What did YOU do to your van today?
Page: 1, 2, 3 ... 649, 650, 651  Next
hiram6
hiram6 is offline
PostPosted: Thu Oct 25, 2007 1:20 pm    Post subject: What did YOU do to your van today? Reply with quote
A thread with a similar title has garnered over 5,000 posts on another forum I visit.
I've been very productive Westy-wise today.
-Installed new fuel tank
-Installed new ignition switch and lock cylinder
-Reconnected my cable for my heater control valve. (I have to disconnect it and manually move it to off underneath the van during the summer to prevent the Vanagon hotfoot.
-Working on a little desktop platform/cubby thing to fit in the center of the dash. Woodworking 101 kind of thing. I would like a level spot there instead of the slope of the Vanagon dash. Not sure I'll get that done today.
Not braggin', but I feel pretty good about everything so far. Nice feeling to know you did it, and therefore know how it was done.
Very Happy
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
jackbombay
jackbombay is offline
PostPosted: Thu Oct 25, 2007 1:28 pm    Post subject: Reply with quote
Oil cooler install after a LOT of prep work to make it fit, got tires mounted (Hakkapeliita CS 195 75 16) 16" wheels and put on the van (not the rears yet though, need to modify the lugnuts Shocked ) , wired up new fridge (vitrifrigo). Hope to make a drawer for above the fridge tonight.
BadBeetle
BadBeetle is offline
PostPosted: Thu Oct 25, 2007 1:34 pm    Post subject: Reply with quote
I just got my Vanagon Syncro GL today. Very Happy allot a work ahead of me.
It needs a new engine, and a CV shaft. lol Other than that its near MINT!
View user's profile Send private message AIM Address Yahoo Messenger Classifieds Feedback
Lanval
Lanval is offline
PostPosted: Thu Oct 25, 2007 1:40 pm    Post subject: Reply with quote
Does yesterday count? I wired in a new voltmeter cluster with oil pressure and inclinometer.
Also wired my oil temp sender for my air cooled engine to the water temp gauge in my post 85 cluster. We'll see if it works.
Finally, reset the idle, and checked the decel valve for vacuum leaks. Seems OK, we'll try the van. It's dropping a fair bit of oil from the rear main seal Shocked Wouldn't be so bad if I hadn't paid someone to seal it in summer. Confused
Best,
Lanval
camo westy
camo westy is offline
PostPosted: Thu Oct 25, 2007 2:17 pm    Post subject: Reply with quote
Finally raining here in VA. I drove my weekender into the warehouse where it is warm and dry.
Yesterday I ordered new rear seat upholstery from SewFine.
Lots of nice Vanagon interior fix-ups from the SewFine folks. Great service too.
UH60Driver
UH60Driver is offline
PostPosted: Thu Oct 25, 2007 2:20 pm    Post subject: Reply with quote
I listened to my fuel pump on the way home. It is starting to growl at me again... So I am guessing I need to pull it and see what is going on.
ProvoCyclist
ProvoCyclist is offline
PostPosted: Thu Oct 25, 2007 2:44 pm    Post subject: Reply with quote
Yesterday I...
Changed the oil and put on a proper Mahle filter. I pre-filled the thing, and it look like 3/4 quart! Shocked
Topped up the coolant.
Re-installed the original steering wheel that I put a wheelskin on and a new horn ring.
Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Savanna Beige Metallic LH1V.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A
Ma'ili Pt Westy
Location: Woodside, California (located in Northern California)
Ma'ili Pt Westy is offline
PostPosted: Thu Oct 25, 2007 3:05 pm    Post subject: Drove it Reply with quote
Got it out of the garage today and took it for a drive into town.
McVanagon
McVanagon is offline
PostPosted: Thu Oct 25, 2007 3:21 pm    Post subject: Reply with quote
Just drove it to and from work. Crying or Very sad
'69 Mike
'85 GL
'87 Wolfsburg Hardtop
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
woggs1
woggs1 is offline
PostPosted: Thu Oct 25, 2007 3:37 pm    Post subject: Reply with quote
I just looked at it from my webcam at work. Yes I have a webcam pointed at it.
4 speed 88 Westy
fastwagens
fastwagens is offline
PostPosted: Thu Oct 25, 2007 3:43 pm    Post subject: Reply with quote
removed the tranny from my VR6 syncro project. I did yhis with the help of my 7 yo son. Good times/
CF
CF is offline
PostPosted: Thu Oct 25, 2007 4:01 pm    Post subject: Reply with quote
today i checked the codes on the eurovan,ordered my brake parts for the syncro,and tried to start the 84 gl(pain in the a** 1.9)
fortheloveofvdub
fortheloveofvdub is offline
PostPosted: Thu Oct 25, 2007 4:05 pm    Post subject: Reply with quote
New roof hatch/ roof hatch seal, new flat seal on pop top (bunch a yucky black crap), new seal around rest of pop top, luggage rack seal next, (some other day).
Nasty ol' winter's just around the corner here in Ohio!
1621
1621 is offline
PostPosted: Thu Oct 25, 2007 4:54 pm    Post subject: Reply with quote
Have you considered therapy?
Added a couple magnets to the edge of the rear table to keep it from swinging around turns.
'85 Westy
kevinbassplayer
kevinbassplayer is offline
Tuesday night - Finished the rear brakes: installed new Stainless brake lines, new shoes, new wheel cylinders, and new brake drums. Unfortunately I had to put it back in the shop today because the drums are squealing, I loosed the e-brake but the shoes are still rubbing too much. Last night I had a flat tire (a big nail) and put in a tire plug and pumped the tire up with my mini compressor on the side of the road by flashlight.
bucko
bucko is offline
PostPosted: Thu Oct 25, 2007 5:05 pm    Post subject: Reply with quote
Used some mild compound to clean the inner paint (door jamb area).
Bascially, I pick a part of the vanagon to clean; 2 out of 3 days a week to get it detailed.
Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181
Perales
Perales is offline
Received and opened a box of shiny new valve covers and other bits from Bus Depot. I am waiting for the weekend.
-- 1987 Westfalia automatic (Captain Vino)
Raynor Shine
Raynor Shine is offline
PostPosted: Thu Oct 25, 2007 5:15 pm    Post subject: Reply with quote
I ordered a Norcold. Finally!
Perales
Perales is offline
PostPosted: Thu Oct 25, 2007 5:19 pm    Post subject: Reply with quote
Oh, I like that idea, I think I'm going to do that too.
mrhooie
mrhooie is offline
PostPosted: Thu Oct 25, 2007 6:06 pm    Post subject: Reply with quote
brushed the snow off it =(
85 Westy 1.9l h2o - the Winder mk II
Page 1 of 651
