pete000 Samba Member
Posted: Mon Mar 24, 2008 2:13 pm Post subject: How to spot a 21 or 23 Clone ? |
I am more of a Vanagon guy, but interested in obtaining a 21 or 23 window Split bus. I have seen a lot that have been put together from donor parts windows roofs etc..
What do I look for when looking for the real deal ?
I want an investment vehicle and would not be that interested in a repro.
Does the VIN tell anything about the config from the factory?
Thanks _________________ 1990 Vanagon RS 2.1
1967 Deluxe 21 window
Koni Shocks
H & R Red Springs
Addco Sway Bars Front-Rear
18 X 7.5 and 18 X 8 OEM Porsche Wheels
Recaro Power-Heated seats |
IN2RUST Samba Member
Joined: October 30, 2005 Posts: 1942 Location: West Coast
Posted: Mon Mar 24, 2008 2:55 pm Post subject: |
The only Real way to tell is by a birth certificate. Also make sure it has belly pans. Also a good indication is the wiring will run through a tube in the belly pan and not have tabs in that area. But really only birth cert. |
Motel65 Samba Member
Joined: January 24, 2005 Posts: 84 Location: New West
Posted: Mon Mar 24, 2008 2:56 pm Post subject: |
As a non expert i would saythat it would be just as easy to clone the VIN number |
DMNCLNR Sir Camp'alot
Joined: November 12, 2003 Posts: 2897 Location: Newport Beach Ca
Posted: Mon Mar 24, 2008 3:49 pm Post subject: |
Motel65 wrote: |
Very true, I hear about people switching out the vins to make a 21 or 23 quite often. Belly pans are not such an easy swap, and are usually a good indicator of a fake. Sometime it can be very hard to tell, take your time and if you are the slightest bit suspicious, I would walk! _________________ To his their own PBJ
Pl@y@ #1 |
twinwindows Samba Pimp
Joined: December 08, 2000 Posts: 4086 Location: So.Cal. Highland Park GFK!
Posted: Mon Mar 24, 2008 4:29 pm Post subject: |
If you know buses from the inside out its way easy to tell. A vin wont always be able to help but key areas can and will tell the difference.
I ran into a guy who claimed his bus was a real 23 and had push button front door openers. I asked to open the rear decklid and sure enough there were all the tattletales of a 21 with a corner window bus being grafted on. Psssshhh... C`mon! _________________ CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote: |
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed. |
Posted: Mon Mar 24, 2008 5:24 pm Post subject: |
twinwindows wrote: |
I ran into a guy who claimed his bus was a real 23 and had push button front door openers. I asked to open the rear decklid and sure enough there were all the tattletales of a 21 with a corner window bus being grafted on. Psssshhh... C`mon! |
What about that guy at pomona slanging the fake 23? You called him out on his welds... _________________ To his their own PBJ
Pl@y@ #1 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69833 Location: Phoenix Metro
Posted: Mon Mar 24, 2008 6:17 pm Post subject: |
The M-code plate should have a Deluxe model code. Model 241 or 251 if this is a USA Bus. It should NOT have M-code 130 either, which would mean it was originally a hardtop Deluxe.
This is assuming the M-code plate is intact and original. If it's for investment purposes, I would pass on any Bus missing any VIN plates or M-code plate. _________________ How to Post Photos
60DoubleTurd Type 3 Contributor
Posted: Mon Mar 24, 2008 6:21 pm Post subject: |
So if I am looking at a REAL 15 it SHOULD have the 130 on the MCode plate right? _________________ Frank
66 L87 Variant Pigalle
SBS #17 |
Posted: Mon Mar 24, 2008 6:46 pm Post subject: |
I am pretty sure it is the real deal. It still has OG paint dash and OG paint under black primer. I hope it has the MCode plate on it still. It was in the woods under a tree for years. _________________ Frank
SBS #17 |
wanta23 Samba Member
Joined: March 31, 2007 Posts: 534 Location: At The Beach
Posted: Mon Mar 24, 2008 7:34 pm Post subject: |
60DoubleTurd wrote: |
I am pretty sure it is the real deal. It still has OG paint dash and OG paint under black primer. I hope it has the MCode plate on it still. It was in the woods under a tree for years. |
Why don't you tell me where it's at, under the tree, and I'll go check it out I'll let you know what I buy, I mean find |
Posted: Mon Mar 24, 2008 7:52 pm Post subject: |
make sure its a real tree though ....and not just some fake Christmas tree someones grafted on..... i hear that happens all the time |
Posted: Mon Mar 24, 2008 9:26 pm Post subject: |
wanta23 wrote: |
Its all done and done and is no where near any trees anymore. I'll let you buy.....I mean see it when I am finished with it and its $35K. _________________ Frank
SBS #17 |
Posted: Mon Mar 24, 2008 10:35 pm Post subject: |
wanta23 wrote: |
Its all done and done and is no where near any trees anymore. I'll let you buy.....I mean see it when I am finished with it and its $35K. |
Posted: Tue Mar 25, 2008 11:30 pm Post subject: |
I think the 21 walk through I am looking at is the real deal. It's a 67 with some rust and totally drivable. Some stuff is a bit off, but fixable.
I did a vin check on the bus vin check site and it came up with "Built on: August 1966"
It has chrome speedo ring, clock, chrome ash tray, deluxe trim, jail bars, OEM glass, belly pans and I see no evidence of any body work (headliner is all removed). Radio looks to be opened to din size (Junk cd player installed)? There are some odd holes drilled in the nose around the VW badge with plugs in them. Front safari windows poorly installed. All side glass has pop out hinges with painted trim.
I did get the VIN, but being the novice I am could not locate the Vin tag or M plate? Where do I find those.
Thanks for all the advice. Looks like I might be picking this one up. I will post pictures upon delivery. _________________ 1990 Vanagon RS 2.1
Koni Shocks
H & R Red Springs
roberto Samba Member
Joined: December 10, 2002 Posts: 833 Location: West Central Ohio
Posted: Wed Mar 26, 2008 4:53 am Post subject: |
It sounds like you are on the right track. most hacks don't install belly pans. very important. For me when trying to make sure are belly pans, and m-code 130. |
FG1732 Samba Member
Posted: Mon Apr 28, 2008 11:36 am Post subject: |
pics? |
Posted: Mon Apr 28, 2008 4:24 pm Post subject: |
I will post some pics soon. I am stripping it out, needs to visit the metal guy soon. Front floor is Toast, rear cargo floor, pretty bad, dash hacked for a crap radio (I found a donor section), lots of minor rust bites all over it, frame is solid, passenger side walk through partially cut. Crap $400.00 paint job, Surfer boy teal. Has good Velvet Green and pearl White under the trim and wheel wells.
M codes and VIN are all correct. True early 1967 21 window.
I think I paid a bit too much, but oh well at least I will be building what I want. I think she will sort out nicely. _________________ 1990 Vanagon RS 2.1
Koni Shocks
H & R Red Springs
mandysbus Samba Member
Joined: December 20, 2002 Posts: 567 Location: downtown womelsdorf
Posted: Tue Apr 29, 2008 6:52 am Post subject: |
pete000 wrote: |
I think I paid a bit too much, but oh well at least I will be building what I want. I think she will sort out nicely. |
67s did have a big square radio hole.......they take a 67 only blockoff plate |
Posted: Tue Apr 29, 2008 5:23 pm Post subject: |
Well this one is cut super big ! They sawed half the fins out ! I hate hacks ! They did leave the stock dash speaker intact though. _________________ 1990 Vanagon RS 2.1
Koni Shocks
H & R Red Springs
