Mr Maz Samba Member
Joined: September 24, 2004 Posts: 64 Location: Saskatchewan,Canada
Posted: Mon Jan 28, 2008 1:20 pm Post subject: T1 VS T3 CASE |
Can any one tell me the difference between a t1 as41 case and a t3 case? _________________ 1972 Squareback
1958 beetle
1975 super beetle
1982 vanagon |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Mon Jan 28, 2008 2:11 pm Post subject: |
Universal case will work for both. A little more information about what you have and what you want to do would help.
Oil filler Location is one obvious difference.
<edit> If it's for an automatic you will have to carve out a place to get at the torque converter bolts. _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
Mr Maz Samba Member
Posted: Mon Jan 28, 2008 2:34 pm Post subject: Sorry, here is more detail |
72 t3 squareback.
I purchased a used parts lot on ebay containing the parts to build a 1915cc
the case is a as41 flycut for 94mm, the heads are stock cut for 94mm(I will port these to make them flow better).I will have them rebuilt with ss valves.
Stock crank and rods from what looks like a 1600 autostick, new mahle cam,lifters. scat seals,push rods, hd springs. Im going to use a new set of weber icts from my 1600 for now but am going to change to megasquirt FI next year.
Its not optimal but a good start and should have lots of torque!  _________________ 1972 Squareback
1958 beetle
1975 super beetle
1982 vanagon |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Mon Jan 28, 2008 3:22 pm Post subject: |
If the crank is from a 1600 Type 3 automatic, there's no difference, AFAIK.
If it's from a Type 1 autostick, I'm not sure...
I didn't know Mahle made cams. Do they still?
Isn't an AS-41 case a universal case? If so, you just have to plug the dipstick tube for a Type 3 application. Everything else should work for a Type 3 motor. (oil filler tube, rear hanger bosses, etc.) _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Jan 28, 2008 8:33 pm Post subject: |
AS-41 just stands for the alloy the case is made from. There were different AS41's for T-1 and T-3. Then there was the Universal AS41, which would work for both. A universal AS41, would have both the T-3 dip stick mount, and the hole for the T-1 oil pressure switch. You just plug the one you dont use.
And there was no difference in the crank and rods for a automatic, autostick, or a manual trans. Only difference for the autostick engine was the oil pump. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Mr Maz Samba Member
Posted: Tue Jan 29, 2008 12:15 pm Post subject: |
Thanks Guys, puts my mind at rest.
Know its time to talk to my machinest. _________________ 1972 Squareback
1958 beetle
1975 super beetle
1982 vanagon |
