'71 Bus Fuel System Hoses
chabanais
chabanais is offline
PostPosted: Tue Sep 03, 2002 9:02 pm    Post subject: '71 Bus Fuel System Hoses Reply with quote
Can anyone help me with the hose routing? One hose goes from an outlet in the fan housing into the air canister. Another hose goes from the oil spout into the air cleaner. Where on earth does the other hose from the air canister go? I looked in the Bentley manual and there was a picture of the hoses, however they didn't really say where they all go.
Thanks.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Sep 05, 2002 5:57 am    Post subject: '71 Bus Fuel System Hoses Reply with quote
Are you running a stock oil bath air cleaner? No I'm sure your not.... you have a 1776.... well the other hose went to a connection on the stock air filter assembly.
If you tee off your hose from the oil filler it shouyld do basically the same thing which is suck in the gas fumes and burn them in the air intake mixture along with the crankcase fumes...
