steering problem
Cash Up Front
Cash Up Front is offline
PostPosted: Sat Aug 10, 2002 6:40 pm    Post subject: steering problem Reply with quote
got a 73 bus with extreme play in the wheel, when i say extreme im serious. feels like wheel doesn't want to turn tires when i want them to. also perhaps due to all this my turn signals will shut off on their own (lights do) the signal indicator stays on though. both problems started at the same time. help help help
chabanais
chabanais is offline
PostPosted: Sun Aug 11, 2002 12:37 am    Post subject: steering problem Reply with quote
Are your tie rods loose? Steering box toasted? Better look into those two things.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Sun Aug 11, 2002 8:22 am    Post subject: steering problem Reply with quote
Check out the "drag link" also, it goes from the steering box to the swing lever on the beam BEFORE it even gets to the tie rods ect. so it is commonly the first to go.... Pull the splash pan if it is still there and have a helper turn the wheel while you look everything over....
