New Porche rod nuts....surface rust on threads
Jonasand
Jonasand is offline
PostPosted: Mon Mar 07, 2022 1:08 pm    Post subject: New Porche rod nuts....surface rust on threads Reply with quote
Bought 8 new genuine porche rod nuts. They were sent from Porche Germany to my retailer... I noticed some of them had surface rust on threads.
Is this cause for concern or not?
79 Baywindow, currently rebuilding engine
Type 4 2.0 L FI
Hydraulic lifters
bsairhead
bsairhead is offline
PostPosted: Mon Mar 07, 2022 3:48 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Yes, I would not except as new. Dings all over, not new.
Brian
Brian is offline
PostPosted: Mon Mar 07, 2022 4:22 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Run an oiled tap through them.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
SGKent Premium Member
SGKent is offline
PostPosted: Mon Mar 07, 2022 4:27 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
run an oiled bolt thru them. A tap will remove metal. When you torque them make sure they feel normal. Or ask the seller to find some that aren't rusted.
Abscate
Abscate is offline
PostPosted: Mon Mar 07, 2022 6:12 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
As long as itโ€™s genuine Porsche Rust it will be ok/
aeromech
aeromech is offline
PostPosted: Mon Mar 07, 2022 7:05 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Calmโ€ฆโ€ฆ.
Should be ok
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent is offline
PostPosted: Mon Mar 07, 2022 7:30 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
you can also run a spiral wire brush in them to knock the rust off.
aeromech
aeromech is offline
PostPosted: Mon Mar 07, 2022 9:28 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Steve, do you have a link?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent is offline
PostPosted: Mon Mar 07, 2022 9:51 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
go to your gun cleaning kits and there you will find bore brushes about the same size as the threads. The only one you can't use are spiral wound stainless brushes like for a 12 ga. Most of the brass and stainless bore brushes have bristles that will work.
https://www.amazon.com/Pieces-Stainless-Different-Twisted-Cleaning/dp/B095SHKQ86
PostPosted: Tue Mar 08, 2022 10:09 am    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Moderator note:
Please don't post political BS, it was cleaned up.
Wildthings
Wildthings is offline
PostPosted: Tue Mar 08, 2022 10:24 am    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
I would be a bit peeved to pay for a expensive Porsche part that hadn't been stored well. A tap shouldn't be taking any metal at all, oiled up it should turn through the nuts with little force. You could also oil them up and just run them onto an old bolt a few times.
Jonasand
Jonasand is offline
PostPosted: Tue Mar 08, 2022 2:34 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Yes Iโ€™m considering returning them... but then it will be a week before next shipment... but thats ok, my rods will not be back from the mashinist anyway.
Thanks for you answers guys
And to abscate... if I decide Iโ€™m going for that rod-nut-Rat-look, then genuine porche rust cant be beat. VW rust just looks so cheap in comparison. And even though no one can actually see my rod nuts, I can still brag about the rust on them being genuine porche rod nut rust.
Type 4 2.0 L FI
Hydraulic lifters
busdaddy
busdaddy is offline
PostPosted: Tue Mar 08, 2022 3:35 pm    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Some rod nuts are tweaked slightly to make them friction fit on to the threads, a tap may round them back out.
I'd try some of the milder internet tricks for rust removal, like soaking them in Coca cola, molasses or vinegar first, it doesn't look like it'll take much to get it off, but any debris in the threads may skew torque wrench readings.
Слава Україні!
busman78
busman78 is offline
PostPosted: Wed Mar 09, 2022 6:47 am    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Run a wire brush thrugh them, a drop of oil or a drop of locker and use them, they will spend the rest of their life in oil, slim chance they will ever rust out.
dogmeat
dogmeat is offline
PostPosted: Thu Mar 10, 2022 2:24 am    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
NO tap. clean them and go
SGKent is offline
PostPosted: Thu Mar 10, 2022 7:59 am    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
do not tap. Tap removes metal. You can chase them or replace them.
George Carlin:
Skills@EuroCarsPlus:
Jonasand
Jonasand is offline
PostPosted: Sat Mar 12, 2022 9:33 am    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
Thanks guys
I ordered eight more nuts so hopefully there are at least four good ones in this shipment.
Type 4 2.0 L FI
Hydraulic lifters
oscarsnapkin
oscarsnapkin is offline
PostPosted: Sat Mar 12, 2022 11:15 am    Post subject: Re: New Porche rod nuts....surface rust on threads Reply with quote
There are cheap kits of Dremel-type attachments that would have small metal brushes you could use with a drill. Iโ€™ve used them for cleaning rusty nuts and they worked great. I paid a few bucks at either Harbor Freight or Home Depot.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"Itโ€™s so easy to laugh, itโ€™s so easy to hate, it takes strength to be gentle and kind."
