idle problems ???
[email protected]
stephvdw@mindspring.com is offline
PostPosted: Tue Aug 06, 2002 8:01 pm    Post subject: idle problems ??? Reply with quote
I'm looking into buying an '85 Vanagon. When it is idleing , the rpm will all of a sudden go up then after a few moments go back to normal. Any suggestions?
The engine has just had heads, bearing and rings replaced.
thanks
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Wed Aug 07, 2002 6:04 am    Post subject: idle problems ??? Reply with quote
Surging like that is usally related to a glitch in the FI system, it could be as simple as a vacume hose loose or off or several of them... or hooked up to wrong fittings.... Also the FI system may need to be tweaked out as it may have been messed with alot before the major repair was done...
Check all the hoses and around the "big air boot" for cracks ect... good place to start.
