ValleyHappy Samba Member
Joined: April 04, 2007 Posts: 251 Location: Walla Walla, WA
Posted: Mon Dec 10, 2007 2:41 pm Post subject: It's cold and my van won't really warm up |
It's my first winter with my van and I noticed my heater never gets really warm. My coolant temp guage is reading just above the low shaded area. It seems my motor is not properly warming up. Do I have a faulty valve that is sending coolant to the radiator sooner than it should? Does the vanagon have such a cooling system...that allows the coolant to circulate around the motor only, until it warms up and then can be circulated up to the radiator? I'm sure once I get a Bently I can answer my own questions.
Thanks _________________ 09 Suzuki SX-4 Crossover |
funagon Samba Member
Posted: Mon Dec 10, 2007 4:19 pm Post subject: |
Your hunch is correct. The "valve" that allows hot coolant to run up to the radiator is the thermostat. It's in the engine compartment, in a black plastic housing attached to the cylinder head on driver's side. Lots of hoses attached to it.
Your thermostat has probably gone bad and its stuck open, so that coolant is constantly cycling through the radiator. That means your engine is running too cool and your heater never heats up.
If that's the problem, then new thermostats are cheap. Undo the 4 bolts on the thermo housing, replace thermostat (install new o-ring in correct location!), snug down bolts. You're done. You'll lose a little coolant but don't worry about it. Just top up the overflow tank.
The other possibility is that your heater control lever (on the dash) is not properly attached to the cable that runs to the heater control valve. The lever clamps onto the cable behind the dash (you can see it if you pull out the ashtray) and sometimes the cable slips in the clamp. But I think the result there would be heat on all the time, not heat off. So it sounds like you have a bad thermostat. Cheap and easy to replace. Put a new one in and see what happens.
EDIT: My description of the thermostat location is for the 2.1 WBX engine. If you have a 1.9 engine then I don't know that it's in the same place. _________________ 1990 GL 7-passenger
2.2 liter WBX
devesvws Samba Member
Joined: January 05, 2004 Posts: 1540 Location: madison va
Posted: Mon Dec 10, 2007 4:39 pm Post subject: |
mine is doing the same thing. but fear prevents me from looking at the thermostat and changing it. just knowing the heads will start leaking once i do  |
danno Samba Member
Joined: November 07, 2005 Posts: 184 Location: Comox BC
Posted: Mon Dec 10, 2007 6:45 pm Post subject: |
one thing I noticed after I took the leaky rear heater core out and put a loop in place was the heat wouldn't get very hot and so I took the loop out and plugged both lines and now it seems to get a lot hotter up front.
Dan _________________ Dan
Comox BC
86 Wolfsburg Weekender
92 Golf 4dr
93 Beta Synt Trials Bike. |
brooklynvan Samba Member
Joined: February 08, 2006 Posts: 342 Location: Brooklyn NY
Posted: Mon Dec 10, 2007 9:06 pm Post subject: |
Thermostat is cheap. and easy to replace.
Mine was doing the same thing. now it's toasty. _________________ 1990 Vanagon "Plain Jane" Bostig in the Back
TRADED: 1967 Panel for 1976 BMW 2002
SOLD: 1984 Sunroof Vanagon with EJ22
RIP 1986 Saab turbo
and my daily commuter: a Bicycle |
Posted: Mon Dec 10, 2007 9:46 pm Post subject: |
thanks for the replys...one thermostat coming right up. toasty sounds good. _________________ 09 Suzuki SX-4 Crossover |
Chuck77 Samba Member
Joined: April 05, 2007 Posts: 170 Location: Brush Prairie, WA
Posted: Mon Dec 10, 2007 10:11 pm Post subject: |
About how long would it typically take for a 2.1 WBX to heat up from ambient weather temperatures like 30 degrees? I too may be dealing with this issue, but I wanted to see what a typical time frame was so I can compare. I am also considering spraypainting a piece of cut to fit cardboard and putting it in front of my radiator but behind the grill to get the brick to warm up a little quicker on my morning drive... |
Posted: Tue Dec 11, 2007 4:27 am Post subject: |
I can drive for 45 minutes and my temp only reads to the top edge of the shaded area on the low end. only in the summer did my gauge readfull warm-up temp. _________________ 09 Suzuki SX-4 Crossover |
mordeaux Samba Member
Posted: Tue Dec 11, 2007 8:16 am Post subject: |
Chuck,
I drive about 6 miles to work each day - 2 miles on city streets and 4 miles on a stop and go freeway. In that drive each morning, my 90 Carat gets well warm, warm enough to be uncomfortably warm with no front blower fan.
So, after 15 minutes driving in 30F temps, the needle on my gauge is just about at the LED. Maybe a hair below the LED. |
Posted: Tue Dec 11, 2007 8:40 am Post subject: |
My 90 GL (2.1 liter engine) has a new radiator and new thermostat. Front heater gets good and warm after about 5-6 minutes of steady driving in 30 degree F outdoor temps.
I've found that letting the car sit with engine idling won't get the coolant/heater warm, at least not fast enough. So it's useless to let the van "warm up" in the driveway, at least for the purpose of getting the heater going on a cold morning. So I start her up and drive easy (lower RPMs) until the coolant needle starts to rise, just so that I'm not working the little engine too hard while the oil is thick.
After 3-4 minutes the needle on the coolant temp gauge starts to rise and I have some heat at the front vents. After 6-7 minutes of steady driving, the needle stops at the light in the middle of the gauge, I have plenty of heat in the cabin, and I put the gas pedal to the floor.
EDIT: for those who care to compare how long it takes to warm up: this morning it was 18 degrees F outside and it took about 6-7 min driving before the coolant temp needle started to move and I felt a little heat. After 10-12 minutes of steady driving I had good heat coming out of the front vents and the needle rose to its proper position. It shouldn't take longer than that (unless you're sitting at stoplights and sitting in traffic). _________________ 1990 GL 7-passenger
2.2 liter WBX
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10147 Location: Abiquiu, NM, USA
Posted: Tue Dec 11, 2007 9:11 am Post subject: |
funagon wrote: |
After 3-4 minutes the needle on the coolant temp gauge starts to rise and I have some heat at the front vents. After 6-7 minutes of steady driving, the needle stops at the light in the middle of the gauge, I have plenty of heat in the cabin, and I put the gas pedal to the floor. |
You're doing it exactly right. This describes perfectly what VW's recommended starting/driving procedure always was with the old aircooleds, and its logic applies equally to any engine. I'm not surprised you figured it out, because it makes so much sense. Since both idling and cold oil are both unfavorable operating conditions, the rec was always to start up, verify that the oil light has gone out indicating the motor has OP, and drive away using moderate power levels until the engine is fully warmed up. Idling is a less-balanced state of operation than higher revs, and produces much less waste heat, so oil warmup is greatly delayed by idling a cold engine. Cold oil is a poor lubricant, so the main objective is to warm up the oil ASAP, without overstraining the engine while lubrication is sub-optimal. Most of the wear in engines is attributable to the warmup phase. So this is a good compromise to get the oil to a useful temp faster, while avoiding undue strain on the bottom end in the meantime. It's also why the oil/water heat exchanger put on later VW cars is such a useful thing to have, as the water reaches temp much sooner than the oil will so it helps get the oil warm much faster.
I modify the procedure to take one other thing into account. If the car has been parked overnight, the gear oil has all drained off the gear surfaces. I let the engine idle for half a minute or so, clutch out and in neutral, so the gear shafts can spin and throw oil around the gearbox, then I drive away gently until my engine is warmed up. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Tue Dec 11, 2007 9:21 am Post subject: |
funagon wrote: |
I've found that letting the car sit with engine idling won't get the coolant/heater warm, at least not fast enough. So it's useless to let the van "warm up" in the driveway, at least for the purpose of getting the heater going on a cold morning. So I start her up and drive easy (lower RPMs) until the coolant needle starts to rise, just so that I'm not working the little engine too hard while the oil is thick. |
Same here.. The longest I ever let them warm up, is the time it takes me to clear snow/ice off the windows.... _________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
fixedgear Samba Member
Joined: November 09, 2006 Posts: 300 Location: Clear Lake, Manitoba, Canada
Posted: Tue Dec 11, 2007 11:19 am Post subject: |
Thanks to ValleyHappy for the post. My situartion is somewhat similiar-little or no cabin heat. The main difference being that I am running the 2.1 at an outside temp. of around 0 degrees F.( -15C.). During the summer months the needle was usually on the lower side of the LED. In the present situation the needle is parked, and the most I can expect in a 50 K. (32 mile ) run is to get it to budge to close to the bottom edge of the white area.
I have the diffuser off and checked the cable, which seems to be secure to the front valve. I have flushed the system and have the coolant ratio around 50%. I have removed the thermostat and dangled it in boiling water to check the opening and closing function. The 87 degree thermo. seems to be working.
Feeling the pipes to and from the heater after 1/2 hour of driving, with the temp. guage needle close to rest, the best description would be lukewarm. The airflow from the footwell ducts with no fan is far greater than needed for the heat generated. The fan is not an option in this case.
I had read the posts that said that the thermostat's fuction was limited to warmup only. I infered by this that after 10 minutes or so of running in any temperature that the thermostat had no influence.
I wonder if the engine never achieves warmup over the entire 1 hour or so running time due to the themostat staying open (despite my test.) I cannot believe that the amount of heat I am getting off the front exchanger is normal, even for a vehicle designed to be recreational. The Germans are nothern Europeans after all!
In defence of the 2.1 though I have to say that I have never had a vehicle that cold-started like this. My storage preparation, last winter, next to the house was limited to oil change, gas fill-up with some stabilizer. The battery was left in can connected. No plug removal or defogging oil with manual cranking. Six times or so last winter I tried to start it, but not move it. It started each time and kept idle. Both my other vehicles would never be able to do this unless the block heater was working, and even then the draw-down of the battery would make it iffy, in not driven.
Sorry for the wordy post, Barnaby |
Posted: Tue Dec 11, 2007 11:35 pm Post subject: |
tencentlife wrote: |
funagon wrote: |
I modify the procedure to take one other thing into account. If the car has been parked overnight, the gear oil has all drained off the gear surfaces. I let the engine idle for half a minute or so, clutch out and in neutral, so the gear shafts can spin and throw oil around the gearbox, then I drive away gently until my engine is warmed up. |
This is pretty much how I do it as well. This August I had a brand new radiator, T stat, rear heater, and head job done on the 2.1, and it still seems a little slow to come to full temp. I do notice that my operating temp now is different than what it was in the summer, and it felt that I could have easily gotten 3rd degree burns from the heater then. Well I wish I had that problem now when I have to head to work and I wear gloves and a hat inside the van since the heater seems to perform so poorly. Any tips on how to bring the heater temps up? What if I was to block off some of the radiator with a piece of spraypainted cardboard, thus shrinking the efficiency of the air-water heat exchange process? |
msinabottle Samba Member
Posted: Wed Dec 12, 2007 12:45 am Post subject: Little Engine, Big Van |
It really doesn't take too long for a WBX to heat up. That's a LITTLE engine moving a LOT of metal around, surprisingly well. In the good old days, a 440 V-8 would be cold a half hour after you started driving it, but the little four cylinders heat up quite quickly given how much work they've got to do.
The drill I heard was to leave the heater off until the engine temperature indicator needle moved AT ALL. Then you could turn on the cabin heat while letting the engine get warm enough for operating temperatures.
Most engine wear occurs before the oil is warm enough to lubricate the moving surfaces of a running engine. The best thing I've done in this cold weather is to go down from 20W50 to 10W30 from October to March. I'll probably make that 10W40, but the van starts easily with the thinner oil and it does get lubricated quickly.
Posted: Wed Dec 12, 2007 7:18 pm Post subject: |
Rob, that's right, the absolutely fastest way to get the engine warming up s to leave the heater valves closed until the needle begins to register. That stops all flw outside of the loop within the engine itself. Then open the valve and it will deliver warmer water to the heater core.
Chuck77, have you tried closing your rear heater valve to see if you get better heat up front? If it gets better, it's possible that your rear heater lacks the flow restrictor that should be in the valve inlet port. If too much water flows thru the rear core too easily, there will be very little flow diverted to the front core, and your fan will quickly cool the core, with the result being anemic temps out of the front heater. If closing the rear valve helps (push the little lever rearward), you could just leave it that way, or just open it a crack in lieu of the restrictor. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Posted: Wed Dec 12, 2007 8:26 pm Post subject: |
Not sure about the flow restrictor being intact or not in the rear, that would definitely play a big part in things. I did adjust the rear heater core valve, I will see what that does for me tomorrow. Thanks man. |
tds3pete Samba Member
Joined: April 04, 2004 Posts: 914 Location: Seattle, WA
Posted: Wed Dec 12, 2007 8:53 pm Post subject: |
FYI On my Audi A6, I have both a coolant temp guage and oil temp guage. It is interesting how much faster the coolant gets up to normal temp than the oil.....something like twice as fast. It seems logical since the coolant has a high flow rate, and is probably makeing a lot more contact around the cylinders and heads.
I don't know if this is typical, but it means reading a coolant temp guage might not be a completely accurate picture of oil temp, until everything has stabilized. _________________ '58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow |
Posted: Wed Dec 12, 2007 8:56 pm Post subject: |
No, it's definitely not. Oil takes 2 or 3 times as long as coolant to get to full running temps, like 180F. The oil/water exchanger is a great way to make that happen faster. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
aguabonita Samba Member
Joined: November 27, 2005 Posts: 267 Location: Monterey, CA
Posted: Thu Dec 13, 2007 11:29 am Post subject: |
Is that why it's a bit hard for me to shift (manual tranny) when my van is fresh off the blocks and cold? Only seems to last for a shift or two. _________________ '87 Westfalia, GW 2.2, and some other goodies
'90 Volvo 245 |
