Shock Recommendations for Reduction Box Baja Bug
thefladge
thefladge is offline
PostPosted: Fri Jan 11, 2013 2:42 pm    Post subject: Shock Recommendations for Reduction Box Baja Bug Reply with quote
I need new shocks for the rear of my Baja Bug. The car is equipped with Bus reduction boxes mounted in the laydown position using John Johnson Racing adapters.
I currently have a pair of well-worn Rancho shocks on the rear. When I installed these laydown adapters years ago, I fabricated mounts for 2 shock absorbers on each side, although I have only run one shock per side during this time. It also features Sway-A-Way 28mm short torsion bars.
I have Bilstein shocks in the front and they work great! I'm thinking of getting Bilsteins in the rear also, but I figured I should see what opinions I would get here first.
I'd like to run two shocks per side and each shock needs to be the same length as the rear shocks on a 1968 and later VW Bus in order to fit.
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
thefladge
PostPosted: Mon Jan 14, 2013 1:02 pm    Post subject: Reply with quote
Nothing?
I figured there must be other reduction box guys out there besides me.
I'll do some research on the Bilstein web site and others to see what I can find.
avrunner
avrunner is offline
PostPosted: Mon Jan 14, 2013 4:37 pm    Post subject: Reply with quote
i have a single kyb gas adjust on my redux setup happy with the way they work
Jeremy1Kanobe
Jeremy1Kanobe is offline
PostPosted: Mon Jan 14, 2013 7:16 pm    Post subject: Reply with quote
I am running a similar RGB setup with 28mm torsion bars. I ended up with a 10" fox with 60/70 valving. I have seen many run the KYB in pairs but have not tried that. The RGB is alot of unsprung weight so the shock must be fairly HD to control it.
Gregorio
Gregorio is offline
PostPosted: Mon Jan 14, 2013 7:24 pm    Post subject: Reply with quote
I'm running Bilstein 5100's and they work great.
thefladge
PostPosted: Wed Jan 16, 2013 11:07 am    Post subject: Reply with quote
Years ago I had some KYB shocks on the rear. They didn't last very long.
I think I will save my money for Bilsteins. They have a great reputation for reliability and look cool too!
