Deluxe bumper trim
Page: 1, 2, 3  Next
ukdj
ukdj is offline
PostPosted: Thu Nov 29, 2007 9:15 pm    Post subject: Deluxe bumper trim Reply with quote
Do you think they used a special tool to put that rubber in Do you think it was cut by machine or by hand?
driving down the road of life at 60 mph
derv
derv is offline
PostPosted: Thu Nov 29, 2007 9:20 pm    Post subject: Re: deluxe bumper trim. Reply with quote
Hey Craig -
I was flipping through my bentley yesterday and saw that there was a special tool used to insert the rubber into the trim.
I am sure it can be done using something else.
Jack
Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth.
Andrew
Andrew is offline
PostPosted: Thu Nov 29, 2007 11:28 pm    Post subject: Re: deluxe bumper trim. Reply with quote
derv wrote:
ukdj wrote:
Do you think they used a special tool to put that rubber in Do youthink it was cut by machine or by hand?
Hey Craig -
We did mine using a flat head screw driver. Just be careful not to slip and stab the bus. Laughing
-Andrew
Scotts 63 23
Location: Somewhere in my mind... The Real er Laguna Beach :)
Scotts 63 23 is offline
PostPosted: Fri Nov 30, 2007 10:19 am    Post subject: Reply with quote
I used a flat burnishing tool made of bone to push the rubber into the slot.
I cut the rough shape of the rubber with a knife/utility blade, then sanded it down, eventually wet sanding the rubber and then waxing it when finished. Turned out perfect!
'63 23 Daily Driver
www.scottmooreart.com
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Fri Nov 30, 2007 11:33 am    Post subject: Reply with quote
Yeah, that rubber cuts/sands/buffs surprisingly well.
I used a large flat blade screwdriver on baby oil soaked pieces and installation went pretty easy.
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
ukdj
ukdj is offline
PostPosted: Fri Nov 30, 2007 9:23 pm    Post subject: Reply with quote
i,ve put it in before i was just wondering if it was pre made by a machine or if they cut it or filed it by hand at the factory?All those years ago
Lind
Lind is offline
PostPosted: Fri Nov 30, 2007 9:29 pm    Post subject: Reply with quote
I have had NOS trim inserts, and they were cut and sanded smooth. they were not formed ends.
Wanted:
twinwindows
Samba Pimp
twinwindows is offline
PostPosted: Fri Nov 30, 2007 10:09 pm    Post subject: Reply with quote
Hmm.. Thanks for the info
CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote:
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed.
Stocknazi
Stocknazi is offline
PostPosted: Sat Dec 01, 2007 7:58 am    Post subject: Re: deluxe bumper trim. Reply with quote
derv wrote:
Hey Craig -
where in the bently manuel was the pic of the special tool you are refering to? is this in the 50-62 bently?
WANTED:
Thomas Jefferson
Empicollector
Empicollector is offline
PostPosted: Sat Dec 01, 2007 9:39 am    Post subject: Reply with quote
I use a wooden kitchen spoon--works good and no damage----and warm the rubber first
PostPosted: Thu Dec 11, 2008 9:14 pm    Post subject: Re: deluxe bumper trim. Reply with quote
In the body section
PostPosted: Thu Dec 11, 2008 9:15 pm    Post subject: Reply with quote
Yes, my original inserts from my '64 are clearly hand shaped. They are not even perfectly smooth, although the shaping is pretty even. I'm wondering if they cut them with a hot knife.
My technique:
1. Cut strip from roll. If using original pieces as a pattern, make sure they haven't shrunk when you cut the overall length.
2. Cut rough shape with a box knife or razor blade.
3. Carefully shape with bench grinder
4. Hand sand/shape with 60 grit on block and free hand
5. Smooth out minor scratches and final shaping with 150 grit
6. Wet sand with 600 grit
7. Wet sand with 2000 grit
8. Buff with some paint polish
9. Install
A wooden kitchen spoon works great to push the insert into the trim, although I prefer to push from the bottom. Use the handle end, not the spoon end. The spoon end will break if it's too thin.
Do the fronts first so if you screw up, you can cut it down and make a rear.
Split 1
Split 1 is offline
PostPosted: Sun Dec 14, 2008 4:32 am    Post subject: Reply with quote
Can you buy repro inserts, or what are people using.
Thanks
Dave
IN2RUST
IN2RUST is offline
PostPosted: Sun Dec 14, 2008 8:34 am    Post subject: Reply with quote
Yes, wolfsburg west sells repop insert. Fairly inexpensive
RUSTFARMER....I like anything old and rusty!
PostPosted: Sun Dec 14, 2008 10:34 am    Post subject: Reply with quote
Yes, it comes in a big long strip that you have to cut and shape.
The roll I bought, sourced from Wolfsburg West, had enough for an extra piece. Maybe a front, definitely a rear.
Some pics of me roughing it in a front bumper point:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=505345
http://www.thesamba.com/vw/forum/album_page.php?pic_id=505344
http://www.thesamba.com/vw/forum/album_page.php?pic_id=505343
http://www.thesamba.com/vw/forum/album_page.php?pic_id=505342
Rich Hanson
Rich Hanson is offline
PostPosted: Sun May 10, 2009 6:54 am    Post subject: Installing rubber insert Reply with quote
I just finished installing the rubber insert on the bumper trim I bought from Westling Machine. Instead of using a grinder to shape the rubber, I used a 4-way wood rasp (available at most hardware stores) to work the rubber (Wolfsburg West). In just minutes, I had the shape I needed and kept the mess to a minimum. I used the finer "teeth" on the rasp to clean it up, then used Everett's suggestion on sanding and finishing.
I used a wood block with a taper on one end to push and roll the upper bead of the rubber into the trim. Worked good!
Ragtop Rich
61 Ragtop Bug
60 Bug
57 23-Window Bus
57 oval window
83 1/2 Westy
Split 1
Split 1 is offline
PostPosted: Fri Jun 12, 2009 5:14 am    Post subject: Reply with quote
I bought the insert from WW but its for the US spec ones and I can only get 3 of the Euro ones out of a length, so now I have to order another length, 8 foot for just one insert??
I also found it easier to get in if you let is soften in boiling water for a few minutes first.
Dave
Damon22
Damon22 is offline
PostPosted: Fri Jun 12, 2009 7:27 am    Post subject: Reply with quote
I bought the inserts in 4 strips from Creative Engineering, I mentioned that I have a Wolfsburg bus and therefore the front inserts are longer and Mandy told me their trims come in lengths to compensate for that, 2 short 2 long.
I used a grinder to shape them, came out perfect. I was dreading geting them in, given the agro getting the old ones out, but it was a breeze.
Dunked the strips in a bucket of hot water for 10 minutes before fitting each one.
Following Everetts advice I used a liberal application of personal lubricant (unflavoured) and a wooden Spatchula.
Rich Hanson
PostPosted: Fri Jun 12, 2009 8:13 am    Post subject: deluxe bumper trim Reply with quote
I had e-mailed W/W with the suggestion that they offer the inserts in both 8' & 10' rolls, so that those with pressed bumpers can get all 4 pieces from one 10' roll. If enough people e-mailed that to them, hopefully they'd be responsive enough to customers to accommodate that request. Even if they charged a little bit more proportionate to the length, it'd still be better than having to order an additional piece for just one 30" strip of insert.
Ragtop Rich
61 Ragtop Bug
60 Bug
57 23-Window Bus
57 oval window
83 1/2 Westy
hitest
hitest is offline
PostPosted: Fri Jun 12, 2009 4:39 pm    Post subject: Reply with quote
If WW just offered the 10 foot lengths- I'd still buy it. I'd use the extra couple feet as a tire stop so my wife will stop running her car into the water softener!
FU#5
Page: 1, 2, 3  Next
