82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Sun Apr 06, 2008 3:18 pm Post subject: Help! w/ rear camber on lowered Vanagon |
I just had a question for members in the forum who've lowered their Vanagons
I have a 82 Westy with H&R lowering springs (w/ Bilstein HDs) that took the ride height down about 1 1/4" or so
I've had a full 4-wheel alignment and rear camber is a bit more than I would like and the spec's call for.
The rear camber adjustment is maxed out (the outer trailing bolt)
I was wondering who else has had this problem and if anyone has come up with a fix that allows more adjustment to bring the rear camber closer to the optimum setting.
I've been thinking of increasing the size of the oval adjustment hole for the outer bolt adjustment but thought I'd see if anyone has solved this problem before me
It didn't seem like too much of a problem when I was running 205/50HR14s on the factory allow wheels but now that I've stepped up to 225/55HR16 on 16x7.5 aftermarket rims, the excessive camber seems more pronounced and I'd really like to get the camber back closer to 0
Thanx
_________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
pgurnee Samba Member
Joined: November 05, 2007 Posts: 197 Location: Ferndale, CA
Posted: Mon Apr 07, 2008 12:19 am Post subject: |
When I got my 88 wolfsburg it had both the h*r lowered springs and too much camber. The alignment shop told me to remove the outer trailing arm bolt and make the hole in the bracket larger with a dremel. The larger hole will allow more adjustment of the camber.
I have not done this job yet but will very soon. I have to pull the trans and will do both jobs at the same time.
Good Luck
Paul _________________ 1988, In previous life a Wolfsburg Weekender in present life an excellent work truck. |
Posted: Mon Apr 07, 2008 7:58 am Post subject: |
Yep, enlarging that hole is the only fix I know of. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1929 Location: Bloomington, IN
Posted: Wed Apr 09, 2008 8:02 am Post subject: |
I have the same problem. I was told by the people over in the westfalia.org forum to go to a good alignment shop and have them enlarge the adjustment hole. That way when it is on the lift they can check out the bushing as well to make sure it hasn't gone bad and is actually the problem. That is one of the things on my list to do before using my van alot this summer. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Sun Jan 08, 2012 11:39 am Post subject: |
Thread resurrection!
I want to add neg camber but I can't seem to loosen the bolt for the outer trailing arm. Suggestions?
The Bentley say's up or down but doesn't state which way for more negative camber. |
insyncro Banned
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12175 Location: Port Manteau
Posted: Sun Jan 08, 2012 11:55 am Post subject: |
Man, I feel about ten feet tall right now. As I was reading this thread, I was imagining that same solution--damn! Sometimes a mental midget like me can actually cobble together cognitively functional ideas.
I'm going to log out now before I get smacked back down to earth _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Sun Jan 08, 2012 9:32 pm Post subject: |
| K58 wrote: |
Usually it's the trailing arm bushings that sag, and you get too much negative camber; in this case you want less negative camber. Anyway, to get more negative camber, the bolt would move up. Your bolt is likely rusted to the bushing. Maybe you can get it out with penetrating oil and an impact wrench. You can sawzall the bolt and bushing as a last resort, but you'll need to replace the bolt and bushing in that case. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
edit: double post _________________ 1986 Vanagon Westfalia EJ25
K58 Samba Member
Posted: Sun Jan 08, 2012 10:08 pm Post subject: |
| presslab wrote: |
| K58 wrote: |
Usually it's the trailing arm bushings that sag, and you get too much negative camber; in this case you want less negative camber. Anyway, to get more negative camber, the bolt would move up. Your bolt is likely rusted to the bushing. Maybe you can get it out with penetrating oil and an impact wrench. You can sawzall the bolt and bushing as a last resort, but you'll need to replace the bolt and bushing in that case. |
Awesome, thank you! That's the info I was looking for.
When I had an alignment done recently they told me the left bolt was stuck but didn't offer a fix (said camber was off by a small amount and not to worry about it.) I like everything to work on my vehicles so I'll try your advice. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19005 Location: Retired South Florida
Posted: Mon Jan 09, 2012 11:28 am Post subject: |
| K58 wrote: |
| presslab wrote: |
| K58 wrote: |
Changing your camber changes your toe. So, if your camber was close, and you are concentrating on just freeing up the seized bolt. Mark your bolt position before you start to work. This way you can get it back close. I have one seized as well, but plan to tackle it when I change the rear trailing arm bushings. |
insyncro Banned
Posted: Mon Jan 09, 2012 12:16 pm Post subject: |
I cut off all original stock bolts and bushings in the rear if they don't spin freely after hitting them with a 3/4 impact gun.
The replacements I have been using are Burleys black (hard) or Powerflex (softer).
Both install easily.
grease the new hardware well and loosen and spin the bolts once a year to insure they don't seize again. |
SeattleDownhill Samba Member
Posted: Tue Jan 10, 2012 12:34 am Post subject: |
Yup... I have the same issue. I think I'm at 3.5 or 4 degrees of neg. camber... I'm really low.... I took my van into a local place recommended by multiple people on here and they weren't able to do enough without grinding out the rears. I didn't have the money to pay them to do it at the time, so I will need to go back. I trust myself with a lot more stuff now than in the past, but still not alignment or anything dealing with it. I'll leave that to the pro's.
those camber plates look pretty rad. very common in the golf/jetta scene. |
SouthOlive Samba Member
Joined: October 31, 2009 Posts: 133 Location: The Nexus of Crisis
Posted: Fri Aug 03, 2012 8:41 am Post subject: |
Does anyone know where to buy them in the US? Brickwerks say they won't ship here.  _________________ 1985 Westy
2011 GTI |
