jbow1076 Samba Member
Posted: Wed Dec 05, 2007 11:00 am Post subject: Leaking from my push rod sleeves. Need advice!!!!! |
I have a 2054cc engine and using stock push rod sleeves which are now leaking. I need to get new sleeves and I was wondering if anyone had any suggestions on which ones to purchased and which ones to avoid. I have seen many different styles from spring tension to a nut in the middle that provides the pressure. Some are Nylon and some Aluminum, which route would be the best to take to stop the leaking. Thanks to all~ |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Dec 05, 2007 12:08 pm Post subject: |
Stock tubes seem to work the best. The plastic ones seem to melt if they get hot.
If the engine is a stroker, you will need to stretch the tupes out a little before you install them.
And the seams go up.
VW's should not mark their territory. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
ClareSutton Samba Member
Joined: December 05, 2004 Posts: 466 Location: Sarnia Ontario
Posted: Wed Dec 05, 2007 2:27 pm Post subject: |
I used the spring loaded ones on my '71 notch. It was convenient not having to take the engine out but it was still by no means easy---and they still leak--a bit. I would go with stock or maybe the the type with the expansion nut. Good luck |
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Wed Dec 05, 2007 2:49 pm Post subject: |
I used these with high ratio rockers. Worked great.
http://www.cbperformance.com/catalog.asp?ProductID=123 _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
