Fuel Line-Between Pump and Filter
Brown_Bus
Brown_Bus is offline
PostPosted: Sun Dec 16, 2007 2:12 pm    Post subject: Fuel Line-Between Pump and Filter Reply with quote
1976 FI 2L
I noticed the fuel line between the fuel filter and pump was leaking slightly -wet hose and slight drips on driveway. So I went to replace it.
Should there be a constant flow of fuel out of that hose with the engine off. If so, any recommendations on how to slow the flow long enough to put the new line on?
Thanks,
Troy
VDub Campers Ltd.
VDub Campers Ltd. is offline
PostPosted: Sun Dec 16, 2007 2:20 pm    Post subject: Reply with quote
Yes get a fuel line clamp from any motor factors or if this is not possible use vice grips to grip the hose at the side of the filter closest to the front of the vehicle . If using vice grips protect the hose with a rag or something to save damage to to hose .
Yes fuel would always drain from the tank if you didnt clamp it .
Late Westy hire, sales and servicing at www.vdubcampers.co.uk
Brown_Bus
PostPosted: Sun Dec 16, 2007 3:01 pm    Post subject: Reply with quote
so clamp on the fuel tank side of the filter. That way I can remove the suspect line. Makes sense. Thanks
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Dec 16, 2007 3:07 pm    Post subject: Reply with quote
Make sure you get the correct hose. 11mm as I recall.
Brown_Bus
PostPosted: Sun Dec 16, 2007 4:46 pm    Post subject: Reply with quote
I went to public school what is the standard conversion for that? Smile
When i get the line is Fuel Injection hose the kind to get?
Randy in Maine
PostPosted: Sun Dec 16, 2007 4:49 pm    Post subject: Reply with quote
Yes I went to public schools also. That is why I am willing to work on a VW bus.
11mm = 11mm.
Do not buy the SAE equivalent. That is a tough one to find also. I bought some at the Merceded Dealer, but I should have just bought it for less money at German Supply.
Brown_Bus
PostPosted: Sun Dec 16, 2007 5:06 pm    Post subject: Reply with quote
Smile
I guess what I mean by the standard conversion is the measurment system that we are stick with here n the USA...
local auto parts store carries 3/8'' etc.
Is German Supply an online company? It's one of those can wait but would rather not,for it to come in the mail.
Thanks Randy
Troy
busfreak_71
Flat 4 Junkie
busfreak_71 is offline
PostPosted: Sun Dec 16, 2007 5:39 pm    Post subject: Reply with quote
Your bus was made in Germany (DUH!) There they use metric, so use metric tools, 11mm=11mm or IF you musk know the SAE equivalent of a 11mm, a 7/16" will do but is not recommended because it isn't the right tool... Rolling Eyes
'71 Tin Top Westfalia
'99.5 Bora TDI
'85 Jetta Coupe
'85 Mercedes 300SD
Resident Off-Grid hippie and diesel advocate.
Brown_Bus
PostPosted: Sun Dec 16, 2007 7:02 pm    Post subject: Reply with quote
I undrstand that the rest of the world uses Metric including the folks who put my bus together:).. my question was, in a pinch, without quick delivery from German Supply, what would suffice from the local store. They just looked confused when I expressed the need for exact metric product.
Maybe Canada doesn't have the problem I do with my local auto parts store only stocking in inches etc. so my dilemma may have been lost on you.
On a side note, most of the scientific world is suing metric. I wish the U.S. would step up to the plate with the rest of the world.
I ended up ordering from German Supply and will just start my Christmas trip a week later. But what is cool is I found jalousie window crank handles Smile
cr@M
cr@M is offline
PostPosted: Sun Dec 16, 2007 7:14 pm    Post subject: Reply with quote
I hate SAE. I prefer metric over everything.
America likes being different and stubborn because they think they're right and they need ways like SAE to feel better than everything.
*no there's no support to go with that, just a small rant*
1972 Deluxe named Lucidity
1973 Transporter
"He who fights with monsters must see to it that he himself does not become a monster...
when you gaze long into the abyss, the abyss also gazes into you."
-Friedrich Nietzsche
Brown_Bus
PostPosted: Sun Dec 16, 2007 7:17 pm    Post subject: Reply with quote
I hear ya. Metric is soo much easier to work with. Conversion within the system at least.
Traveling Writer
Samba Scribe
Traveling Writer is offline
PostPosted: Mon Dec 17, 2007 9:45 am    Post subject: Reply with quote
Regarding German Supply, yes they are online.
http://www.germansupply.com/home/customer/home.php?cat=300
I just received the replacement fuel hose kit, and it looks great! I know many others on here rely on Scott at GS to do their fuel lines. Check out the link....
Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well)
vdubyah73
vdubyah73 is offline
PostPosted: Mon Dec 17, 2007 9:50 am    Post subject: Reply with quote
Little off topic, but since it's been mentioned, it really toasts my ass that American cars are now both SAE and metric.
Bill
burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34'
dtrumbo
dtrumbo is offline
PostPosted: Mon Dec 17, 2007 10:06 am    Post subject: Reply with quote
Bill
X2! I just changed the alternator on my '93 Chevy (American?) pickup and had to make endless trips back and forth to the tool box to get the appropriate socket depending on the fastener, SAE or metric, that I was attempting to loosen. Very frustrating. One or the other please, not a mix.
1970 Transporter. 2074cc, dual Weber IDF 40's
1971 Super Sedan.
1973 Squareback.
1976 Transporter.
1978 Riviera Camper.
1979 Transporter.
1979 Beetle.
IFBwax
IFBwax is offline
FYI your Mercedes or BMW dealer should have it. Also, you'll need slightly bigger hose clamps which are also available from them or even a VW dealer. They cost a bit more than any old clamp, but won't pinch the hose.
Owner of: "The Party Pickle" (a 1979 2 Liter FI "Raby Camper Special" Sage Green Westy Campmobile) & "Charlie Brown" (a 1979 2 Liter FI "Rob Grant Rebuild" Agate Brown/Dakota Beige Station Wagon)
www.partypickle.blogspot.com
82-T/A
82-T/A is offline
PostPosted: Mon Dec 17, 2007 11:20 am    Post subject: Reply with quote
If this has not been mentioned already... unless you absolutely want to keep the car 100% stock, I highly recommend you replace those old lines with steel lines. Steel lines will last twice as long, and hold pressure better than those old VW lines.
Todd,
(Fun cars)
2002 Ford Crown Victoria LX-P74
1987 Pontiac Fiero SE / V6
1973 Volkswagen Type-2 Transporter
dtrumbo
dtrumbo is offline
PostPosted: Mon Dec 17, 2007 11:37 am    Post subject: Reply with quote
Not after they crack from being hard-mounted to places that move independently of each other. The rubber is there to act as a "buffer" so the hard lines don't shake themselves to death.
1971 Super Sedan.
1973 Squareback.
1976 Transporter.
1979 Transporter.
1979 Beetle.
Brown_Bus
PostPosted: Mon Dec 17, 2007 1:20 pm    Post subject: Reply with quote
well I ordered the fuel line form GS, splurged for the 3-5 day shipping, found the window crank knobs and ordered them Smile ...
My wife called me at work to let me know that the fuel line has a ''slight'' 3-4 drop a minute drip. I do have a local mechanic who I trust dearly, but my work hours latley have been running later than his hours. He did offer to leave a , what he called a 12mm hose, for me to pick up after hours.
I am confused as GS and others reference an 11mm hose. Hopefully the 12mm will work until my shipment from GS arives. The bus isnt my daily driver so it isnt an immediate need, other than the previously mentioned trip at weeks end.
If there is enough light when I get home to get the hose changed out I wil report back. I could do it in the garage but dont want to smell it up with any spilt fuel.
Thanks guys
IFBwax
IFBwax is offline
PostPosted: Mon Dec 17, 2007 1:43 pm    Post subject: Reply with quote
As you know this is a must do. If it leaks on its own, imagine how much it will leak with it is under pressure from the pump.
I don't want to scare you, but I went and looked at a burned out bus a few months ago.
They had the same problem with the hose by the pump, but felt they could drive it the 1 mile to the VW garage to have them fix it.
They only got a few blocks before it burned to a crisp... and the bus was toast.
Here's some more information about hoses and such...
http://www.ratwell.com/technical/FuelHoses.html
1FUNBUG
1FUNBUG is offline
PostPosted: Mon Dec 17, 2007 2:00 pm    Post subject: Reply with quote
If the hose from the tank to the pump is leaking then it's not under pressure. However, it may be an indication that the hoses on the pressurized side (i.e. engine compartment fuel rail) are nearing their life expectancy. Anyhow, good move ordering from German Supply. I've used their fuel hose kit and was very happy with the results.
1FUNBUG
71 Beetle, 1776, dual Kadrons
77 Westy, Camper Special 2.0 F.I.
