skippytheleglesshobo Samba Member
Joined: May 15, 2002 Posts: 105 Location: der Bezirk aus grün
Posted: Sun Aug 18, 2002 3:18 pm Post subject: 69 bus frontend/ cooling |
my bus sits nose high. about 1 or 2 inches too high. this looks kinda silly, and i am sure it is affecting my handling. what would be the best way to drop the front just a tad, about 1.5 inches? would coil over shocks be a good solution? or gas adjust?
also, does anyone know much about that oversize crank pulley that was in VWT a few months ago? the one that is supposed to give you more air from your fan. has anyone tried it out? any feedback. it seems like it is a good idea ya know. |
breadloafdeluxe Samba Member
Joined: February 12, 2002 Posts: 418 Location: Birthplace o Tx. Brazoria Co.
Posted: Mon Aug 19, 2002 4:56 am Post subject: 69 bus frontend/ cooling |
Maney Baywindow buses suffer from saggy ass syndrome. The cure is to reajust the REAR tortion arms,or if not to bad try the coil-overs.I also am intrested in that oversized pully by Bugpack, they wanted like $45.00 for it. I may give it a try later. DavidK 71 Deluxe,69S/Cab |
Posted: Mon Aug 19, 2002 4:58 am Post subject: 69 bus frontend/ cooling |
How'd that E get in there? I really need to proof read befor I post.D. |
chabanais Samba Member
Posted: Tue Aug 20, 2002 10:53 am Post subject: 69 bus frontend/ cooling |
Is your Bus higher in front when you are sitting in the driver's seat?
I'd follow the earlier advice but mine is that you'll never get a Bus to handle very well to begin with. |
Posted: Tue Aug 20, 2002 5:38 pm Post subject: 69 bus frontend/ cooling |
the bus is higher in the front compared to all the other baywindow buses around. and i've checked :>)
the ass is the right height, unless they all have a saggy ass.
the rear looks to be a real nice height, i;d just like to drop the front to match.
is that a no on coil overs? |
Posted: Wed Aug 21, 2002 7:43 pm Post subject: 69 bus frontend/ cooling |
I just went out and looked at my S/Cab that sits Perfect! I'm runnin 195x75r14s the top of the tire is 1 in. higher than the lip of the wheel well.Looking at my 71 7pass w/ the same tires sits about 3 in. from the lip to the top of the tire (ass sags) I'm puttin in a ajustable beam tomorrow so I can see more than asphalt out the rear view mirror!DavidK. |
