Posted: Sat Aug 17, 2002 5:00 pm Post subject: Gas Tank Access--Help! |
My '77 bus has a chronic gas smell, and I tracked it down to cracks in the the rubber tank filler tube that attaches to the gas tank itself. I can see the cracks with a mirror and a flashlight through the round hole behind the air filter, and I can see that I'll need to get the firewall removed to unscrew the hose clamps, but I CAN'T GET THE FIREWALL OFF. The screws are off, and everything is out of the way, but I'll be damned if I can get the firewall off or out of the way. It's loose, and seems like it should come off, but it won't. What's the trick? I'm reluctant to use brute force on it. Help! |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Sat Aug 17, 2002 6:52 pm Post subject: Gas Tank Access--Help! |
If I remember right there is a sealant behind the panel and a pry bar is needed to pull it off. I also thought the motor had to come out to bring it out.While you are in that deep you might as well either replace the sending unit or at least put a new seal on it. That seal is usually another thing that causes a gas smell. Good luck. |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Sat Aug 17, 2002 10:31 pm Post subject: Gas Tank Access--Help! |
ALL the screws??
Did you remove the 2 that go up from the bottom? They are near the ends and are tough to find.
Then you pull the bottom to the rear and then down. The top edge hooks in place. |
