what size tire (Rear) do you run on your Thing?
BajaRoy
BajaRoy is offline
PostPosted: Mon Mar 17, 2008 4:34 pm    Post subject: what size tire (Rear) do you run on your Thing? Reply with quote
I put my (finally found) Jackman wheels on my thing.
my thing is 95% offroad and 5% street use.
rear tires stick out like 3.5" and rub the fenders.
no problem driving on the street but as mentioned 95% offroad use.
each large bump can damage my rear fenders.
running 7" rims with 31 X 10.5 X 15 MickeyThompson Baja Terrain.
the thing is lifted 3" & afraid further lift requires 930CVs.
what tire size other thing owner running on their beloved thing?
npconnor
npconnor is offline
PostPosted: Mon Mar 17, 2008 6:01 pm    Post subject: Reply with quote
Take the rear fenders off, it's not hard, it looks weird but since no one's going to see it... Those look like nice tires, keep them!
'73 Thing
Austin Air-coolers Gang
Ferretkona
Ferretkona is offline
PostPosted: Mon Mar 17, 2008 7:32 pm    Post subject: Re: what size tire (Rear) do you run on your Thing? Reply with quote
Wish I knew you were looking, I have 4 in the patio I have been wanting to sell.
74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6
Ian Epperson
Ian Epperson is offline
PostPosted: Mon Mar 17, 2008 9:36 pm    Post subject: Reply with quote
Or, replace them with the extra-wide rear fiberglass fenders that the Thing Shop offers:
http://www.thethingshop.com/detail.asp?PRODUCT_ID=181WR
Description: Made the same shape as your original fenders with four inches added to the bolt edge to accomodate larger tires. You will like the quality-designed, heavily-reinforced, inner lip around the wheel well for extra strength. Can be cut to desired width.
Price: $120.00
VW-181 shirts and stickers.
http://ian.epperson.com/vw
Motochris
Motochris is offline
PostPosted: Tue Mar 18, 2008 10:32 am    Post subject: Reply with quote
I don't have a current pic...but I have 35x12.50's on back, 33x9.50's on front... no fenders.
www.F-O-A.com
BajaRoy
BajaRoy is offline
PostPosted: Tue Mar 18, 2008 12:10 pm    Post subject: Reply with quote
Thanks all for very good suggestions.
large rear tires will not help maneuver the tight rocky desert terrains.
already bent few rims on my baja bug.
I'm thinking about 7LT all the way around.
skinny tires & real tall side wall which usually use on front of the thing.
anybody tried this set up?
Fun 181
Zu Geil!
Fun 181 is offline
PostPosted: Tue Mar 18, 2008 2:37 pm    Post subject: Re: what size tire (Rear) do you run on your Thing? Reply with quote
Have you checked out this Thing sticky?
http://www.thesamba.com/vw/forum/viewtopic.php?t=279367
There are links to lots of posts dealing with larger tires, rubbing, clearance issues, etc. Check it out, it should be pretty helpful.
BajaRoy
BajaRoy is offline
PostPosted: Tue Mar 18, 2008 3:03 pm    Post subject: Re: what size tire (Rear) do you run on your Thing? Reply with quote
Thanks Fun 181, very helpful information.
I have 4 X 1973 Things in the desert house. two yellow running & two orange
which one is good restoration candidate & other orange one will be cut up
as a spare parts.my ultimate goal will be 1 wild offroad, 1 mild offroad &
1 complete restoration to an original condition.
