1978 Westy Wiring??
[email protected]
jeremymary@yahoo.com is offline
PostPosted: Thu Aug 29, 2002 7:33 am    Post subject: 1978 Westy Wiring?? Reply with quote
Thanks for the responses below regarding my water pump question. My next question is...
Is there a book or web address where I can find a detailed wiring diagram for the camper portion of the bus?
[email protected]
jlewis@wfisd.net is offline
PostPosted: Thu Aug 29, 2002 9:56 am    Post subject: 1978 Westy Wiring?? Reply with quote
There is no wiring diagram but you might find this interesting:
http://www.type2.com/bartnik/csmanual.htm
As far as the pump, (if you need a replacement), I would take the old one off, buy an adaptor to fit in the pump-to-tank hole, and buy a pump that does not hang from the tank. Mine broke where it screws into the tank, making a huge mess. I bought a better pump (maybe a "pro-flow"? I don't remember.) I then mounted it to the side of the compartment. The new pump was a better quality piece-should last a LOOONNG time. I icemaker filter placed in line to the faucet is in the near future. No more plastic taste!
[email protected]
PostPosted: Thu Aug 29, 2002 10:34 am    Post subject: 1978 Westy Wiring?? Reply with quote
Thanks, the original westy manual, just like the one you linked, came with the bus.
TimGud
TimGud is offline
PostPosted: Thu Aug 29, 2002 11:31 am    Post subject: 1978 Westy Wiring?? Reply with quote
You can find a wiring diagram for your bus at www.vintagebus.com . They even have one for the westy accesories. Good luck.
