///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Sun Mar 16, 2008 3:35 pm Post subject: Squealing, screeching, screaming brake help needed. |
I can't take this any more. I have done about a zillion brake jobs in my life and I have never had more difficulty than my '74 coupe is giving me. The brakes on this Ghia don't squeal, they scream. It's practically deafening. In my attempts to fix it, I've done the following:
1. Bought new organic pads from Napa.
2. Used blue Permatex disc brake quiet on the backs of the pads (and allowed it to dry overnight)
3. Removed the rotors and sanded the faces down to perfection with 40 grit discs on my DA.
4. Beveled the edges of the new pads with a file.
5. Bent the anti-rattle clips to have more tension.
6. Used caliper grease on the edges of the pads where they touch the caliper and on the clips, pins, etc.
7. Bedded the new pads in with a few high-speed stops with cool-downs in between.
After doing all of these things, I've actually made it worse! I feel sorry for people in other cars or on the sidewalk - it's that bad. Has anyone else had this much difficulty with them?? |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1227 Location: Philaburbia
Posted: Mon Mar 17, 2008 4:17 am Post subject: Re: Squealing, screeching, screaming brake help needed. |
Tom, that's an impressive list of things you've tried. You know more about brakes than I do, but if your calipers/pistons are in good shape and aren't dragging then you might look into pads with a different composition. I suspect various compositions are available, since I read about the owner of a racing Ghia trying various pads to find the best composition for his application. Just some thoughts. Good luck.
Charley |
poorpaul Samba Member
Joined: March 17, 2008 Posts: 62 Location: Prairie Grove, Arkansas
Posted: Mon Mar 17, 2008 6:13 am Post subject: notching pads |
Pretty frustrating for sure. One thing we used to do with Jag pads was to cut a groove across the pad material. Some folk put it across the length, some the width, and some made two diagonals about 20 degrees beginning from a point at the inner center. I've also seen some pads that had a piece of brass embedded into a similar groove. |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Mon Mar 17, 2008 6:36 am Post subject: |
I would guess it is the pad compound, try another pad that isn't made by the same manufacturer. I have had this problem with my Volvo, it is enough to make you insane - pulling the calipers and pads apart 25 times.... |
Posted: Mon Mar 17, 2008 7:05 am Post subject: |
Well, I'm currently on the second set of pads - the first were semi-metallic, the newest ones are organic. They both screeched like crazy. But if anyone has a particular brand of pad they've had luck with, I'm all ears.
Interesting idea about the groove. The new pads have a vertical groove pre-cut in them. Maybe I will try a diagonal one, too. What have I go to lose? |
'73spr-DUNG-btl Samba Member
Posted: Mon Mar 17, 2008 7:18 am Post subject: |
I'm having the same troubles with my '74 |
brent bousman Samba Member
Joined: January 28, 2005 Posts: 263 Location: Annandale VA
Posted: Mon Mar 17, 2008 8:03 am Post subject: |
I never had any luck with different types of aftermarket disc brake quiet.
Which calipers are you using? I have seen 2 different metal backs for ATE and Varga that fit between the pad and the piston. Are you using these? |
Posted: Mon Mar 17, 2008 8:07 am Post subject: |
brent bousman wrote: |
I have the original '73.5 - '74 Girling calipers. No shims (and I don't think you could shim them - the pin doesn't pass through the pad). |
Posted: Mon Mar 17, 2008 8:16 am Post subject: |
I'm not familiar with the Girling calipers. The ATE has a metal plate that fits over part of the piston (held by the piston)and the Varga has a square metal piece that fits over the whole piston (held by a wire on the top of the pad). Do you know if the Girling had a stock plate behind the pad?
My guess is your squealing is your pad rubbing (vibrating) against the piston or the brake caliper somewhere. |
70 140 Samba Member
Posted: Mon Mar 17, 2008 8:33 am Post subject: |
The new Varga calipers come with pads and are $70-ish a side....
I don't know what else you would try Tom; switched pads, resurfaced rotors, adhesives, etc, etc... sounds like you have tried all the tricks. |
Posted: Mon Mar 17, 2008 8:48 am Post subject: |
70 140 wrote: |
The new Varga calipers come with pads and are $70-ish a side..... |
Yep, that's next, unless I come up with a miracle cure. |
70 140 Samba Member
Posted: Mon Mar 17, 2008 8:53 am Post subject: |
///Mink wrote: |
grease the rotors and pad surface?  |
Posted: Mon Mar 17, 2008 9:02 am Post subject: |
70 140 wrote: |
///Mink wrote: |
I was thinking I could just disconnect the front brake hoses. That should quiet it down. |
Posted: Tue Mar 18, 2008 8:19 pm Post subject: |
Well, you can add #8 to the list: Fabricated some half-shims to force the trailing edge of the pad to contact the rotor first. No change.
:2gunfire:
thom Samba Member
Joined: October 12, 2000 Posts: 6135 Location: Sacramento
Posted: Tue Mar 18, 2008 8:26 pm Post subject: |
Well, I have a set of 993TT fronts you could swap in... _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Posted: Tue Mar 18, 2008 8:27 pm Post subject: |
thom wrote: |
Well, I have a set of 993TT fronts you could swap in... |
Cool. Those should fit right under stock 15" wheels, right?  |
thom Samba Member
Posted: Tue Mar 18, 2008 8:40 pm Post subject: |
///Mink wrote: |
thom wrote: |
Well, I have some extra 930 spacers; you could stack a 2" and a 3" on each side.... _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Posted: Wed Mar 26, 2008 9:59 pm Post subject: |
Just wanted to resurrect this thread with a little more information. Since I originally posted, I've put about 400 miles on the car and the squeal is about 95% gone. I guess the new pads and "resurfaced" rotors finally mated up and quieted down. Kinda like a lot of new marriages.
I think my hearing damage was permanent, however. |
mr matt Samba Member
Joined: May 26, 2005 Posts: 968 Location: southeast Pa
Posted: Wed Dec 03, 2008 11:05 am Post subject: |
I'm kinda going through what you did on my super beetle w disc brakes.
I just replaced the disc pads & now
I also feel sorry for the people around me, even the people in other cars - hah, the worst of it is going through a tunnel an applying the brakes, the tunnel acts like a megaphone - it is unbelivable! I;m surprised people are not dropping down, passing out from the sound........
I will try some of the things you attempted above,
someone mentioned to me, that this will happen unless you cut the rotors a bit - I dont want to do that, so I will sand the heck out of them to remove the glaze and put in a new pattern.
Funny how the first time I put the disc brake system on my superbeetle, they never squealed.......which makes me tend to think cutting would solve the prob -
either that, or a lot of time for the brakes to mate to the rotor.......
Matt |
74Pepper Samba Member
Joined: March 26, 2007 Posts: 719 Location: Dallas, TX
Posted: Wed Dec 03, 2008 11:53 am Post subject: |
He-he...he said "mate".....  |
