guys are right on the heater tube/chassis crossbrace issue....I just went through my pile of cut up BD parts, and I found a rear and a front crossbrace with pieces of the og heater tube still attached, the rear is 7.7cm, and the front is 7.0cm , you are correct, the NOS rear chassis crossbrace that I have is a post BD piece....I am glad this issue is solved, the correct parts will be included in Chris's next shipment.....now, on to the next BD parts mistery ....I tell you, this never ends, learn soemthing new every day..... _________________ that's not patina, that's fucking rust man!!!!
Posted: Sat Nov 17, 2007 2:47 pm Post subject: |
Glad to of helped. The amount of changes 50-53, small differences in the frame and panels is amazing. May be there should be a thread just for these.
Cheers |
Gerson Samba Member
Posted: Sat Nov 17, 2007 3:04 pm Post subject: |
I agree  _________________ that's not patina, that's fucking rust man!!!!
musclebus Samba Member
Joined: February 23, 2006 Posts: 171 Location: UK, Dorset, BD Heaven and Hell
Posted: Sat Nov 17, 2007 7:27 pm Post subject: |
| Gerson wrote: |
| the correct parts will be included in Chris's next shipment.....learn something new every day..... |
cool news .....and correct
if only we had access to one of the original vw factory workers (Marks getting there though ) _________________ www.musclebus.co.uk
Check out our last remaining Klassicfab panels in stock |
barndoormambo Samba Member
Joined: April 25, 2005 Posts: 443 Location: East Coast, Homeland
Posted: Fri Apr 01, 2011 6:56 am Post subject: |
..does anyone have a pic of the OG 70mm flexi hose?
- & , besides modern substitutes, does anyone know whre i can find one?  _________________ ....just cause you don't see it, doesn't mean it isn't there!.... |
